Home > Modifications & Maintenance (L663) > Retrofit 11.4 Pivi Display
Page 1 of 10 12345678910>
Clark4x4
Spain
After clearsight retrofit I found this on CCF files:
I really like bigger screen, so... started to investigate about connectors used, pin's, etc...
At the same time found display and plastic trims on ebay...
I spend lot of time to build connector, specially second conector to use pins from current connector.
Grey connector to new screen is this one:
JAE ELECTRONICS / MX34012SF1
pins M34S75C4F1 (I buy also pins f2 and F3, just in case)
And for second connector, to use current pins, this one is valid:
BMW 61132359994 61136925611 (blue/green in picture, found on ebay)
And yes, I buy a lot of diferent connectors because I was not sure wich one is valid Laughing
let's go...
Reach some screws are quite difficult... better have long torx screw drivers!!!
And finally after some panic moments, blank screen after change CCF MultiCAN 641... solved with hard reset of Pivi (hold buttond around 10 seconds)
Done!!!!
Need to put everthing in place (not easy), and another retrofit done.
Post #1006248 2nd Sep 2023 11:31am
Clark4x4
Spain
oh, important, change of pins positions from old connector to new one...
Post #1006250 2nd Sep 2023 11:36am
walfy
Was it a brand new screen? I thought they were coded to the car. 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #1006255 2nd Sep 2023 12:44pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
Brilliant job Clark4x4 Bow down It's a retrofit I would like to do if I can find all the bits cheap enough Thumbs Up Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1006257 2nd Sep 2023 1:02pm
aajr
United States
Clark4x4
I have the big screen from factory, but I must say that this is a brilliant post with all of the information one might need to make the upgrade. Well done!
Post #1006261 2nd Sep 2023 2:44pm
Clark4x4
Spain
I bought on eBay, used
Post #1006263 2nd Sep 2023 3:14pm
mmbanf
Italy
Hello, Clark,
congratulations, great work, thanks for the many useful information. Thumbs Up
Marco
Post #1006314 3rd Sep 2023 9:02am
Moo
Ukraine
Shocked I can now understand why the retro fit is so expensive from third party providers.
Great effort, but I'm happy with the smaller screen. Thumbs Up Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1006316 3rd Sep 2023 9:16am
J77
Hats off for doing it but it seems a huge effort for not a lot of benefit over the small screen. 24MY 90 D250 HSE, Tasman Blue
Post #1006320 3rd Sep 2023 10:06am
ckamps
United States
Great write up!
Would you be willing to produce and sell the wiring harness adapters?
Do you have any advice as to which eBay country sites might offer the best chance to find second hand screens?
In another forum, it was mentioned that Land Rover tools are required to enable the 11.4” screen. Based on your experience it appears that you only needed the Gap IID tool to accomplish necessary coding. Is that correct?
Post #1007314 12th Sep 2023 3:30am
Clark4x4
Spain
Hi,
well drop me a PM and I try to help you with connector, I got some spare pieces to built at least another set...
I found all pieces in ebay UK, from a damaged vehicle, in a very good conditions. I guest the key is be aware or setup an automatic search. Be aware that Jaguar use same display... i.e. all these references are valid:
T2H42943, T2H42943, MX6319C279AE, LR144528, T2R72241
I got under my radar this unit at good price (all plastic trims need to be buyed), but not sure about this page:
https://used.lr.parts/product/t2h42943-tou...2017-used/
or you could ask your LR dealer, but will be expensive Confused
And yes, with GAP IID tool is enough!!!
Post #1007448 13th Sep 2023 6:15am
ckamps
United States
H Clark4x4, can you PM me? I cannot PM you due to me not having enough posts. Sad Thanks!
Post #1007669 14th Sep 2023 11:43pm
Hairy Dan
I'm sure you only need 3 posts to be able to use PM's so how's the weather in Missouri? Whistle Laughing Cheers Ian
Kielder 4x4 Safari
Post #1007755 15th Sep 2023 6:52pm
ckamps
United States
Hah! Funny guy. Best time of year 70F, low humidity, and sunny.
Post #1007773 15th Sep 2023 10:28pm
Vidoq
Qatar
Sorry for not starting the new thread, I have an issue while retrofitting 11.6 inch screen.
Once I install it and changed the ccf to 11.6 alpine, I found on the screen - placeholder images.
Did u face the same issue?
Does anyone know how to get rid of them?
Post #1010165 5th Oct 2023 1:36pm
