Home > Puma (Tdci) > Clutches - Sachs Transit 4x4, LOF, Clutchfix etc. |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3650 |
My LOF one did the same but has slowly settled down and rarely rattles the transmission now, although I had my idle adjusted up a tad which helped DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
25th Jul 2024 4:40pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20540 |
The springs on the friction plate can often be culprit, as can the gearstick selector.
In mine the LR one was broken, the nylon ball had cracked. Since then I bought a Shift R from TMD. That’s really nice, no more issues there with that never been so nice to go through the gears nice and smoothly. They aren’t cheap, but well made. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
25th Jul 2024 4:46pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4225 |
Hopefully this'll get the job done. Transit 4x4 arrived this morning.
Click image to enlarge Click image to enlarge 2007 110 TDCi Station Wagon XS |
26th Jul 2024 11:40am |
Please let us know how you get on, I really like it on mine drives nice with a good bite and low slip.
LR’s offering I never had any luck with multiple generations of them, they just got a little bit better, though some had good luck, I found they did far less miles than I’d have expected. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
26th Jul 2024 2:27pm |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3340 |
Presumably you are doing the slave etc. as well. If so I’d consider getting the pioneer4x4 clutch line. It’s a much nicer solution than the Ford junk. WARNING. This post may contain sarcasm. |
26th Jul 2024 4:01pm |
The garage is fitting and supplying everything else, it's just they haven't done a transit clutch in a Defender before so asked me to get it. 2007 110 TDCi Station Wagon XS
26th Jul 2024 4:12pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2091 |
I’m assuming the pioneer4x4 line makes it easier to bleed as the standard line goes up and down several times, allowing airlocks to be created and making it a real pig to bleed sometimes. |
26th Jul 2024 6:34pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2436 |
For those who do not care about the rattle of a non LR Puma OE spec clutch disc, you can get a Ford V8 from the 60s for peanuts. Same diameter, same splines, same height etc Puma 110" SW
26th Jul 2024 7:51pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4722 |
The gearstick can rattle. Next time you hear a rattle put your hand on the gearstick. If that stops the rattle just replace the gear stick. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
31st Jul 2024 11:04am |
I glued those vibrating weights in place years ago The noise I had was definitely from the transmission. The suggestion to me is that one of the shafts in the gearbox can rattle as well as the clutch. 2007 110 TDCi Station Wagon XS
31st Jul 2024 12:18pm |
Good idea about the weights. Just thought it was an easy thing to diagnose if you had not already tried it. 1982 88" 2.25 diesel
31st Jul 2024 12:24pm |
That is the idea of the central dumper of the original cutch disc. A very cheapo way LR avoided a DMF design. Some may say DMF is a bad idea, but they work very well in other car brands. Puma 110" SW
31st Jul 2024 12:25pm |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5877 |
Seconded....also find it very heavy on engagement. It's by no means a 'smooth, subtle, finessed' clutch. Also with you on not planning to change it, hopefully ever again. Might check gearstick just to be sure. Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
31st Jul 2024 2:47pm |
I had an original Land Rover clutch replaced with another land rover clutch and have no bother with it. 1982 88" 2.25 diesel
31st Jul 2024 2:55pm |
