Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 60 of 110 <123 ... 596061 ... 108109110>
DefenderMidlands
I think the engine output is only software changes to the ccf files. Maybe additional files need to also be changed
Post #1010379 7th Oct 2023 10:58am
carltb
 2015 Defender 110 Puma 2.4 DCPU Corris Grey
So the car was back to normal this morning so I tried again to activate dynamic mode. Did it correctly locking car and waiting and then rebooting the pivi. This worked and I got the dynamic function and menu. However there was something off with the car. I went for an hour long drive and it was mainly the rpms that seemed high. Regardless of drive mode. At my destination I restored the ccf to stock. Drove back and all worked fine.
The rpms was over 3000 at 140kmh after the ccf change. Compared to 2500 when restored. Both in Comfort mode. Quite odd.
Anyone else experienced something similar?
I know the car got an update or patch or something concerning the drivetrain just before delivery a week ago that was released that same day. There will apparently be a recall or whatever it’s called regarding all p400e to get this update. Could this be related?
Won’t be doing anymore tinkering with the ccf in my car for now anyway. 😐
Post #1010416 7th Oct 2023 5:47pm
lightning
Yes l would definitely stop trying to activate "Dynamic" mode as your Defender clearly doesn't like it.
Nothing to stop you doing some of the other changes that are possible though.
Post #1010459 7th Oct 2023 10:30pm
malibu
Australia
``mmbanf wrote:
atldef110 wrote:
I found a new feature today
- Activate Park Assist
EUCD-059 Parking Assistance
Standard: Without Parking Assistance
Change to: PDC (Front, Rear) - Parking (Parallel, Exit)
EUCD-099 Park Assist Camera
Standard: Without Park Assist Camera
Change to: With Park Assist Camera
EUCD-140 Pdcautoactivationmenu
Standard: Not supported
Change to: With PDC Auto Activation menu
MultiCAN-469 PDCAutoActivation
Standard: Not Supported
Change to: Default OFF configurable
MultiCAN-500 PDCBtnFCIM
Change to: Fitted
MultiCAN-602 PDC
Standard: PDC not fitted
Change to: 10 Channel fitted ( Park Assist)
MultiCAN-786 Park Assist
Standard: Not Fitted
Change to: Full Auto VarD (Fully automated park assist with automated steering breaking accelaration and gears)
Have anybody able to activate Adaptive Cruise Control yet? Can anyone with ACC send me their CCF?
hi, very interesting!! thanks for sharing. have you tried this and it works without errors? Thumbs Up
I tried the parking assist the weekend. It worked perfectly, as in, the car finds parking spots and parks itself. Amazing. Yes I also get the brake warning and 2wd warning. Interesting, when I reset all the settings and restarted the car, everything worked perfectly with no warning, and park assist, until the next restart and then park assist disappeared.
I suspect when GAP work out the ACC, all the other options, such as ATPC, TR2 and Park assist will all work at once.
Post #1010574 8th Oct 2023 11:12pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
With regards to Park Assist I notice that LR Chip, which have just started offering activations in the UK, have the park assist option as coming soon so it may not be straightforward doing it via Pathfinder also Confused Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1011148 13th Oct 2023 4:45pm
TCOV
United States
Re: Problem with MY2024 CCF file
Philipp1601 wrote:
I a new owner of a IID-Tool BT I bought from ExpeditionParts in Germany.
The IID-Tool BT was delivered today, I updated it to 4.00.00 build 3034.
The car is brand new, too. It is a 2024 Defender 110 D250 XS.
btw:
There are some problems with activating the „inControl“ service of the car, the dealer is trying to find out with LR. So the car is not yet activated. It seems this is not the only car that does not activate, the activation procedure was changed, there is a problem with LR.
