![]() | Home > General & Technical (L663) > Gap Diagnostic Tool Activations for IID 4 tool + other items |
sasa Member Since: 05 Mar 2024 Location: ceska lipa Posts: 59 ![]() ![]() |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6657 ![]() ![]() ![]() |
DefenderMidlands Member Since: 08 Mar 2023 Location: West Midlands Posts: 255 ![]() ![]() |
***Starred item Requires GAP IID Tool G4 to activate Will throw up an error with GAP IID G3 version of the tool***
ALSO MAKE SURE THE G4 TOOL IS UPDATED TO THE LATEST FIRMWARE VERSION VIA USB CABLE ON YOUR PC/MAC ***ACC ADAPTIVE CRUISE CONTROL (ACC) MultiCAN-580 PTCruiseFitment: ACC with Queue Assist fitted MultiCAN-712 ACC Lead Car Distance Display: Fitted MultiCAN-809 ACC Stop Gap Setting: Fitted ***ALL TERRAIN PROGRESS CONTROL (ATPC) MultiCAN-476 ATPC Original: HDC Change to : HDC and LSPC No warnings, no loss of other functionality. 15 min wait required, no Pivi reset. ***CONFIGURABLE TERRAIN RESPONSE (TR2) MultiCAN-736 Config TR Fitment - Not Configured > change to Off Road Configuration MultiCAN-755 Config TR Mode - Not available for selection > change to Available for selection with timeout MultiCAN-797 Ter CT Select In FCPB Change to "Rotary used for selection within touch CHAUFFEUR MODE ENABLE MY24 ONWARDS ONLY MultiCAN-665 ChaffeurMode Fitted MultiCAN-853 TS Sec Seat Movement Touch Screen Control of Secondary Seat Movement - Fitted STARTUP ON AUTO TERRAIN RESPONSE MultiCAN-476 ATPC Was HDC only Is HDC and LSPC MultiCAN-696 ATCM Auto TR Mode Switch Was Auto Terrain Response Mode selection switch not fitted Is Auto Terrain Response Mode selection switch fitted MultiCAN-736 Config TR Fitment Was Not Configured Is Off Road Configuration MultiCAN-754 Auto TR Prog Mode Was Not fitted Is Fitted MultiCAN-755 Config TR Mode Was Not available for selection Is Available for selection with timeout MultiCAN-778 ATPC Select In FCPB Was Control interface not available in FCPB Is Available as shared purpose button MultiCAN-778 Ter Auto Select In FCPB Was Control interface not available in FCPB Is Rotary used for selection within touch screen MultiCAN-789 Drive Mode Order Was All Terain Vehicle Standard Order Is AlI Terrain Vehicle Including Auto Order MultiCAN-797 Ter CT Select In FCPB Was Control interface not available in FCPB Is Rotary used for selection within touch screen MultiCAN-798 Ter CP Select In FCPB Was Control interface not available in FCPB Is Rotary used for selection within touch screen MultiCAN-853 ATPC Button Type Was Not fitted Is Hard Button Fitted REMEMBER AUTO STOP/ START LAST SETTING MultiCAN-566 MHLastUserMode Last user memory mode disabled Last user memory mode enabled ACCURATE SPEEDOMETER MultiCAN-838 Speedo Market Market 0 (+3.5% +2km/h) Market 1 (+2%) You also have to have all these 3 setting to match MultiCAN - 838 Speedo Market MultiCAN - 577 SpdoCalPercentScale MultiCAN -575 SpdoCalkmhOffset FOGLIGHTS SHUT OFF WHEN TRAILER IS CONNECTED, ONLY TRAILER FOGLIGHTS ARE RUNNING EUCD-019 Rear Foglight Tow Function Not supported EUCD-020 Trailer Module Not supported Trailer Module 13-pos socket ENABLE BOTH FRONT MICROPHONES EUCD-126 Microphone Microphone (Driver Only) Front microphones RESET SERVICE OIL WARNING Service/Test -> IPC-Instrument Pack -> Service