![]() | Home > Technical > Heated Breather Modification LTB00196 for arctic regions |
Kris
you have an email Steve |
Kris
that's because your steering wheel is on the wrong side ![]() nice little kit and you can take the fuse out for the summer ... I must remember to put it back in before you know what ! btw - does it make a difference on the fan setting ? I thought it just used the fan +ve feed - but happy to be corrected |
Phoenix90 Member Since: 04 Mar 2012 Location: Cornwall Posts: 377 ![]() ![]() ![]() |
Yes, would be very upsetting to suffer failure for forgetting a fuse!!
I assumed the fan speed was controlled by varying the voltage to it at the plug where the heater joins in. Just an assumption though. I'll put a meter on it tomorrow when i'm back out there. |
I've put the fuse back in just to be safe ..
D'MARIQUE Member Since: 17 Aug 2013 Location: Russia, Ekaterinburg Posts: 17 ![]() ![]() |
Has anyone tried the heater kit for the Ford Transit?
![]() ![]() They had the same problem & the dealer's fixing the bug till today for free, because of "safety measures" ![]() Transit kit should cost less than LR, I suppose...))) Anyone tried? |
It's probably the same heater
Another alternative would be to fit an oil catch tank and block off the air box hole |
Добрый вечер D'Marique,
Welcome to the forum as I see this is one of your first posts. Where abouts in Russia are you, and which Defender are you driving there? I know your country pretty well, anywhere from Moscow down to Volgograd, Voronezh, Belgorod, Rostov, Stavropol and Krasnodar oblasts. ![]() Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Привет, Ericvv! Yes, right, I'm newbie here))) Bought my Def couple months ago: it is 110 '08. Awesome wagon with it's own character & soul))) ![]() In Russia I live in Ekaterinburg, Ural & travel around the region mostly))) Now, with my Def I will widen my traveling area in the country for sure ![]() |
Welcome on board D'MARIQUE!
![]() ![]() IID Pro MV License |
Taken from a Rented Peugeot (came from 65CV Diesel 2013 208)
![]() Need time to install ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License |
Wow! ts nice! ![]() Looks like it will fit perfectly ![]() P.S. I thought it couldn't be that cold in Venice ![]() |
![]() but in Alleghe, in the Alps, where my father in love live, normally arrives at -22. ![]() ![]() IID Pro MV License |
-22 - it's a nice warm winter, i should say))) ![]() I'm also thinking of another heating option - FLEXIBLE TAPE HEATER Seems easy to install & to use. Costs about $30 for 1 meter, 12V. http://www.homakoh.ru/production/auto-en/engl/ |