In the meantime I tried to code the CCF file to unlock some features. I started with one of the simpler ones:
I tried to activate the wifi hotspot by
MultiCAN-814 IVIWiFiHotspot
Standard: Not fitted
Changed to: Internal WiFi Hotspot fitted
When I tried to upload the changes to the car it said:
„CCF version not yet supported“
and the app fell back to the main menu. Any other CCF-change ends the same.
Can one of you help me with the problem?
Is anybody else suffering the activation problems with LR?
Thank you
Philipp
Did Patrick get back to you on how to resolve? I am receiving the same message. Just picked up my2024 110 P400 Xdynamic SE. I am also having the same issue with incontrol.
Post #1011181 13th Oct 2023 10:52pm
Hairy Dan
Make sure you are using the latest version of the app and make sure you have updated your firmware on the tool to the latest version, if the problem persists drop Patrick a line at gapteam@gap-diagnostic.com although it may be Monday before you get a reply Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #1011183 13th Oct 2023 10:59pm
BruceT
South Africa
Just received mine from Steve (thank you for all the help Steve) and just wanted to thank everyone on this thread for their contributions. It’s already helped me change a few settings.
It will definitely be traveling with me on my adventures. "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
11MY Defender 130
23MY Defender 110 D300 HSE X-Dynamic
https://www.youtube.com/channel/UCzrHKcjA-LJ470_H4QwPgVA
Post #1011217 14th Oct 2023 6:32pm
vcrabz
Czech Republic
can somebody with defender MY24 please post full CCF? thx
Post #1011219 14th Oct 2023 6:36pm
adnan_u88
I had the same issue for MY24 - CCF Version Not Yet supported. Once I changed to beta firmware (build 3509) it seemed to work okay.
Since then there has been a Pivi update, just tried to make some other ccf changes today and its failing to upload the ccf changes. May need to change the firmware again?
Post #1011233 14th Oct 2023 8:21pm
Philipp1601
Germany
Patrick helped me with my CCF upload problem.
It was solved by using the last beta and to have the car in a state with ignition on but engine off.
Incontrol was solved by JLR, too.
Unfortunately they reset the whole car again. So I lost my third party activated ACC again and had to reactivate it. So try to have the car fully incontrol activated before changing CCfs.
One of the problems was that I wanted to use my standard email account which is related to my web hosting account with ionos.de.
I had to use my iCloud account for incontrol to work. Greetings
Philipp
MY24 Defender 110 XS-Edition D250 Stealth Mod
MY07 VW Multivan T5 Sport Edition D5
MY12 Mini R55 Cooper Works
MY00 MB SLK 320 R170 Designo
MY21 KTM 690 SMC-R
Post #1011285 15th Oct 2023 11:06am
brucehun
South Africa 2003 Defender 110 Td5 DCPU Java Black
Gap tool
I received my gap tool and set up with no issues.
Ccf I changed which don’t work on ‘23 110 HSE although enabled:
1. Wifi hotspot
2. Stop/start
3. Tow assist 2
Dynamic mode, configurable TR, seatbelt reminder all good.
Post #1011563 17th Oct 2023 3:30pm
DefenderMidlands
They should work after a few reboots of pivi pro and restarts of car / lock and allow car to sleep
Post #1011566 17th Oct 2023 4:02pm
brucehun
Thanks, will try that
Post #1011572 17th Oct 2023 4:32pm
mmbanf
Italy
Hi everyone,
I've already done the experiment...
the vxdiag vcx +hdd jlr data tool works for the basic characteristics of the vehicle, for example I managed to calibrate the headlights after updating the matrix, then you can bleed the brakes with the guided procedure, many small things.
but don't talk about ccf, being an offline connection it doesn't read vbf files, so no ccf editor........
I bought it because I use it and I have it. very happy with the gap tool, given the difficulties in activating acc and tr2, I wanted pathfinder to work on the DADC ecu and be able to set: learn central configuration, on the ecu functions.
unfortunately vxdiag doesn't let you access the ecu functions, so nothing new. Big Cry Big Cry Big Cry
Post #1011575 17th Oct 2023 6:07pm
