Home > Puma (Tdci) > coolant air locking
bear100
coolant air locking
i think i have an air lock issue in the coolant?
had the head gasket replaced last year which was causing the header tank to overflow after a 2 hour journey. since the gasket was done it ran ok for months, but all of a sudden it started running hot.
instead of the usual 84-87c it now runs at 94-100c.
flushed the system fitted new low temp stat but still the same except now i can only get heat in the cab when on a run, if idling no heat from the blowers. I've bled from the hose screw for days now but still the same? fitted new water pump but still the same.
The small hose from rad to tank is hot. the top right hose from rad is warm, the hose below it is cool and feels empty....no feeling of flow.
Any suggestions Bow down 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #1056143 2nd Jan 2025 5:46pm
bear100
No help? Big Cry 2023 Defender L663 V8
Post #1056861 10th Jan 2025 8:27am
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
Is the Thermostat opening at the right temperature?
Post #1056874 10th Jan 2025 10:33am
Johan_B
Sweden 2008 Defender 110 Puma 2.4 CSW Tonga Green
Don't think I have any help to offer.
I drained and filled my system 3 times this fall and followed the procedure in the WSM to the letter. You don't say but I will assume you did the same? I had no problems with airlocks.
You say it is running hot, compared to what? Isn't 94-100 C perfectly acceptable for these engines? Could it be that a lower ambient air temperature can allow higher cooling temp before fan kicks in?
Usual 84-87 C seems a bit low with a standard thermostat, doesn't it start to open at 87C and fully open at 92C? Could it be that the old one has been stuck open and you actually ran cold all the time?
Idling in the cold will always lower the temperature in the blower significantly. There's a very low flow in the heater and not much energy coming from the engine.
The hoses I will need to get out to the Land Rover to think through...
As I said, not much help. I understand you are experiencing a change of some sort and to that there should be an explanation.
Post #1056878 10th Jan 2025 11:16am
piechipsandpeas
Australia 2013 Defender 110 Puma 2.2 SW Indus Silver
Hi Bear
The top right hose is the inlet to the radiator. This will be warm but only get hot when the thermostat is open and hot coolant is then entering the radiator to be cooled, prior to this it will feel warm but not hot.
The big hose below the radiator is the return hose from the radiator outlet and will feel cool/cold until the thermostat opens and hot coolant flows through the radiator, noting that both the radiator and lower hose will always have coolant in them, just that until the thermostat opens that coolant is stationary and not doing anything. Note that even when coolant is flowing through the radiator \ the bottom hose will always feel less hot than the top hose as the radiator will be doing the thing it is designed to do (ie reduce the temp of the coolant before returning it to the engine). So don't be surprised that yours is cold and feels like there is no flow, as that will be the case while the thermostat is closed, which at the time of year where you are is quite likely, especially when idling.
The small hose to the expansion tank is there to allow the excess coolant to get back into the expansion tank as the coolant heats up and expands, so should feel hot. even if the other two aren't.
Have you tried testing the thermostat when out of the engine to see if is functioning at the correct temp?
Andy
Post #1056893 10th Jan 2025 1:00pm
Isnโ€™t there two thermostats with a different temp reading by type?
I thought I have read that before. No Guts, No Glory.
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #1056898 10th Jan 2025 1:34pm
Ianh
When I drain the coolant I do it from the oil cooler, I would do it from the fuel cooler but I donโ€™t have one on my 2.2. In addition i remove the bottom radiator hose and drain a few more litres of coolant from there. That way I know I have fully drained the system and reduced likelihood of air locks On refilling . Before draining I also turn the heater control fully to hot and remove coolant cap.
I Follow the WSM process to refill the system and have never had airlocks.
I suspect you have some air in the system, perhaps trapped in the heater matrix, so remove heater matrix hoses from heater control valve and pump some coolant into the heater matrix to see what comes out of the matrix return hose. You can modify a garden sprayer bottle to do this. Reconnect hoses, run engine and bleed any air.
Ps worth checking heater valve is operating correctly before re fitting hoses.
If this does not help you can drain again as I do, inc removing bottom rad hose, then see if that works getter for you in keeping air out of the system.
Post #1056924 10th Jan 2025 3:12pm
bear100
thanks guys, working away at the moment and struggling to find time to mess with it.
as mentioned the heaters will run hot when on a run but as soon as you come to s atop at traffic etc the heaters will blow cold not cool but cold no heat at all, even on a run the heater will go cold and i need to stop and bleed the vent.
what happened this Saturday, i went for a run it ran really well and stayed hot for much longer, when i got back and an hour or so later went to top up the coolant (loss from bleeding) the usual pressure in the tank, a little while later with the cap still off the top coolant hose was under vacuum (slightly squished with the pressure) to check i released the clamp and sure enough there was a vacuum (cap still off at this point) what would cause this? 2023 Defender L663 V8
Post #1057937 20th Jan 2025 7:41am
