Home > Technical > Heated Breather Modification LTB00196 for arctic regions
Page 2 of 7 <1234567>
Denis
Russia 2010 Defender 110 Puma 2.4 SW Stornoway Grey
rubber sealants. Sideways - one sealant on each side of bonnet
Front of bonnet - 2 rubber sealants - one on bonnet, one on body.
 Puma 110
Post #123284 11th Feb 2012 7:23pm
thanks Denis.
looking at the picture of the engine blanket ... how do you use it ?
> are these your modifications or land rovers ?
> do you take it off when you start the engine ?
> why do the belts not get caught up in it ?
cheers
bp
Post #123289 11th Feb 2012 8:13pm
Denis
blanket - rather common mod here... there are many sizes for different cars, it's made somewhere in Russia
you don't need to take it off at all, it's heavy enough to keep form.
use - as shown on photo - you tidy put it in and close the bonnet, that's all. It's approved for use in cars and made for that.
material - some type of fiberglass. Personally I use it second winter and very pleased with it.
site of manufacturer http://www.avtoteplo.net/
cheers Puma 110
Post #123294 11th Feb 2012 8:30pm
thanks again Denis Thumbs Up
Post #123330 11th Feb 2012 11:21pm
had the heater installed at the dealer today ... here's the pictures
Standard:
With Heater installed:
Post #124744 17th Feb 2012 6:42pm
dgardel
Italy
MAMMA MIA!!!!
but the dealer had finished the sheaths????? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #124763 17th Feb 2012 7:48pm
Daniele not sure what you mean ?
the insulation on Denis' was added by Denis.
the problem is inside the pipe not outside.
Post #124766 17th Feb 2012 7:59pm
dgardel
Italy
I mean the blue electrical cable, w/o protection, where you can see it.....
or the plastic ties like ....
not my style Thumbs Up
Please add spitted heaths/protections for a better view and protection
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #124771 17th Feb 2012 8:05pm
ah, yes, I will be fixing that properly tomorrow, I have some non-sticky insulating tape Thumbs Up
Post #124791 17th Feb 2012 9:01pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I've got a few hundred metres of spiral wrap if you need it Thumbs Up
Pete
Post #124802 17th Feb 2012 9:15pm
thanks for the offer Pete Thumbs Up
I've had a look in my electrics box, I have 2 metres of convoluted tubing .. that will do perfectly, pics to follow.
Post #124852 17th Feb 2012 10:28pm
Denis
Need to do on mine also, thanks Thumbs Up Puma 110
Post #124877 18th Feb 2012 12:28am
removed and re-installed with cable protection and tested Thumbs Up
there is an inline fuse that I will remove until the Nordic trip
Post #124928 18th Feb 2012 11:57am
dgardel
Italy
Hooo
Now is "dgardel" approved!!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #124934 18th Feb 2012 12:29pm
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
You're right dgardel - it would have cost all of 30p extra for the dealer to do it properly!
Post #124946 18th Feb 2012 1:35pm
