![]() | Home > Modifications & Maintenance (L663) > Retrofit 11.4 Pivi Display |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1443 ![]() ![]() ![]() |
You don't get the placeholder fault with the Chinese screen and no missing graphics eg the car missing on wade assist.
Thanks for the info on carplay, that would explain it as I just updated my phone to 18.4 ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Darrant1234 Member Since: 03 Nov 2024 Location: Wakefield Posts: 24 ![]() ![]() |
So with gap tool I should be ok. What screen did you get and did it come with a bracket. I’ve seen the powerful uk ones
This is the screen that I bought, it comes with everything you need, screen and bracket and then I enabled it with my IID G4 tool
https://www.aliexpress.com/item/1005007504...18022EIAtN Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Thanks for the link. Looks to be a 13 inch screen not sure if I want 13 or the 11.
