Home > Modifications & Maintenance (L663) > Retrofit 11.4 Pivi Display
Page 7 of 9 <123456789>
deekay
United States
Now I'm getting the following two faults. Perhaps this just isn't meant to be...
Post #1040988 25th Jul 2024 7:24pm
mmbanf
Italy
an important question, is your screen new from the factory? or used screen?
Post #1040989 25th Jul 2024 7:27pm
deekay
United States
I purchased from Summer Auto/Zhous (Alibaba) that was referenced on page 3 of this thread.
Post #1040990 25th Jul 2024 7:29pm
mmbanf
Italy
hi Deekay, as I have written other times, buying a new factory screen from summer is a great thing, however to make the system work you have to connect the car to the Pathfinder or Topix Cloud program, the official Land Rover programs, this is necessary because it new factory screen did not load the software, and without this software it will never work…. there are guys in your area who offer this service, they also write regularly on the forum. I'm sorry I can't help you.
Marco
Post #1040992 25th Jul 2024 7:40pm
deekay
United States
Ah ha! Can't believe I missed that. I'll work on that and report back. Thank you!
Post #1040994 25th Jul 2024 7:58pm
deekay
United States
Fully functional now after a coding session with Gary @ SVS. Thanks everyone for your help!
Post #1041121 27th Jul 2024 4:11pm
stevemfr
France
This is interesting. It's a shame I didn't catch it earlier. The IIDTool can, of course, upgrade/flash the SW on an ECU. If this all that's needed, there's no need to go to a 3rd party....
Marco, did you talk to Patrick about this issue?
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s,
2 FL1s and a L663 on the way
Post #1041141 27th Jul 2024 7:52pm
mmbanf
Italy
Hi Steve, I knew about this feature, didn't think it was possible on Defender l663. I will write to Patrick, all brand new modules require flashing software, Headlights, blind spot modules, sat nav, wireless phone charging, etc... thanks Thumbs Up
Marco
Post #1041161 28th Jul 2024 6:15am
inith5
Germany
Hello Marco, I think you've looked into retrofitting the clear exit detection. Have you made any progress? 23.5MY Defender 110 D250 HSE
Post #1041169 28th Jul 2024 8:25am
Clark4x4
Spain
Hi,sorry, I’m on holidays in south of Italy and can’t follow messages 😑, happy to see retrofit is done!!
By the way, very interested in GAP tool used to upgrade/flash modules, anyone know how to do it ?
Cheers!!
Post #1041176 28th Jul 2024 9:50am
bozman
United States 1995 Defender 90 V8 Petrol SW Epsom Green
I (finally) upgraded from the 10" to the 11.4" screen over the weekend. So pleased with the ease of install, and the GAP took made it all too easy.
The screen I used was from a 2022 E-Pace, FYI.
I also swapped out the white crossbeam for a dark crossbeam at the same time.
I did need to trim the top pad about 1/2" above the screen bracket in order for the screen to sit back in its proper position, which I used a utility knife to cut. After the swap, I uploaded the new CCF, allowed the car to shutdown completely, then did a hard reset on the screen. Amazingly happy.
Post #1041278 29th Jul 2024 2:47pm
awktm
Australia
How are people modifying the top rail? Anyone have some photos or tips?
I'd rather not buy a complete new rail.
I can see Hunters modifying one in one of their videos below:
Post #1041364 30th Jul 2024 11:16am
Dannymm
I modified my top trim piece the same way with a multi tool and a metal plate to protect the trim material while cutting the plastic away.
I actually purchased a used top trim piece from a crashed V8 defender for £60 to use a template/guide to know where exactly to cut for the 11.4 screen.
Post #1041370 30th Jul 2024 12:13pm
awktm
Australia
That's great! thanks for that!
Are you happy with how you modified the rail? Does it all look ok? Did you re-glue or staple back the fabric after cutting the plastic away?
Post #1041547 1st Aug 2024 8:32am
Dannymm
I used this trim adhesive. The screen covers the newly recessed trim but it looked oem.
Post #1041555 1st Aug 2024 10:20am
