![]() | Home > Technical > Heated Breather Modification LTB00196 for arctic regions |
D'Marique, will be interesting to see reactions to this discovery and please keep us informed of how you get on with installation, but.... what is that hunting or shotgun ammunition doing in the picture
![]() ![]() ![]() http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Eric - I got a 12 bore cartridge with my heater pipe - I think its part of the installation
I guess those cartridges come as an official LR option in Russia.... Probably Land Rover Russia also offer the equivalent of the Swiss "Hunter" limited edition there. And the gunbox in the back probably is prepacked in Solihull with some rounds of these cartridges. Did not know that this type of cartridges fit into a standard Kalachnikov....
It would be interesting if you post the ford P/N(s). ![]() ![]() IID Pro MV License |
Reminds me of the cold starting kit for Bedford MKs and the like but guessing it's here for scale comparison?
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6126 ![]() ![]() ![]() |
^^^^ That was a canister of ether that sat on the dash, wasn't it.
Sounds familiar - only used one a couple of times but they all seemed to be fitted with them - was it pop in a canister, screw down lid and I seem to recall there was a manual pump handle involved somewhere?
That was is, the long handle you pull/push from the dash to get it into the inlet manifold.
Never used one in anger, only fiddling with it when bored. ![]() |
I'm guessing if there was someone at the MOD responding on an MOD forum to the question "What optional extras did you spec that you later realised were not required/were useless" then this kit should be close to the top of the list
D'MARIQUE Member Since: 17 Aug 2013 Location: Russia, Ekaterinburg Posts: 17 ![]() ![]() |
The standard 70mm shotgun shell nearby - is just for describing the scale ![]() There was no ruler, so the ammo came in handy ![]()
Yes, sure, here it is - FORD 1680029 ![]() Click image to enlarge |
![]() ![]() ![]() ![]() ![]() IID Pro MV License |
going back on topic, when I refitted my heater, i added a switch on the dash, of course the other option is to remove the fuse unless you are going somewhere where the temperature is < -10C
In the OP, Steve said that any issue with this was resolved by LR as of VIN 7A776667. In our climates here, and with my VIN which starts with 9Axxxxxx, is there going to be any issue?
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Talked to "Ford Transit" serviceman this weekend & he said, that on ford this heater works 12 months a year and 7 days a week ![]() ![]() So, i found the cable to connect the heater, but it seems, that there's no such socket/plug on LR... On Transit it is simple: disconnect the existing connection and plug the heater cable in parallel (sorry, for mess-explanation) Here are the pics ![]() ![]() ![]() Maybe someone will recognize it? ![]() If no, then the opposite to the heater end of the cable is to cut & connect to the cabin heater fan, as some dealers do. You turn on the cabin heater & the breather is heating as well; your turn off the cabin heater if it's warm - & the breather heater is turned off also. Something like that... P.S. And of course, the p/n of the cable: Ford 1540797 ![]() |
