![]() | Home > Technical > Heated Breather Modification LTB00196 for arctic regions |
Denis Member Since: 28 Dec 2010 Location: prairie Posts: 58 ![]() ![]() ![]() |
rubber sealants. Sideways - one sealant on each side of bonnet
![]() Click image to enlarge Front of bonnet - 2 rubber sealants - one on bonnet, one on body. ![]() Click image to enlarge Puma 110 |
blanket - rather common mod here... there are many sizes for different cars, it's made somewhere in Russia
you don't need to take it off at all, it's heavy enough to keep form. use - as shown on photo - you tidy put it in and close the bonnet, that's all. It's approved for use in cars and made for that. material - some type of fiberglass. Personally I use it second winter and very pleased with it. site of manufacturer http://www.avtoteplo.net/ cheers Puma 110 |
thanks again Denis
had the heater installed at the dealer today ... here's the pictures
Standard: ![]() Click image to enlarge With Heater installed: ![]() Click image to enlarge |
MAMMA MIA!!!!
but the dealer had finished the sheaths????? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Daniele not sure what you mean ?
the insulation on Denis' was added by Denis. the problem is inside the pipe not outside. |
I mean the blue electrical cable, w/o protection, where you can see it.....
or the plastic ties like .... ![]() Click image to enlarge not my style ![]() Please add spitted heaths/protections for a better view and protection Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License |
ah, yes, I will be fixing that properly tomorrow, I have some non-sticky insulating tape
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 ![]() ![]() ![]() |
I've got a few hundred metres of spiral wrap if you need it
![]() Pete |
thanks for the offer Pete
![]() I've had a look in my electrics box, I have 2 metres of convoluted tubing .. that will do perfectly, pics to follow. |
Need to do on mine also, thanks ![]() |
removed and re-installed with cable protection and tested
![]() there is an inline fuse that I will remove until the Nordic trip ![]() Click image to enlarge |
Hooo
Now is "dgardel" approved!!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 ![]() ![]() ![]() |
You're right dgardel - it would have cost all of 30p extra for the dealer to do it properly!
