Home > Puma (Tdci) > Clutches - Sachs Transit 4x4, LOF, Clutchfix etc.
Page 1 of 3 123>
Bluest
Pondering which clutch to go for:
Sachs Transit 4x4
LOF Roadspec
LOF Powerspec
Clutchfix
Any particualr reason to choose any one over the other? Are there any technical or functional differences worth considering. They look visually different to each other in their designs (particularly the Transit 4x4 one), so I'm assuming they may perform differently.
The Sachs and Clutchfix are approximately the same price, with the LOFs coming in a bit cheaper.
If I went LOF, I'm swayed toward the Powerspec as we are quite heavy when off roading, but in truth, apart from rattling the standard Ford clutch has performed as required. Are there any negatives to the heavier duty Powerspec option? They claim pedal no heavier that standard.
I know that all of the above have happy owners, but looking for some actual tangible differences in the products. 2007 110 TDCi Station Wagon XS
Post #1040629 21st Jul 2024 6:20pm
BrickBox
Find a LOF approved LR Specialist and you will have a 12 months warranty on all the LOF parts fitted.
You can go on the LOF website and they have an approved fitters map you can check. 2008 2.4 110 Utility Station Wagon XS.
Post #1040631 21st Jul 2024 6:49pm
Sachs in mine aka the Transit 4x4 clutch, it’s uprated to a good weight carrying capacity.
I’m happy with it, it feels stronger than the factory offering and isn’t heavy, slips less.
I’m pleased with it, if you have a 2.4 you can use the later 2.2 slave and associated 2.2 bleed valve etc with it. WeWillWin🇬🇧🇺🇸
Post #1040632 21st Jul 2024 7:08pm
Def90
United Kingdom 2015 Defender 90 Puma 2.2 SW Corris Grey
Hi Bluest
I fitted the Sachs Transit 4x4 clutch about six months ago, very happy with it and agree with custom90 comments.
Post #1040648 21st Jul 2024 8:20pm
Bluest
Thanks, worth knowing 2007 110 TDCi Station Wagon XS
Post #1040654 21st Jul 2024 8:35pm
Bluest
Def90 wrote:
Hi Bluest
Sounds promising. Bizarrely, Amazon of all places for a very good price. 2007 110 TDCi Station Wagon XS
Post #1040655 21st Jul 2024 8:42pm
Esben Kold
Denmark 2008 Defender 110 Puma 2.4 SW Galway Green
I replaced the original with a LOF powerspec. The pedal is not any heavier performs super smooth. I have only done 10k km’s so I do not know how it is in terms of longevity.
The parts seemed well made and in my opinion of superior quality, when compared to the original parts that came out.
Post #1040656 21st Jul 2024 8:43pm
piechipsandpeas
Australia 2013 Defender 110 Puma 2.2 SW Indus Silver
I have had an LOF Powerspec in for 3 years now. I find it is a big improvement over the original LR clutch especially off road or when loaded and towing, with it being far more tractable from stationary (no slip). I do get some rattle when in neutral which I believe is the gearbox idler shaft and due to the stiffer clutch springs.
I currently have an LOF pedal spring fitted as well, which makes the pedal lighter but not too much.
Post #1040705 22nd Jul 2024 1:31pm
Bluest
Can I just confirm, is the Sachs a straightforward bolt-in fit to the standard Defender? No other changes required? 2007 110 TDCi Station Wagon XS
Post #1040719 22nd Jul 2024 4:57pm
Yes, direct fit no problems at all just like all other options.
It suits the MT82 6speed transmission and Ford Duratorque both 2.4 and 2.2L.
(Which is the Defender Puma).
It was fitted to the Ford Transit 4x4, which had the same gearbox and engine.
Regards the Transit 4x4 and its payload etc Blackwolf on here knows more about it, but it is a heavy duty option and very good.
It’s what I have, plus the later 2.2 slave, and bleed valve etc.
I’ve just come back today from a 110 mile round trip, very pleased with it.
So the Sachs / Transit 4x4 clutch will fit straight in a 2007 to 2016 Puma no problem at all. WeWillWin🇬🇧🇺🇸
Post #1040727 22nd Jul 2024 6:18pm
Parts list which I previously saved Wink :
1x SACHS 3000 950 727 Clutch Kit.
(Fixings will be required to fit).
1x Land Rover Genuine LR068979 Concentric Slave Cylinder / Bearing. (Late Type).
3x Land Rover Genuine UYP500070 Replacement Slave Fixings.
1x Land Rover Genuine LR068981 Clutch Slave Adaptor. (Late Type).
1x Land Rover Genuine LR068982 Clutch Slave Valve. (Late Type)
1x LUK OEM Spigot bearing LR004390 (LR004390G)
1x Land Rover Genuine Crankshaft Oil Seal LR020610 (May be needed, leave alone if it is not leaking though).
https://www.autodoc.co.uk/sachs/7428173 WeWillWin🇬🇧🇺🇸
Post #1040731 22nd Jul 2024 6:35pm
Bluest
Great thanks, I've ordered the Sachs clutch. I am not fitting it as just haven't got the time and I haven't done it before. It's going into Defender specialist, hopefully next week if the clutch comes and I can sort recovery. Good point on the crank seal as it is leaking. Am having a LOF adapter shaft at the same time. 2007 110 TDCi Station Wagon XS
Post #1040733 22nd Jul 2024 6:46pm
Thumbs Up
There is the adaptor shaft yeah, mine was fine (genuine) but has always been lubed.
I have a new flywheel as well, kept safe but again wasn’t needed when mine was done. WeWillWin🇬🇧🇺🇸
Post #1040736 22nd Jul 2024 7:01pm
BrickBox
Definitely do the 2.2 Puma slave cylinder upgrade while the box is apart. 2008 2.4 110 Utility Station Wagon XS.
Post #1040964 25th Jul 2024 2:34pm
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
I have a Clutchfix HD one, maybe 12000 miles on it now, but despite not having had any really hard use it makes a rattle worse than the original when everything is hot. Seems OK when cold.
Can't say I would bother again, but having pre-emptively fitted one new HD clutch "so I wouldn't have any problems" (ha) I don't intend to take the gearbox out again to do the same. ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #1040973 25th Jul 2024 4:08pm
Page 1 of 3 123>