Interval Reset STOP DRIVER ASSISTANCE RESETTING TO HIGH MultiCAN-889 GSR2 EU Market Ft Change it to Non GSR2 Country ACTIVATE WIFI/WLAN HOTSPOT MultiCAN-814 IVIWiFiHotspot Standard: Not fitted Changed to: Internal WiFi Hotspot fitted CHANGE SPLASH SCREEN TO "Defender 007 EUCD-205 Racing Sub Brand Standard: Mainstream Vehicle Changed to: LTD 007 DYNAMIC MODE Most cars will then have red dials and red interior lights when dynamic mode is selected EUCD-129 Terrain Response Fitment, Set to "Auto Terrain Response Dynamic & Configurable Dynamic Mode" EUCD-245 Dynamic-I Standard: Dynamic-i Not Fitted Changed to: Dynamic-i Content with Configurable Dynamic Mode Screen MultiCAN-562 DynamicProgMode Standard: Not available for selection Changed to: Available for selection without timeout Other possible value: Available for selection with timeout MultiCAN-605 ConfigDynamicMode Standard: Not Fitted Changed to: Fitted MultiCAN-777 Ter Dyn Select In FCPB Standard: Control interface not available in FCPB Changed to: Rotary used for selection within touch screen WALK AWAY LOCKING MultiCAN-505 Change it to Current: Enabled Possibly only works on cars without locking fuel cap or MY25 onwards APPROACH UNLOCKING MultiCAN-807 Approach Unlocking Disabled Change to Enabled Possibly only works on cars without locking fuel cap or MY25 onwards MODIFY SIGNATURE LEDS BEHAVIOUR MultiCAN-463 DRLBehWhilstDIsAct Current: Turn Off New: No Action MultiCAN-465 DRLBehWhHazardsAct Current: Turn Off New: No Action This setting is to keep them on while the turn signals or hazard lights are operating ENABLE SUBWOOFER The subwoofer was installed in the base model, but wasn't enabled EUCD-121 Subwoofer Standard: Without Subwoofer Changed to: Subwoofer ENABLE ALL MICROPHONES EUCD-126 Microphone = Four Microphones (Two Front & Two Rear) Standard: Microphone (Driver Only) DISABLE SEATBELT REMINDER MultiCAN-717 Front Belt Minder Beltminder Fully OFF MultiCAN-737 Rear Belt Minder Rear Beltminder OFF REAR DOOR POPS OPEN FROM BUTTON ON KEY FOB MultiCAN-770 Remote Release Tailgate Enabled GLOBAL OPEN AND CLOSE MultiCAN-723 Gloabal open/close MultiCAN 723 SMRF Global Close - changed to Enabled MulitCAN 719 CDL Global Close - changed to Enabled MultiCAN 719 CDL Global Open - changed to Enabled EUCD 184 Global Open/Close - changed to Global Open/Close Doors + Sunroof DISABLE DRIVE AWAY LOCKING MultiCAN-740 Drive Away Door Lock to Disabled - To disable drive away locking FOGLIGHTS WITH HIGHBEAM EUCD-018 Foglight Function Foglight without restrictions MultiCAN-734 Front Fog Lights Oft High Beam Set to Disable. MORE ACCURATE SPEED READINGS MultiCAN-838 from: Speedo market 0- 3.5% + 2kph To Speedo market 1- 2.0% + 0kph TOW ASSIST2 MultiCAN-579 Tow Assist Set to Tow Assist 2 MultiCAN-635 Towing Set to Not Support if not already set to this setting. MultiCAN-696 ATCM TA2 Switch Set to Tow Assist 2 feature selection switch not fitted, again if not already set to this. MultiCAN-793 TA2 Input Control Set to HVAC rotary. MultiCAN-795 TA2 Select in FCPB Set to Rotary used for selection within touch screen. AFTER RETROFITTING 11.4" DISPLAY MultiCAN-641 FrntUpperDispVariant Alpine 11.6 inch Single View Clarke4x4's thread on fitting larger screen https://www.defender2.net/forum/topic89297.html