Home > General & Technical (L663) > Gap Diagnostic Tool working Activations for IID 4 tool only |
sasa Member Since: 05 Mar 2024 Location: ceska lipa Posts: 48 |
7th Jun 2024 12:22pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
1988 90 Td5 NAS soft top
2015 D90 XS SW |
7th Jun 2024 12:40pm |
DefenderMidlands Member Since: 08 Mar 2023 Location: West Midlands Posts: 225 |
***Requires GAP IID Tool G4 to activate Will throw up an error with GAP IID G3 version of the tool***
ALSO MAKE SURE THE G4 TOOL IS UPDATED TO THE LATEST FIRMWARE VERSION VIA USB CABLE ON YOUR PC/MAC ACC Adaptive Cruise Control (ACC) MultiCAN-580 PTCruiseFitment: ACC with Queue Assist fitted MultiCAN-712 ACC Lead Car Distance Display: Fitted MultiCAN-809 ACC Stop Gap Setting: Fitted All terrain progress control (ATPC) MultiCAN-476 ATPC Original: HDC Change to : HDC and LSPC No warnings, no loss of other functionality. 15 min wait required, no Pivi reset. Configurable Terrain Response (TR2) MultiCAN-736 Config TR Fitment - Not Configured > change to Off Road Configuration MultiCAN-755 Config TR Mode - Not available for selection > change to Available for selection with timeout MultiCAN-797 Ter CT Select In FCPB Change to "Rotary used for selection within touch MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar |
7th Jun 2024 2:47pm |
Gbone99 Member Since: 25 Jul 2024 Location: New York Posts: 1 |
Hi, New member here. Thru the awesome work on this forum I got a GAP V4 tool for my 23' Defender 130. All the ACC programs I tried have worked except the parking feature and global open/close window with the remote. The parking shows up on Pivi but wont work. I think I need to disconnect the battery (read on another thread) to get these to work.
I found that the battery is under the pass seat, is there any specific process or pit falls to be aware of here? Thanks in advance. |
25th Jul 2024 4:30pm |
BadgerWaz Member Since: 15 Jul 2024 Location: Linconshire Posts: 66 |
Disconnecting the battery on many cars will disable the auto window function, so these need relearning when the battery is reconnected.
Usually you put the window down with the switch and hold it down for a short while, then the same for putting it back up. Maybe try this but using the keyfob as that's how I lower all my windows at once to let the heat escape the car before letting the dogs jump in. On our Disco the sunroof opens too. |
25th Jul 2024 7:13pm |
RoysRover Member Since: 04 Aug 2024 Location: Pennsylvania Posts: 2 |
Has anyone been able to set the default TR mode to anything other than Comfort? I have all the “features” other than the dreaded Park Assist. I had it almost working but the start button was greyed out. A huge thank you to this thread and the big contributors; Gap Diagnostics, Ian, Marco, and many others. Thanks to you all, my vehicle is way cooler!
4th Aug 2024 10:43pm |
copysat Member Since: 14 May 2024 Location: AD Posts: 9 |
Are GAP 4 available in stock?
9th Sep 2024 9:00am |
Kaylorsan Member Since: 18 Apr 2024 Location: UT Posts: 3 |
I got my GAP IID tool last week and have been playing around with it a bit.
I have a Carpathian Edition (V in the North American Market. I have Pivi 4.1.5 installed. It came standard with many of the options out there, however I can still add a # of features with the tool. Yesterday, I was playing around with 882 and 895 in the CCF files. I can’t recall who/where it was posted (see text below), however it enabled a ‘shortcuts’ screen that allows for TR (Terrain Response) settings via soft buttons. It also made some changes to the ‘real estate’ on the left and right side of the screen. The right side now has a slider for Volume and the left side has TR Modes. When Pivi first booted up, it showed some ‘demo’ screens of the new layout. It included some Climate options on the left side. Unfortunately, they have not shown up yet on the screen. The only downside is that the left side used to be customizable with the apps that I could choose. It is now ‘fixed’. My guess is that there are more changes in the future and things will change over time, however I found this exciting to play with. Has anyone else seen this yet? Thanks for all who have contributed to this thread. I find it very fun to explore/add/customize features. FWIW, I am still not able to get Park Assist to work. Like others have posted, everything seems to sequence correctly, however the START button remains greyed out. The post I saw …882 to enable the side bars on the ends of the screen. This way you can quickly adjust the AC temp, fan, drive mode, seat temps, volume. You also need to enable a few setting that if I recall were grouped in the 895 and you can choose what short cuts you want displayed such as window defrost etc. Those are called soft buttons.. |
10th Sep 2024 12:33am |
@RoysRover - This worked for me. Can't recall where found it tho. It took a couple reboots and restarts to appear. Note that I also performed some activations that gave me 'side menu bars' and the 'shortcuts' screen. I'm not sure if the success of this activation depends on those. I hope that it works out for you. STARTUP ON AUTO TERRAIN RESPONSE MultiCAN-476 ATPC Was HDC only Is HDC and LSPC MultiCAN-696 ATCM Auto TR Mode Switch Was Auto Terrain Response Mode selection switch not fitted Is Auto Terrain Response Mode selection switch fitted MultiCAN-736 Config TR Fitment Was Not Configured Is Off Road Configuration MultiCAN-754 Auto TR Prog Mode Was Not fitted Is Fitted MultiCAN-755 Config TR Mode Was Not available for selection Is Available for selection with timeout MultiCAN-778 ATPC Select In FCPB Was Control interface not available in FCPB Is Available as shared purpose button MultiCAN-778 Ter Auto Select In FCPB Was Control interface not available in FCPB Is Rotary used for selection within touch screen MultiCAN-789 Drive Mode Order Was All Terain Vehicle Standard Order Is AlI Terrain Vehicle Including Auto Order MultiCAN-797 Ter CT Select In FCPB Was Control interface not available in FCPB Is Rotary used for selection within touch screen MultiCAN-798 Ter CP Select In FCPB Was Control interface not available in FCPB Is Rotary used for selection within touch screen MultiCAN-853 ATPC Button Type Was Not fitted Is Hard Button Fitted |
10th Sep 2024 1:00am |
Joolroper Member Since: 02 Oct 2022 Location: Bristol Posts: 25 |
Many thanks this worked for me to enable AUTO terrain response.
This needs adding to the main thread please for all, as this is not on there at present. Cheers guys! |
14th Sep 2024 6:09pm |
graemesmith1960 Member Since: 03 Sep 2021 Location: West of Scotland Posts: 64 |
I think it is already all on the main thread somewhere as I managed to enable the Auto mode a while ago. The problem is that it always defaults to Comfort on startup. You need to do a long press of the button or select it on screen to get the Auto Terrain.
According to the iGuide it will either default to Comfort or Auto depending on the market. Unfortunately it doesn't say what markets are supposed to do what! Mine is a UK spec car. Defender D300 HSE 110 MY22 Pangea Green |
12th Oct 2024 1:30pm |
Lonfred Member Since: 20 Sep 2024 Location: Barcelona Posts: 5 |
I used this as written above and the car start up on Auto terrain response but when I manually change to another program it is not possible to manually change back to AUTO even if it is visible on the screen. Anyone who know what to change to get it available? Long push does not work either. P400e with small screen MY23
3rd Nov 2024 8:57pm |
