![]() | Home > Maintenance & Modifications > New Topic Name: Trailing Arms bush removal DONE!!!!! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20719 ![]() ![]() |
D44 do some nice ones as well, but they are more competition spec. WeWillWin🇬🇧🇺🇸
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 813 ![]() ![]() ![]() |
I'd suggest you haven't quite cut through the bush...... But you're nearly there 👍🏼
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5855 ![]() ![]() |
What he said.
Cut deeper. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8207 ![]() ![]() ![]() |
this is the method i use, either in a vice or hit with a sledge hammer (prior to getting a press) dont expect to use the impact socket again after the sledge method. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5889 ![]() ![]() ![]() |
JST, I’ve got some redundant sockets around that I can afford to lose. I don’t have a vice, so if I used the sledge technique, what do I do it against? The ground? Concrete? I’m trying heat next. See where that gets me. But once this side is out, I’m taking the other straight to the garage. Really annoying as all parts (including the a-frame ball joint) are ready to put back in and I’ll need the Def for a (potentially snowy) drive up to 2000m on Sat am. Need it done by then.
![]() ![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
Nope, no vice. What if I push reeeealy hard? ![]() Going for the heat, cut and chisel (more) technique first. Then might do some bish, bash, bosh over lunch… ![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
Done. TFFT. Going to take the other arm to a garage.
![]() Thanks again everyone. Once again, Def2 members come up trumps. ![]() ![]() Click image to enlarge ![]() Click image to enlarge Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5929 ![]() ![]() ![]() |
One done, same to the other and save garage costs
![]() good luck 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Shafski Member Since: 19 Jun 2023 Location: Chilterns Posts: 119 ![]() ![]() ![]() |
Second ones always the easier one! You’ll be fine
![]() _________________________________________ 2015 110 Montalcino Red Utility "Harriet" along with Puma on I.C.E |
Yeah, you've done the learning bit, second one will be a piece of cake... Buy something else with the money you save from garage cost 😉
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1237 ![]() ![]() ![]() |
A hydraulic press Ed
82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
revd Member Since: 20 Apr 2024 Location: England Posts: 220 ![]() ![]() |
I’ve got a pal with a 100 ton press lined up for bush swaps, hoping not to need anything larger 😂
Never had anything need more than about 7t and that was to disintegrate an L322 wheel bearing. A bit of thin oil, particularly when it starts moving makes things a lot easier. Ed
Well, the first took 2-3hrs to get out. The second 20mins.
![]() ![]() ![]() Glad I didn’t take it to a garage. ![]() Another question. I’ve got standard replacement bushes (the version with two metal tubes with rubber sandwiched in between), but I’m wondering about a polybush version. What brand would anyone recommend? ![]() Click image to enlarge Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