AFTER RETROFITTING CLEARSIGHT INTERIOR REAR VIEW MIRROR MultiCAN-711 Interior Mirror Variant IRVM changed to SVRM Marco's thread on fitting Clearsight Mirror https://www.defender2.net/forum/topic88338.html To turn off DRL / signature LEDs, aka "halos" in premium / matrix type headlamps: MultiCAN-468 FntDRLType Current: Incorporated DRL and Pos New: No DRL TURN OFF AUTOHOLD PERMANENTLY MultiCAN-711 Auto Hold Current: HVH Enabled New: HVH Disabled STOP DRIVER ASSISTANCE RESETS TO HIGH MultiCAN-889 GSR2 EU Market Ft Change it to Non GSR2 Country DISABLE THE VEHICLE WAKING UP AND THE LIGHTS COMING ON OR OFF WITH SOLELY THE TAILGATE/BOOT DOOR OPENING AND CLOSING Multican 703 “BCM interior light trunk” Fitted. Multican 703 BCMinterior light delay” Fitted. Immediately turns out all vehicle lights without a 30 second delay. So the 1st one stops ALL vehicle lights when trunk/boot door is opened or shut. The 2nd one immediately stops the lights when any of the 4 passenger doors are opened because our vehicles are set for a 30 second delay which drains the battery. WIPER DRIP FEATURE MultiCAN-726 Wiper Drip Wipe Feature Change to:Disabled TURN PUDDLE LIGHTS OFF (if you're not a fan of the "graphics") EUCD-087 Puddle Light Stock setting: Outer Mirrors With Puddle Light (0x2) Change to: Without puddle light DISABLE THE FAKE ENGINE NOISES PLAYED THROUGH THE STEREO (or choose different versions) with these two settings: (I highly recommend disabling this on long roadtrips... it's more present than you think.) Next Generation Power Train Sound Quality (NGPTSQ) MultiCAN-584 NextGenPwrTrnSQ Select: Not Fitted MultiCAN-585 ActSndDesignPwrlvl Not Supported Select: Not Fitted * Both set to ' Not fitted ' for off[/u][/i] DEFENDER PIVI PRO MY25 INTERFACE - SOFT BUTTONS ON SIDES OF SCREEN POSSIBLY ONLY WORKS FOR MY25 CARS MultiCAN-882 Sidebar Controls from "Legacy" to "Sidebar Controls with DSC + VC Drawer AND VC Bar on 4x4i MultiCAN-892 SideBar Climate Climate Icon on Side Bar Available - FICP Replacement MultiCAN-896 ReCircle Soft Button Soft Button Fitted with timed and latched logic MultiCAN-897 Max AC Soft Button Soft Button Fitted MultiCAN-897 Max Defrost Soft Button Soft Button Fitted MultiCAN-897 AC OnOff Soft Button Soft Button Fitted MultiCAN-897 Auto Climate Soft Button Front AUTO Climate Soft Button Fitted MultiCAN-898 Front Htd Screen Soft Button Soft Button Fitted MultiCAN-898 Read Htd Screen Soft Button Soft Button Fitted RESET SERVICE (GAP TOOL NOT REQUIRED) Open driver door. Leave open Pull bonnet hatch Press start stop Press and hold down brake pedal Wait 2 seconds. Fully press and hold accelerator pedal. Wait upto 30 seconds until service reset message appears MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar Last edited by DefenderMidlands on 1st Apr 2025 12:11pm. Edited 23 times in total |
Gbone99 Member Since: 25 Jul 2024 Location: New York Posts: 1 ![]() ![]() |
Hi, New member here. Thru the awesome work on this forum I got a GAP V4 tool for my 23' Defender 130. All the ACC programs I tried have worked except the parking feature and global open/close window with the remote. The parking shows up on Pivi but wont work. I think I need to disconnect the battery (read on another thread) to get these to work.
