Home > Modifications & Maintenance (L663) > Retrofit 11.4 Pivi Display |
deekay Member Since: 24 Jul 2024 Location: NY Posts: 11 |
Now I'm getting the following two faults. Perhaps this just isn't meant to be...
Click image to enlarge |
25th Jul 2024 7:24pm |
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 170 |
an important question, is your screen new from the factory? or used screen?
25th Jul 2024 7:27pm |
I purchased from Summer Auto/Zhous (Alibaba) that was referenced on page 3 of this thread.
25th Jul 2024 7:29pm |
Ah ha! Can't believe I missed that. I'll work on that and report back. Thank you!
25th Jul 2024 7:58pm |
Fully functional now after a coding session with Gary @ SVS. Thanks everyone for your help!
27th Jul 2024 4:11pm |
stevemfr Member Since: 18 Sep 2022 Location: Strasbpurg Posts: 141 |
This is interesting. It's a shame I didn't catch it earlier. The IIDTool can, of course, upgrade/flash the SW on an ECU. If this all that's needed, there's no need to go to a 3rd party....
Marco, did you talk to Patrick about this issue? RRC 2Dr, RRC 4Dr, P38, and 2 L322s, 2 FL1s and a L663 on the way |
27th Jul 2024 7:52pm |
Hi Steve, I knew about this feature, didn't think it was possible on Defender l663. I will write to Patrick, all brand new modules require flashing software, Headlights, blind spot modules, sat nav, wireless phone charging, etc... thanks
Marco |
28th Jul 2024 6:15am |
inith5 Member Since: 08 Apr 2023 Location: Bavaria Posts: 30 |
Hello Marco, I think you've looked into retrofitting the clear exit detection. Have you made any progress? 23.5MY Defender 110 D250 HSE
28th Jul 2024 8:25am |
Clark4x4 Member Since: 19 Jun 2023 Location: Madrid Posts: 36 |
Hi,sorry, I’m on holidays in south of Italy and can’t follow messages 😑, happy to see retrofit is done!!
By the way, very interested in GAP tool used to upgrade/flash modules, anyone know how to do it ? Cheers!! |
28th Jul 2024 9:50am |
bozman Member Since: 10 Feb 2009 Location: Vermont Posts: 2 |
Click image to enlarge I (finally) upgraded from the 10" to the 11.4" screen over the weekend. So pleased with the ease of install, and the GAP took made it all too easy. The screen I used was from a 2022 E-Pace, FYI. I also swapped out the white crossbeam for a dark crossbeam at the same time. I did need to trim the top pad about 1/2" above the screen bracket in order for the screen to sit back in its proper position, which I used a utility knife to cut. After the swap, I uploaded the new CCF, allowed the car to shutdown completely, then did a hard reset on the screen. Amazingly happy. |
29th Jul 2024 2:47pm |
awktm Member Since: 19 Jun 2024 Location: Melbourne Posts: 14 |
How are people modifying the top rail? Anyone have some photos or tips?
I'd rather not buy a complete new rail. I can see Hunters modifying one in one of their videos below: Click image to enlarge |
30th Jul 2024 11:16am |
Dannymm Member Since: 28 Jun 2024 Location: Wiltshire Posts: 18 |
I modified my top trim piece the same way with a multi tool and a metal plate to protect the trim material while cutting the plastic away.
I actually purchased a used top trim piece from a crashed V8 defender for £60 to use a template/guide to know where exactly to cut for the 11.4 screen. Click image to enlarge |
30th Jul 2024 12:13pm |
That's great! thanks for that!
Are you happy with how you modified the rail? Does it all look ok? Did you re-glue or staple back the fabric after cutting the plastic away? |
1st Aug 2024 8:32am |
I used this trim adhesive. The screen covers the newly recessed trim but it looked oem.
1st Aug 2024 10:20am |
