![]() | Home > Puma (Tdci) > coolant air locking |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1849 ![]() ![]() ![]() |
I did mine just over a year ago, the only fiddle I found was forgetting to order new studs for the exhaust flange and trying to get the downpipes to line up with the studs in place (loosened an engine mount in the end) and mine has air con so the evaporator was in the way a bit for access - as its original and known to be a bit delicate I made a thin plywood cover for it for protection.
I'd say it was easier than the clutch and all of the polybushes I've just finished! Go for it and take your time, we can all help from the comfort of armchairs and log burners!!!!!! Keith |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1979 ![]() ![]() ![]() |
polybushes is on my list too!!
![]() thanks for the advice, I've been watching this guy, really good to be fair to him, excellent videos. doesn't look to bad, if these step by step are followed Tackling this isn't from a finance point of view but more a personal achievement, i like to do as much of the maintenance and upgrades i can with what i have on the driveway. 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
Yes watched those too - great source of info.
On the drive in south Wales in the winter? - can you collect the bits ready and do it when it gets lighter and warmer ? Or do you have a garage you can put the nose of your 110 into? Im with you on the reasons for doing it, plus you're know its been done properly. I had the clutch done 6 years or so ago by a specialist near Cheltenham, all has been good except the tunnel and floor plates were replaced by what looks like Tek screws so all of the square plastic inserts stripped, there were two cross threaded bolts on the bell housing, wiring looms weren't clipped in place and were chaffed, the cover over the transfer box lever was cracked...... Best of luck Keith |
jbcollier Member Since: 29 Apr 2024 Location: Edmonton AB Posts: 199 ![]() ![]() ![]() |
- look at videos but follow the manual religiously, especially torque sequences.
- do not guess at the angles when torquing. Use a torque wrench with angle settings (best) or an angle indicator (fiddly). - keep wearing parts in the same location and orientation (followers, etc). - do not reuse torque-to-yield bolts. - make sure you clean and blow out the threads in the block. - do not reuse gaskets or o-rings. There's a lot of them so get a kit that includes them all for the best price. - yes, head gasket thickness matters. - don't buy aftermarket parts -- by that I mean cheap, no-name stuff. Name-brand, OEM, Land Rover, or Ford. - since you are in there, reverse flush the heater core. It can make a huge difference. - same with belts, idlers, water pump, and hoses. If they are original, now is the easiest time to change them? - Ford timing chain kits are cheap. Change the sprockets, guides and tensioner, as well. - you do not need the timing tools. I bought them and ended up using drill bits and what not (see videos) instead as they worked better than what was in the kit (??!!) - thought about deleting the EGR? Easy to do it now but you'll have to get it mapped out as well. |
Well I've decided to do it myself
![]() just ordering in some bits and tools i need...angle indicator etc just thinking about head gasket thickness? what sizes are there and what to fit? when the head was done last year the head went to be skimmed but I'm now going to fit a new head so not entirely sure what thickness to fit? 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
Head gasket thickness is based on piston protrusion. As you are just changing the head, use the same spec head gasket as you have fitted now.
I think there's 3 different ones indicated by tabs - as JB says if you fit the same again, nothing is going to hit.
Ahh ok, I see! Makes sense now.
So when the head is off the existing will have a number of holes 1-3 so replace with the same m, assuming the mechanic who fitted it originally did measure it and fitted the correct one and not just the thickest one 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
If you are not sure, you could measure the piston protrusion. There's a procedure in the manual.
Johan_B Member Since: 20 Sep 2024 Location: Gothenburg Posts: 63 ![]() ![]() ![]() |
You can identify the thickness before you take the head off. There is a tab sticking out with 1-3 holes in it.
![]() Click image to enlarge ![]() You can see them over the vacuum pump in the lower image. |
Thanks, i hadn't realised that
![]() Weirdly I'm looking forward to to doing this ![]() What else should i do or replace while I'm in there? What makes are best quality/ eg head gasket kit, sealants etc? Should i reuse the original bolts or buy new? (injector stretch bolts I've got sorted) 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
I bought everything from Turners in one hit superb service & quality.
Good luck Keith |
Head bolts are also single use.
When snugging up the cam/follower carrier, got slowly, a half turn at a time. It is very common to crack the carrier. Apply oil or engine assembly lube to cams, valves and followers. Also apply oil to the timing chain. You do not want moving parts to be dry on start up. |
ordered lots of bits from Turners
![]() the front timing cover is this sealed on and if so what with? do i need a new one? it had a new one last year when the mech fitted the head gasket Thanks for the tips! 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