I found that the battery is under the pass seat, is there any specific process or pit falls to be aware of here? Thanks in advance. |
BadgerWaz Member Since: 15 Jul 2024 Location: Somewhere else Posts: 110 ![]() ![]() |
Disconnecting the battery on many cars will disable the auto window function, so these need relearning when the battery is reconnected.
Usually you put the window down with the switch and hold it down for a short while, then the same for putting it back up. Maybe try this but using the keyfob as that's how I lower all my windows at once to let the heat escape the car before letting the dogs jump in. On our Disco the sunroof opens too. |
RoysRover Member Since: 04 Aug 2024 Location: Pennsylvania Posts: 2 ![]() ![]() |
Has anyone been able to set the default TR mode to anything other than Comfort? I have all the “features” other than the dreaded Park Assist. I had it almost working but the start button was greyed out. A huge thank you to this thread and the big contributors; Gap Diagnostics, Ian, Marco, and many others. Thanks to you all, my vehicle is way cooler!
copysat Member Since: 14 May 2024 Location: AD Posts: 9 ![]() ![]() |
Kaylorsan Member Since: 18 Apr 2024 Location: UT Posts: 3 ![]() ![]() |
I got my GAP IID tool last week and have been playing around with it a bit.
I have a Carpathian Edition (V ![]() Yesterday, I was playing around with 882 and 895 in the CCF files. I can’t recall who/where it was posted (see text below), however it enabled a ‘shortcuts’ screen that allows for TR (Terrain Response) settings via soft buttons. It also made some changes to the ‘real estate’ on the left and right side of the screen. The right side now has a slider for Volume and the left side has TR Modes. When Pivi first booted up, it showed some ‘demo’ screens of the new layout. It included some Climate options on the left side. Unfortunately, they have not shown up yet on the screen. The only downside is that the left side used to be customizable with the apps that I could choose. It is now ‘fixed’. My guess is that there are more changes in the future and things will change over time, however I found this exciting to play with. Has anyone else seen this yet? Thanks for all who have contributed to this thread. I find it very fun to explore/add/customize features. FWIW, I am still not able to get Park Assist to work. Like others have posted, everything seems to sequence correctly, however the START button remains greyed out. The post I saw …882 to enable the side bars on the ends of the screen. This way you can quickly adjust the AC temp, fan, drive mode, seat temps, volume. You also need to enable a few setting that if I recall were grouped in the 895 and you can choose what short cuts you want displayed such as window defrost etc. Those are called soft buttons.. |
@RoysRover - This worked for me. Can't recall where found it tho. It took a couple reboots and restarts to appear. Note that I also performed some activations that gave me 'side menu bars' and the 'shortcuts' screen. I'm not sure if the success of this activation depends on those. I hope that it works out for you. STARTUP ON AUTO TERRAIN RESPONSE MultiCAN-476 ATPC Was HDC only Is HDC and LSPC MultiCAN-696 ATCM Auto TR Mode Switch Was Auto Terrain Response Mode selection switch not fitted Is Auto Terrain Response Mode selection switch fitted MultiCAN-736 Config TR Fitment Was Not Configured Is Off Road Configuration MultiCAN-754 Auto TR Prog Mode Was Not fitted Is Fitted MultiCAN-755 Config TR Mode Was Not available for selection Is Available for selection with timeout MultiCAN-778 ATPC Select In FCPB Was Control interface not available in FCPB Is Available as shared purpose button MultiCAN-778 Ter Auto Select In FCPB Was Control interface not available in FCPB Is Rotary used for selection within touch screen MultiCAN-789 Drive Mode Order Was All Terain Vehicle Standard Order Is AlI Terrain Vehicle Including Auto Order MultiCAN-797 Ter CT Select In FCPB Was Control interface not available in FCPB Is Rotary used for selection within touch screen MultiCAN-798 Ter CP Select In FCPB Was Control interface not available in FCPB Is Rotary used for selection within touch screen MultiCAN-853 ATPC Button Type Was Not fitted Is Hard Button Fitted |
Joolroper Member Since: 02 Oct 2022 Location: Bristol Posts: 25 ![]() ![]() ![]() |
Many thanks this worked for me to enable AUTO terrain response.
