Home > Maintenance & Modifications > New Topic Name: Trailing Arms bush removal DONE!!!!!
Page 2 of 4 <1234>
Push a socket through it in a vice if you can, with a larger socket one side and a smaller one on the inside, be sure the smaller one isn’t tapered so won’t get stuck so a socket about 1 - 2mm smaller than the outer is ideal.
You might need a large vice though admittedly, which you may not have. TheThunderRolls🇬🇧🇺🇸
Post #1056581 7th Jan 2025 6:12pm
D44 do some nice ones as well, but they are more competition spec. TheThunderRolls🇬🇧🇺🇸
Post #1056582 7th Jan 2025 6:13pm
rustandoil
I'd suggest you haven't quite cut through the bush...... But you're nearly there 👍🏼
Post #1056583 7th Jan 2025 6:16pm
landy andy
What he said.
Cut deeper.
Post #1056596 7th Jan 2025 9:00pm
jst
this is the method i use, either in a vice or hit with a sledge hammer (prior to getting a press) dont expect to use the impact socket again after the sledge method. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1056613 7th Jan 2025 11:04pm
Grenadier
JST, I’ve got some redundant sockets around that I can afford to lose. I don’t have a vice, so if I used the sledge technique, what do I do it against? The ground? Concrete? I’m trying heat next. See where that gets me. But once this side is out, I’m taking the other straight to the garage. Really annoying as all parts (including the a-frame ball joint) are ready to put back in and I’ll need the Def for a (potentially snowy) drive up to 2000m on Sat am. Need it done by then. Whistle Big Cry Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #1056638 8th Jan 2025 10:18am
Grenadier
Nope, no vice. What if I push reeeealy hard? Rolling with laughter
Going for the heat, cut and chisel (more) technique first. Then might do some bish, bash, bosh over lunch… Thumbs Up Monsieur Le Grenadier
Post #1056640 8th Jan 2025 10:19am
Grenadier
Done. TFFT. Going to take the other arm to a garage. Rolling with laughter
Thanks again everyone. Once again, Def2 members come up trumps. Thumbs Up
Post #1056647 8th Jan 2025 12:04pm
excossack
One done, same to the other and save garage costs Smile
good luck 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1056657 8th Jan 2025 1:09pm
Shafski
United Kingdom 2015 Defender 110 Puma 2.2 USW Montalcino Red
Second ones always the easier one! You’ll be fine Thumbs Up Shafski
_________________________________________
2015 110 Montalcino Red Utility "Harriet" along with Puma on I.C.E
Post #1056663 8th Jan 2025 1:42pm
rustandoil
Yeah, you've done the learning bit, second one will be a piece of cake... Buy something else with the money you save from garage cost 😉
Post #1056664 8th Jan 2025 1:56pm
sako243
A hydraulic press Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #1056680 8th Jan 2025 4:26pm
revd
I’ve got a pal with a 100 ton press lined up for bush swaps, hoping not to need anything larger 😂
Post #1056686 8th Jan 2025 4:51pm
sako243
Never had anything need more than about 7t and that was to disintegrate an L322 wheel bearing. A bit of thin oil, particularly when it starts moving makes things a lot easier. Ed
Post #1056692 8th Jan 2025 5:35pm
Grenadier
Well, the first took 2-3hrs to get out. The second 20mins. Laughing Laughing Laughing
Glad I didn’t take it to a garage. Rolling with laughter
Another question. I’ve got standard replacement bushes (the version with two metal tubes with rubber sandwiched in between), but I’m wondering about a polybush version. What brand would anyone recommend?
Post #1056742 9th Jan 2025 9:30am
Page 2 of 4 <1234>
