Home > General & Technical (L663) > Gap Diagnostic Tool working Activations for IID 4 tool only
DefenderMidlands
We could do with creating a sticky for Gap Diagnostic Tool working Activations for IID 4 tool only and then we can add ATPC, ACC and TR2 that are confirmed working but only with IID 4 version MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar
Post #1036634 6th Jun 2024 7:26am
sasa
Czech Republic
Thumbs Up
Post #1036769 7th Jun 2024 12:22pm
Martin
Site Admin
Whistle  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1036770 7th Jun 2024 12:40pm
DefenderMidlands
***Requires GAP IID Tool G4 to activate Will throw up an error with GAP IID G3 version of the tool***
ALSO MAKE SURE THE G4 TOOL IS UPDATED TO THE LATEST FIRMWARE VERSION VIA USB CABLE ON YOUR PC/MAC
ACC Adaptive Cruise Control (ACC)
MultiCAN-580 PTCruiseFitment: ACC with Queue Assist fitted
MultiCAN-712 ACC Lead Car Distance Display: Fitted
MultiCAN-809 ACC Stop Gap Setting: Fitted
All terrain progress control (ATPC)
MultiCAN-476 ATPC
Original: HDC Change to : HDC and LSPC
No warnings, no loss of other functionality. 15 min wait required, no Pivi reset.
Configurable Terrain Response (TR2)
MultiCAN-736 Config TR Fitment - Not Configured > change to Off Road Configuration
MultiCAN-755 Config TR Mode - Not available for selection > change to Available for selection with timeout
MultiCAN-797 Ter CT Select In FCPB Change to "Rotary used for selection within touch MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar
Post #1036784 7th Jun 2024 2:47pm
Gbone99
United States
Hi, New member here. Thru the awesome work on this forum I got a GAP V4 tool for my 23' Defender 130. All the ACC programs I tried have worked except the parking feature and global open/close window with the remote. The parking shows up on Pivi but wont work. I think I need to disconnect the battery (read on another thread) to get these to work.
I found that the battery is under the pass seat, is there any specific process or pit falls to be aware of here?
Thanks in advance.
Post #1040975 25th Jul 2024 4:30pm
BadgerWaz
Disconnecting the battery on many cars will disable the auto window function, so these need relearning when the battery is reconnected.
Usually you put the window down with the switch and hold it down for a short while, then the same for putting it back up.
Maybe try this but using the keyfob as that's how I lower all my windows at once to let the heat escape the car before letting the dogs jump in. On our Disco the sunroof opens too.
Post #1040987 25th Jul 2024 7:13pm
RoysRover
United States
Eco Mode Default
Has anyone been able to set the default TR mode to anything other than Comfort? I have all the “features” other than the dreaded Park Assist. I had it almost working but the start button was greyed out. A huge thank you to this thread and the big contributors; Gap Diagnostics, Ian, Marco, and many others. Thanks to you all, my vehicle is way cooler!
Post #1041889 4th Aug 2024 10:43pm
copysat
United Arab Emirates
Are GAP 4 available in stock?
Post #1045286 9th Sep 2024 9:00am
Kaylorsan
United States
Dynamic Soft Button
I got my GAP IID tool last week and have been playing around with it a bit.
I have a Carpathian Edition (VCool in the North American Market. I have Pivi 4.1.5 installed. It came standard with many of the options out there, however I can still add a # of features with the tool.
Yesterday, I was playing around with 882 and 895 in the CCF files. I can’t recall who/where it was posted (see text below), however it enabled a ‘shortcuts’ screen that allows for TR (Terrain Response) settings via soft buttons.
It also made some changes to the ‘real estate’ on the left and right side of the screen. The right side now has a slider for Volume and the left side has TR Modes.
When Pivi first booted up, it showed some ‘demo’ screens of the new layout. It included some Climate options on the left side. Unfortunately, they have not shown up yet on the screen.
The only downside is that the left side used to be customizable with the apps that I could choose. It is now ‘fixed’.
My guess is that there are more changes in the future and things will change over time, however I found this exciting to play with. Has anyone else seen this yet? Thanks for all who have contributed to this thread. I find it very fun to explore/add/customize features.
FWIW, I am still not able to get Park Assist to work. Like others have posted, everything seems to sequence correctly, however the START button remains greyed out.
The post I saw
…882 to enable the side bars on the ends of the screen. This way you can quickly adjust the AC temp, fan, drive mode, seat temps, volume. You also need to enable a few setting that if I recall were grouped in the 895 and you can choose what short cuts you want displayed such as window defrost etc. Those are called soft buttons..
Post #1045369 10th Sep 2024 12:33am
Kaylorsan
United States
Re: Eco Mode Default
@RoysRover - This worked for me. Can't recall where found it tho. It took a couple reboots and restarts to appear. Note that I also performed some activations that gave me 'side menu bars' and the 'shortcuts' screen. I'm not sure if the success of this activation depends on those.
I hope that it works out for you.
STARTUP ON AUTO TERRAIN RESPONSE
MultiCAN-476 ATPC
Was HDC only
Is HDC and LSPC
MultiCAN-696 ATCM Auto TR Mode Switch
Was Auto Terrain Response Mode selection switch not fitted
Is Auto Terrain Response Mode selection switch fitted
Was Not Configured
Is Off Road Configuration
MultiCAN-754 Auto TR Prog Mode
Was Not fitted
Is Fitted
Was Not available for selection
Is Available for selection with timeout
MultiCAN-778 ATPC Select In FCPB
Was Control interface not available in FCPB
Is Available as shared purpose button
MultiCAN-778 Ter Auto Select In FCPB
Is Rotary used for selection within touch screen
MultiCAN-789 Drive Mode Order
Was All Terain Vehicle Standard Order
Is AlI Terrain Vehicle Including Auto Order
MultiCAN-798 Ter CP Select In FCPB
MultiCAN-853 ATPC Button Type
Was Not fitted
Is Hard Button Fitted
Post #1045371 10th Sep 2024 1:00am
Joolroper
United Kingdom 2012 Defender 90 Puma 2.2 X-Tech LE Orkney Grey
Many thanks this worked for me to enable AUTO terrain response.
This needs adding to the main thread please for all, as this is not on there at present.
Cheers guys!
Post #1045817 14th Sep 2024 6:09pm
graemesmith1960
I think it is already all on the main thread somewhere as I managed to enable the Auto mode a while ago. The problem is that it always defaults to Comfort on startup. You need to do a long press of the button or select it on screen to get the Auto Terrain.
According to the iGuide it will either default to Comfort or Auto depending on the market. Unfortunately it doesn't say what markets are supposed to do what!
Mine is a UK spec car. Defender D300 HSE 110 MY22 Pangea Green
Post #1048461 12th Oct 2024 1:30pm
Lonfred
Spain
I used this as written above and the car start up on Auto terrain response but when I manually change to another program it is not possible to manually change back to AUTO even if it is visible on the screen. Anyone who know what to change to get it available? Long push does not work either. P400e with small screen MY23
MultiCAN-476 ATPC
Was HDC only
Is HDC and LSPC
Was Not Configured
Was Not fitted
Is Fitted
Was Not fitted
Post #1050663 3rd Nov 2024 8:57pm
