Home > Technical > Heated Breather Modification LTB00196 for arctic regions |
Denis Member Since: 28 Dec 2010 Location: prairie Posts: 58 |
rubber sealants. Sideways - one sealant on each side of bonnet
Click image to enlarge Front of bonnet - 2 rubber sealants - one on bonnet, one on body. Click image to enlarge Puma 110 |
11th Feb 2012 6:23pm |
blanket - rather common mod here... there are many sizes for different cars, it's made somewhere in Russia
you don't need to take it off at all, it's heavy enough to keep form. use - as shown on photo - you tidy put it in and close the bonnet, that's all. It's approved for use in cars and made for that. material - some type of fiberglass. Personally I use it second winter and very pleased with it. site of manufacturer http://www.avtoteplo.net/ cheers Puma 110 |
11th Feb 2012 7:30pm |
thanks again Denis
11th Feb 2012 10:21pm |
had the heater installed at the dealer today ... here's the pictures
Standard: Click image to enlarge With Heater installed: Click image to enlarge |
17th Feb 2012 5:42pm |
MAMMA MIA!!!!
but the dealer had finished the sheaths????? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
17th Feb 2012 6:48pm |
Daniele not sure what you mean ?
the insulation on Denis' was added by Denis. the problem is inside the pipe not outside. |
17th Feb 2012 6:59pm |
I mean the blue electrical cable, w/o protection, where you can see it.....
or the plastic ties like .... Click image to enlarge not my style Please add spitted heaths/protections for a better view and protection Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
17th Feb 2012 7:05pm |
ah, yes, I will be fixing that properly tomorrow, I have some non-sticky insulating tape
17th Feb 2012 8:01pm |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 |
I've got a few hundred metres of spiral wrap if you need it
Pete |
17th Feb 2012 8:15pm |
thanks for the offer Pete
I've had a look in my electrics box, I have 2 metres of convoluted tubing .. that will do perfectly, pics to follow. |
17th Feb 2012 9:28pm |
Need to do on mine also, thanks Puma 110 |
17th Feb 2012 11:28pm |
removed and re-installed with cable protection and tested
there is an inline fuse that I will remove until the Nordic trip Click image to enlarge |
18th Feb 2012 10:57am |
Hooo
Now is "dgardel" approved!!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
18th Feb 2012 11:29am |
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 |
You're right dgardel - it would have cost all of 30p extra for the dealer to do it properly!
18th Feb 2012 12:35pm |
