Home > Puma (Tdci) > coolant air locking
Page 2 of 5 <12345>
bear100
jst, the engine performed well for 6 months after the head gasket but then suddenly started running hotter than before. Currently no gasses present after a drive just airlocked heaters
jb, I’m not getting any change of colour on the RELD test so assume there is no exhaust gas leak also no leak on the pressure test. any issues leaving the Egr cooler permanently bypassed? It’s deactivated via the remap.
Andy, I will check the little hose over the weekend, and also remove and inspect what hoses I can to check for blockages or delaminating 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #1058181 21st Jan 2025 10:46pm
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
My EGR valve and cooler are gone as I have them mapped out as well, works fine.
Post #1058190 22nd Jan 2025 2:24am
SilverPuma
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Be interested in the outcome. I have an airlock in the heater matrix I think.
Hot coolant in supply hose to heater valve (just replaced AGAIN 🤬 albeit with an RDX one) but blower cold and hose from valve rear to matrix cold. Can shine a torch through the heater valve body and only 10% full of coolant.
Be grateful for best way of unblocking as not clearing by running engine with bleed point opened / expansion tank cap off etc….. 2010 2.4 TDCI Puma Defender 90
Post #1058270 22nd Jan 2025 8:00pm
Siwynne
A vacuum purge and fill tool is less than £30 on amazon. Needs a small compressor to run but they are very effective at filling without introducing air. I have One and it’s a no fuss one hit job guaranteed to be air lock free. ( if you keep the pick up tube submerged)
Post #1058279 22nd Jan 2025 9:36pm
jbcollier
The fact your system is constantly "making air" is the concern. Mine did the same and was only resolved by a head and head gasket change. The head had micro-cracks that the shop said pressure tested just fine but I spoke with Turner and they have been selling a lot of heads so I decided to change mine as well. YMMV
Post #1058334 23rd Jan 2025 3:35pm
bear100
jb, this is what I'm thinking, initially the over pressure would happen only after at least a 2 hour run so thinking the head test would probably pass when cold. but I'm still not getting any reading on the RELD test? What's the cost of a new head?
Siwynne, ive actually got one which came with the coolant pressure test kit, might be worth a go? 2023 Defender L663 V8
Post #1058339 23rd Jan 2025 5:46pm
jbcollier
Post #1058341 23rd Jan 2025 5:52pm
bear100
not as bad as i was thinking!! Surprised 2023 Defender L663 V8
Post #1058344 23rd Jan 2025 5:55pm
jbcollier
That's what I thought. Comes with the valves/springs/etc so it is all ready to go. There are bare heads cheaper but I went with Turner as they have a good rep.
Post #1058345 23rd Jan 2025 5:58pm
jst
This is what i have eluded too and concur with. Air is being introduced some where.
What was the reason the head gasket needed tk be changed the first time? Had that issue that caused the initial failure been fixed yet? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1058397 24th Jan 2025 12:30am
jst
I think you need to bottom out the cause of the coolant loss rhe first time it happened. I have just reared the posts and can't see that rhe initial cause has been rectified.
Is it mapped? If so by who?
You can bypass the egr cooler with a piece of pipe Yes. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1058398 24th Jan 2025 12:33am
bear100
Late reply….working away again!!!
The initial symptoms were coolant cap discharging after at least a 2 hour run but other than that no other symptoms or issues on local or drivers under 2 hours, no coolant loss either. The only give away was the RELD test showing a colour change proving combustion gasses in the coolant after a hot engine.
Hence the gasket change, also blanked the Egr cooler.
Mapped by BAS around 9 years ago, BAS intercooler and silicone hoses.
Going to try bypassing the EGR cooler again and inspect as many hoses as I can this weekend 2023 Defender L663 V8
Post #1058927 29th Jan 2025 9:58pm
jst
Won't be the map then.
Looks to be same problem causing symptoms. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1058936 29th Jan 2025 11:02pm
ickle
Sounds the same as mine, pressure after 2 hours, cap didn't receive so blew the bottle and radiator.
Pulled the head off, and it was only after very carefully cleaning the chambers in the head with a scotch pad that the cracks were visible.
+1 for Turners, told me the same that they're selling loads of 2.4 heads, also that they think tuning shortens head life(?) don't forget the new glow plugs, timing chain kit, etc - be rude not to as its all apart..!
Post #1058981 30th Jan 2025 1:29pm
bear100
It’s got to be hasn’t it!
It’s had new chain kit, cover, glow plugs, turbo, water pump, vacuum pump, thermostat, coolant tank, CHT sensor…..probably forgot more!
Going to the mech next week for a look 2023 Defender L663 V8
Post #1059007 30th Jan 2025 6:51pm
Page 2 of 5 <12345>