This needs adding to the main thread please for all, as this is not on there at present. Cheers guys! |
graemesmith1960 Member Since: 03 Sep 2021 Location: West of Scotland Posts: 79 ![]() ![]() |
I think it is already all on the main thread somewhere as I managed to enable the Auto mode a while ago. The problem is that it always defaults to Comfort on startup. You need to do a long press of the button or select it on screen to get the Auto Terrain.
According to the iGuide it will either default to Comfort or Auto depending on the market. Unfortunately it doesn't say what markets are supposed to do what! Mine is a UK spec car. Defender D350 X-Dynamic HSE 110 MY25 Carpathian Grey |
Lonfred Member Since: 20 Sep 2024 Location: Barcelona Posts: 6 ![]() ![]() |
I used this as written above and the car start up on Auto terrain response but when I manually change to another program it is not possible to manually change back to AUTO even if it is visible on the screen. Anyone who know what to change to get it available? Long push does not work either. P400e with small screen MY23
TomekW Member Since: 21 Feb 2015 Location: Warsaw Posts: 197 ![]() ![]() ![]() |
Hi Folks,
below is the complete list of mods I did in my 2021 Defender 90 D250, with analog instrument cluster. All mods are working, sometimes you need the car to relearn the CCF config, then perform car reset; both available in G4 version new values in blue EUCD-019 Rear Foglight Tow Function Not supported Foglights shut off when trailer is connected, only trailers foglights are running EUCD-020 Trailer Module Not supported Trailer Module 13-pos socket EUCD-126 Microphone Microphone (Driver Only) Front microphones EUCD-129 Terrain Response Fitment With Terrain Response Auto Terrain Response Dynamic & Configurable Dynamic Mode EUCD-245 Dynamic-I Dynamic-i Not Fitted Dynamic-i Content with Configurable Dynamic Mode Screen MultiCAN-476 ATPC HDC only HDC + LSPC MultiCAN-562 DynamicProgMode Not available for selection Available for selection without timeout MultiCAN-566 MHLastUserMode Last user memory mode disabled Last user memory mode enabled MultiCAN-579 TowAssist Not Enabled Tow Assist 2 MultiCAN-580 PTCruiseFitment ACC with Queue Assist fitted MultiCAN-584 NextGenPwrTrnSQ PTSQ NLI Not Fitted MultiCAN-585 ActSndDesignPwrlvl NGPTSQ Not Fitted MultiCAN-605 ConfigDynamicMode Not Fitted Fitted MultiCAN-712 ACC Lead Car Dist Disp Fitted MultiCAN-770 Remote Release Tailgate Disabled Enabled MultiCAN-777 Ter Dyn Select In FCPB Control interface not available in FCPB Rotary used for selection within touch screen MultiCAN-793 TA2 Input Control Not fitted HVAC rotary MultiCAN-795 TA2 Select In FCPB Control interface not available in FCPB Rotary used for selection within touch screen MultiCAN-809 ACC Stop Gap Setting Fitted MultiCAN-838 Speedo Market Market 0 (+3.5% +2km/h) Market 1 (+2%) 2021 Defender 90 D250 1998 TUL 1997 TUM FFR 2003 Defender 110SW Td5 1985 ExMOD 110 ST 3.9 V8 1971 Series IIa Lightweight |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3028 ![]() ![]() |
Did you find that after changing the speedometer to the more accurate setting, the cruise control remains on the previous less accurate speed?
For example you set the cruise at 70mph but the speedometer says you are doing 67mph |
