![]() | Home > Tdi > TDI 200 Fuel Injector Pump |
Ok. I have never done this, but what I can tell you is that this is the same injection pump (VE Bosch pump) that was fitted to late 80s and 90s Dodge Rams and a host of other cummins powered vehicles. So, an injection pump specialist on your side of the pond will be able to advise you.
The alternative is to drop Mike at Britannica Restorations (Montreal) a line as he has decades of experience with these pumps and is almost in your timezone. Hope that helps. |
cykoh85 Member Since: 25 Apr 2022 Location: Selangor Posts: 143 ![]() ![]() ![]() |
Hi geobloke
Thank you for your message and advice. Oh, I know Mike - the YouTuber, hehe... I always learn from there and love his videos. |
Sorry
![]() ![]() ![]() Yes Mike is excellent ![]() |
hehehe
![]() ![]() ![]() thank you bro ![]() |
No problem
Yes
![]() By the way, I have dropped Mike an email. |
Been there done that
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3528 ![]() ![]() ![]() |
Just returned from Selangor/Jahor, and damn the bathroom scale is reading wrong 🤣 kept an open eye for a classic Defender, seen the new one thou.
Sorry not knowledgeable about those injection pump, but I think that part adjusts the pump timing. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Wah, that was nice. ![]() ![]() |
Hi Dinnu, are you in Malaysia? hahaha, anyway, classic defender is the best. ![]() It is okay, I received a reply from Mike. I will share it here. ![]() |
Changing the O ring will not affect the settings – do not back the pump head right off and if at all possible mount the pump vertical to avoid dropping and parts internally – there are a few tiny parts in there!
Best get Bosch original parts – do it once – do it right! Mike thank you for brother Mike. ![]() |
Ah yes well done and a great reply from Mike. Top bloke
hehehe...
By the way, do you have any idea about this part (as shown as attached photo)? Located at upper main gear box. ![]() Click image to enlarge |
I believe it is something like an extension for the reverse selector rod. Should be a small oval gasket between the two components. LT77s box if it is the original 200tdi gearbox.
