Home > Modifications & Maintenance (L663) > Retrofit 11.4 Pivi Display |
Clark4x4 Member Since: 19 Jun 2023 Location: Madrid Posts: 36 |
So... 13.1 upgrade DONE!!!
but, I used a USED Range Rover Sport screen, so not brand new, I guest has coded for Range Rover Sport... and is a "destructive" method... you need to cut some trims, at lease to install in the way I prefer, there is a kit (powerfull) to do it in not destructive way so first test used screen is working. IMPORTANT, need to add the 2 adittional power wires (PINS 6 and 7): Click image to enlarge connect, change CCF, multican 641, couple of reboots and voila: Click image to enlarge after check everything is working, all images are good, defender model, not RRS!!!... then to finish installation, enter in destructive way... we need to adapt one plastic piece first: cut some space for connectors (in orange) and made new holes to use plastic trim from 11.4 in 13.1 screen: (yes, I do 2 more than I needed.. I take wrong lenght) Click image to enlarge I need to check lenghts several times, (the idea is keep same bottom position, I add 2 mm to get more space) but at the end I got plastic trim as I wanted (yes, I do 2 more than I needed.. I take wrong lenght): Click image to enlarge Ok, now I can install screen. but upper trim need some work.... more or less you need to remove this area: I user a multy tool, first separate the fabric from plastic, and use a piece of metal to avoid cutting fabric, so at the end: Click image to enlarge put upper trimm and that's all!!! Click image to enlarge If some of you are interested in my previous 11,4 screen... check for sale area Cheers!!! |
6th Jan 2025 1:54pm |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2670 |
I'm now the proud owner of the GAP IID tool and this is on my wish list.
I know that screens from other JLR models will work, but is there a concise list of part numbers for the screens that do work? Looking at ebay there seems to be loads of screen but I'm not sure which to buy, it could work out quite expensive if I keep buying the wrong screen 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
7th Jan 2025 1:08pm |
LostCause Member Since: 07 Jan 2025 Location: Toronto Posts: 5 |
Thanks for all this valuable info Thunderbob. I was also looking at AliExpress option considering size and the fact it comes with pre wired adaptor and mounts. You mentioned in an earlier post that the screen only powers on when the vehicle is running. So no screen power up on just entry to vehicle and such. Was this still the case once you had it coded correctly? I have a v4 Gap tool already was this what you used for your original coding that did not work? |
8th Jan 2025 6:25pm |
Beautiful job Clark4x4! Thanks for sharing all this info. I'm also reviewing options to upgrade and your posts have been very helpful. |
8th Jan 2025 6:27pm |
ThunderBob Member Since: 23 May 2024 Location: Kentucky Posts: 13 |
@lost cause The screen powers on and off exactly like the OEM screen; Click image to enlarge there is no difference. When I used my Gap tool (v4 with latest firmware) the screen acted just like it would if I had the wrong screen size entered in the CCF ie like the screen was not powered on. When I reverted back to the original CCF setting the screen powered on albeit with the slightly stretched display. When the vendor made the change’s remotely via my laptop, I could change the resolution via the screen change as shown on my original post. No need to change the wiring or use an adapter. Not as satisfying as @Clark 4x4 solution but much easier and the end result essentially the same. Click image to enlarge |
9th Jan 2025 4:27am |
Thanks for the reply ThunderBob. So just to be 100% clear even before starting the ignition when you get in the vehicle the after market screen will power up to the land rover splash screen? if so this is awesome news. Makes me wonder if there is an additional value besides the screen size in the config file that is being changed by the vendor of the screen. If size is the only setting for an OEM screen to make it work one would assume. Sorry for all the questions I do have one more. When getting the vendor to remote in to make the changes are they always available or do you setup an appointment.
9th Jan 2025 3:27pm |
mikesdnielsen Member Since: 27 Oct 2024 Location: Aalborg Posts: 2 |
Thanks for all the great information in this thread.
I've been on the same journey over Christmas. I bought a brand new 11.4" screen from a supplier in the UK. I did the coding using the my IID Tool, but I was not able to get the screen to coded. Coding and "hacking" Defender is not a big thing here, I think as it's a very small market for this type of car here. I've just had it with the local Land Rover workshop, and they were also not able to get it coded straight away. They'll try it again using one of their newer Defenders that were "born" with the 11.4" screen (it was unfortunately out). I'm also in dialog with GAP about how to possibly solve this, in case the dealer comes back unable to do it. Mounting the screen with the Powerful UK custom bracket as a breeze though - I can really recommend this as it seems very easy to use. |
10th Jan 2025 12:22pm |
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 170 |
hello,
When you buy a NEW screen it must be programmed with Pathfinder or topix cloud, tools that the land rover dealer has. For programming it is necessary that you FIRST tell the car that you have an 11.4 screen, (with the Gap tool you modify ccf), then THEN you go to the dealership with the new screen installed, connect topix cloud, idma-interactive display module A, module programming, module replacement, run, and it performs the correct programming. Marco |
10th Jan 2025 6:32pm |
Thank you, Marco! I'll try this with them. I really appreciate it! 🙌
10th Jan 2025 9:36pm |
ruben Member Since: 04 Feb 2021 Location: ASTURIAS Posts: 216 |
I think it will be your lucky day if the dealer cooperates with that!! I insist, anyway…Good luck!! Defender 110 SE I6 D250 23MY
ExDiscovery 3 TDV6 SE |
10th Jan 2025 10:05pm |
