Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
brucehun Member Since: 04 Dec 2012 Location: Johannesburg Posts: 24 |
All options now working.
18th Oct 2023 7:37am |
hcarranzacr Member Since: 19 Oct 2023 Location: San Jose Posts: 6 |
Hi atldef110 I did you setup, but i didn't know how to activated o used to use parking assist mode? When I change - MultiCAN-786 Park Assist Standard: Not Fitted Change to: Full Auto VarD (Fully automated park assist with automated steering breaking accelaration and gears) - Collision alert is disable, any idea Last edited by hcarranzacr on 19th Oct 2023 4:50am. Edited 1 time in total |
19th Oct 2023 1:33am |
------ Hi I have same issue, did you found any solution o workaround best regards |
19th Oct 2023 5:46am |
My P400 have this parameters from factory (3000 MHEV) • MultiCAN-580 GenericEngPwrOut Standard high power engine variant • MultiCAN-599 EnginePowerOutput Engine Power Source - 400/550 but is P400 |
19th Oct 2023 8:04am |
OHRT Member Since: 21 Sep 2023 Location: Ohio Posts: 2 |
How did you get ACC to work? Or are you using it with the errors? |
19th Oct 2023 10:48pm |
@OHRT...My Def has ACC as standard.
20th Oct 2023 11:40am |
DefenderMidlands Member Since: 08 Mar 2023 Location: West Midlands Posts: 223 |
My D250 engine settings are
• MultiCAN-580 GenericEngPwrOut Standard mid power engine variant • MultiCAN-599 EnginePowerOutput Engine Power Source - 249/365 |
20th Oct 2023 1:32pm |
Activity key won’t lock or unlock if approach and walk away lock/unlock are activated
20th Oct 2023 1:37pm |
I found that if I change speed limit I get a error faumous error "Emergency break error" i change to 210 and 250 and in boot I get the same error, went set to default value the issue is solve
• MultiCAN-564 MaxVehicleSpeed LIMIT_191_KPH |
20th Oct 2023 6:18pm |
What power settings does anyone have for a D300? Can anyone upload their ccf file from a d300?
20th Oct 2023 6:52pm |
roccobarocco Member Since: 27 Jun 2023 Location: Ulm Posts: 11 |
Yes, same here. I did the same modification, same error, still wanted to know if it works, went on the Autobahn, it works, however, fault remains. Tried on Disco5 D300. |
20th Oct 2023 7:58pm |
malibu Member Since: 11 Sep 2023 Location: Melbourne Posts: 49 |
I am looking at options to activate the following;
1. ATPC 2. TR 2 (Auto) 3. Parking assist I am woundering if I use the GAP tool to configure the CCF and then find a mechanic with Pathfinder to relearn the DADC module. I know that GAP will sort this out, but I am not sure how long they will take and was keen to get these items working before Christams so I can enjoy the features. Is this likely to work? |
23rd Oct 2023 5:12am |
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 161 |
hi, atpc and tr2, it will work for sure, learn DADC central configuration, and restart gateway, automatic parking I don't think so, there are many shadows on the procedure, it may be necessary to reprogram some ecu.
Cheers Marco |
23rd Oct 2023 5:39am |
are there any economic ways to access PathFinder for a few hours?
23rd Oct 2023 5:53am |
