![]() | Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 174 ![]() ![]() |
write me in pm
Ratledge Member Since: 17 Jun 2023 Location: Murchison NC Posts: 28 ![]() ![]() ![]() |
As far as the speed limiter, I fail to see why anyone needs their Defender to go 143mph much less 170. Are we running from the popo?
atldef110 Member Since: 01 Oct 2023 Location: Atlanta Posts: 11 ![]() ![]() |
Hi hcarranzacr That didn't happen to me. When I made all the changes for park assist, I only got the "Emergency Break Error". After activating the party assist with your GAP tool, you just need to slow down below 18 mph. Alternatively you can activate Park Assist via the Touchscreen. You also use the button to choose which mode you need, Parallel Park, Perpendicular Park or Parking Exit and to switch the system off. Here you can find more information about it. https://www.landrover.com/ownership/incont...tem%20off. |
aajr Member Since: 18 Dec 2022 Location: San Diego Posts: 42 ![]() ![]() |
atldef110
I am a bit confused. Were you able to permanently clear the error message? In other words, have you been able to activate park assist and use it without any error codes? Your note seems to me to imply that you still have the error code, but I'm not sure. |
Hi aajr,
Sorry for the confusion. I was not able to use it without errors. After activating the Park Assist, the feature works fine and it does what it supposed to do, however I get the famous error message "Emergency Brake Assist Not Available". I hope that helps |
G4R1 Member Since: 17 Aug 2020 Location: Barnet/Limassol Posts: 131 ![]() ![]() |
I was wondering if anyone came across of activation of the Air Quality Sensor?
I believe it can be retrofitted also it looks like this is only available on 11.4-inch screen. ![]() Click image to enlarge 3.0L MHVE D200 S Pangea Green+Black Pack Adv. + Off-Road and Family Packs |
DefenderMidlands Member Since: 08 Mar 2023 Location: West Midlands Posts: 252 ![]() ![]() |
I have this on the smaller screen
Ohh, that's interesting. What is MY of your defender? Mine is MY 21 and I have a smaller screen and there is no Air Quality screen.
I'm trying to figure out if this can be activated as I already have cabin air ionisation with pm2.5 filter so I believe this menu screen can be activated. Is the any chance you could share a photo of the Air Quality screen on a smaller screen? 3.0L MHVE D200 S Pangea Green+Black Pack Adv. + Off-Road and Family Packs |
Mine is MY23 and I had the family pack which added the 7 seats, 3 zone climate, air quality etc
Thank you for the clarification! I have the family pack with 7 seats and 3 zone climate too. But air quality seems something new that is probably only available on newer vehicles. 3.0L MHVE D200 S Pangea Green+Black Pack
Possibly could activate it with the GAP tool, this might be a start
• EUCD-150 Air Quality Sensor With Air Quality Sensor MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar |
Pauljm Member Since: 25 Oct 2023 Location: Sydney Posts: 8 ![]() ![]() |
I set this to as I have 285x45r22 instead of 265x45r22 & the rolling diameter is bigger now 32.1
More accurate speed reading MultiCAN-838 from: Speedo market 0- 3.5% + 2kph To Speedo market 1- 2.0% + 0kph When I set cruise control to 80 kph it does like 76 only. It gets worse the faster u go. Anyone know why? It was teading low anyway? |
I've got that option & 8m pretty sure it's an extra filter under the steering wheel there is a youtude that shows how to change it. Guess you could see if the filter holder is there. |
sullivan1337 Member Since: 24 Oct 2023 Location: Pittsburgh Posts: 8 ![]() ![]() |
How were you able to get the beta build? I'm on build 3034 and getting this same error on my new MY24. |
