Home > Maintenance & Modifications > Corrosion Prevention Guide! |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5006 |
It's a long answer since 2011, see page 1 🤣 Provides a guide for chassis and body. Dinitrol & ACF-50.
5th Jun 2024 9:22am |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 469 |
I would'nt use any wet waxes on anything other than brand new components it just makes things far worse and is a pain to remove later for a effective solution. Keep with Buzzweld coatings or similar and leave the wet waxes for "Swiss Tony" |
5th Jun 2024 11:05am |
What "wet waxes" are you referring to (never heard that term) and which Buzzweld product/s ("or similar" as you say), do you mean?
5th Jun 2024 7:01pm |
These rust like crazy. Best to do them from new like this one... in Dinitrol clear coat.
Click image to enlarge Now treat and protected for years... Click image to enlarge This is a very nice 21 plate, 3 year old example. Click image to enlarge BUT this is what is looks like 3 years on with ordinary road use in the South, not the North and not near the sea. If only everyone would get brand new cars done it would save so much rot, costs and problems in only a few years... not to mention the loss of value and life expectancy. Click image to enlarge EDIT. Now done, BETTER! Clear coat and smart black Dinitrol. The brown bit is the exhaust top left of pic. Click image to enlarge Last edited by Zagato on 2nd Jul 2024 12:02pm. Edited 1 time in total |
30th Jun 2024 11:25am |
This all the way from Scotland to West Sussex and then a flight home. The reverse to pick up. Nicest fella you will ever meet despite 12 hours journeys...
Click image to enlarge Still specialising in Supras and now SAABs... Click image to enlarge My own coming on nicely.... Click image to enlarge |
30th Jun 2024 5:22pm |
Nice example...
Click image to enlarge Something different and done just in time... Click image to enlarge Quite a bit of corrosion on the underside but now looks VERY smart close up Click image to enlarge |
30th Jun 2024 5:28pm |
Father and sons Defenders
30th Jun 2024 5:33pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10661 |
Thanks for the great selection there, i'm loving the RS 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
1st Jul 2024 9:23pm |
Another selection...
Click image to enlarge Click image to enlarge Alpha 156 GTA... a mint Japanese import that some idiot garage has sprayed Lanoguard all underneath and made all the previous underseal gloopy. Looks like it has a massive oil leak now. People... Lanoguard is just a glue, of course it won,t stop rust. It's just a massive marketing exercise and easy for the average Joe to apply and get that feel good factor! You have to address the rust first not just cover it Click image to enlarge Click image to enlarge |
16th Jul 2024 7:58am |
WOW what a selection of vehicle's your having, liking the 300ZX, don't see to many of them 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
20th Jul 2024 11:55am |
MartinB Member Since: 20 Jul 2024 Location: Sutton-in-Ashfield Posts: 2 |
Hi,
First time on the forum, but how I wish I had found the anti-corrosion guide ten years ago, but I am asking for help. Cleaning out the back of the Defender I noticed galvanic corrosion around the rear seat mounts (white powder and slime)., with a couple of small holes going all of the way through the top of the inner wing. Moving underneath, I have found galvanic corrosion in the aluminium along the top edge of the stiffener. See photo. My first thought is to remove the five rivet holding the top of the stiffener and insert an aluminium strip along its full length to cover the corrosion. The strip will be held in place with suitable adhesive and the re-riveted stiffener. Second option is to add a full length plate on the inside of the vehicle. After painting, the back of the stiffener is to be flooded with Waxoyl. Which is the best option? Has anyone else had this problem? If so how did you solve it? Thank you. |
22nd Jul 2024 9:49pm |
Beco90 Member Since: 10 Jul 2024 Location: South Wales Posts: 6 |
You could try looking at YRM, they have a range of gaskets and takes you can use to isolate the aluminium bodywork from any steel to try and help prevent the bimetallic corrosion occurring. E.g.:
https://yrmit.co.uk/vehicle/land-rover-def...s-gaskets/ |
29th Jul 2024 9:21pm |
Hi Beco90,
Thanks for the tip. Good prices too. Pity Land Rover didn't spent an extra £20 and include some of these in the original build |
31st Jul 2024 10:06pm |
Two very nice Defenders that have been well looked after. A 2011 from Worcester and a 2007 TD5 from Cornwall. The latter was bought when it was a couple of years old and is probably worth 5K more now from what the owner paid. Pretty good, free motoring almost in one respect!
16th Aug 2024 9:15am |
