Home > Maintenance & Modifications > New Topic Name: Trailing Arms bush removal DONE!!!!!
Page 4 of 4 <1234
revd
Grenadier wrote:
Thanks Revd. Yup, have heard the poly vs OE argument before, for many bushes not just the ones we’re talking about.
Amusing that you say that Solihull weren’t happy with all aspects of its performance, given they didn’t seem to give a fig about the Defender’s performance for the last 20+ years of its, ahem, ‘development’. More likely than not, the performance they were talking about was in the ‘how is this expensive to build’ vehicle performing on the accounts department’s spreadsheet. In that regard, poly would have been a far worse performer than the parts bin downstairs with thousands of OE bushes already in stock…. Whistle
My pal at Solihull is Defender suspension/chassis engineer and has been for probably thirty years, over that time a lot of development/improvements were cancelled on cost grounds, but his vast knowledge is still valid when maintaining an old LR - especially because he knows what works and what doesn't. in the case of poly v OE he has no axe to grind, just his professional opinion based on hard data. - Another contact is a small independent with a four poster, my pal has kindly offered to give up a Saturday when I get round to swapping the bushes.
Post #1057328 14th Jan 2025 8:41am
Grenadier
Good to know. I'll be interested to know how this swap gets on. Immediately the weaving on a straight road (the reason I felt the need to tackle trailing arms and the a-frame), feels much tighter. Weaving gone. However, tipping into a corner/hairpin, still feel something is happening, so I'll do the a-frame next. Anyway, my OEM (main triangular bush), and Terrafirma (trailing arm to axle) bush combo certainly feel better, we shall see how they get on long term, and what difference once the a-frame ball joint has been replaced, later this week.
 Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #1057360 14th Jan 2025 4:33pm
revd
Be interested to see if A frame ball joint has any obvious wear, there was a factory upgrade from Td5 forward that escaped the accountant’s penny pinching with the result that the ball joint was much improved
Post #1057372 14th Jan 2025 5:49pm
Grenadier
Will let you know Revd. Prior to the trailing arms being done, there was a noticeable knock from under the rear axle if, for example, I reversed slowly, then drove forward. Just driven it, knock is still there but considerably less pronounced. So A-frame BJ might literally be the last item to tighten everything up. Thumbs Up Monsieur Le Grenadier
Post #1057424 15th Jan 2025 8:23am
A frame ball joint and the other two bushes knock quite a lot when worn out. WeWillWin🇬🇧🇺🇸
Post #1057474 15th Jan 2025 6:39pm
Page 4 of 4 <1234
