Home > General & Technical (L663) > Gap Diagnostic Tool Activations for IID 4 tool + other items
Page 2 of 3 <123>
CMG
Germany
I read somewhere in this forum that this is not the case. Requires separate setting. Sorry I can‘t recall where I saw this. Ex D4 & D5, now Defender D250 SE 110, MY24, Eiger Grey.
Post #1056313 4th Jan 2025 7:08pm
TomekW
Poland 2003 Defender 110 Td5 SW Bonatti Grey
lightning wrote:
Did you find that after changing the speedometer to the more accurate setting, the cruise control remains on the previous less accurate speed?
For example you set the cruise at 70mph but the speedometer says you are doing 67mph
exactly!
so annoying that I am considering going back to original setting 2021 Defender 90 D250
1998 TUL
1997 TUM FFR
2003 Defender 110SW Td5
1985 ExMOD 110 ST 3.9 V8
1971 Series IIa Lightweight
Post #1056315 4th Jan 2025 7:17pm
Lonfred
Spain
Hi,
Thanks for chairing your settings.
What does this change do?
MultiCAN-566 MHLastUserMode
Last user memory mode disabled
Last user memory mode enabled
Does is remember the last driving mode? For example driving mode mud/ice will be remembered when starting car again?
Post #1056320 4th Jan 2025 9:22pm
TomekW
Hi,
this change remembers that I want to have auto start stop off
Very Happy 2021 Defender 90 D250
1998 TUL
1997 TUM FFR
Post #1056491 6th Jan 2025 9:49pm
The_75th
Wade Sensing...
...What might the differences be do y'all reckon?
Post #1057185 12th Jan 2025 7:27pm
Dannymm
exactly!
Yes you have to have all these 3 setting to match
MultiCAN - 838 Speedo Market
MultiCAN - 577 SpdoCalPercentScale
MultiCAN -575 SpdoCalkmhOffset
Post #1057263 13th Jan 2025 4:34pm
Brockmoor Howard
Belgium
Hi Guys, has anybody info on what CCF modifications are needed for activating electronic active rear differential & torque vectoring by braking ?
Post #1059344 3rd Feb 2025 7:45am
Muehae
Germany
have you retrofitted a rear locking diff?
As i understand this, it not just a software adjustment, but a real part which is needed...
Post #1059472 4th Feb 2025 10:54am
ruben
Spain
Of course, it would be unthinkable that we would have a sleeping rear differential available at the price it has. Defender 110 SE I6 D250 23MY
ExDiscovery 3 TDV6 SE
Post #1059474 4th Feb 2025 10:59am
Brockmoor Howard
Belgium
Indeed, a lot of configurations are sleeping in the CCF.
I was told by professionals that the differential is activable to become electronic.
I wonder what EUCD/MULTICAN number is connected to that activation.
Post #1059547 4th Feb 2025 9:16pm
Retroanaconda
The locking differential is a different physical part, it has a solenoid and extra wiring etc. as well as the actual differential itself.
It can be added but is a lot more work than just software. Have a read of this thread to get an idea of what is involved:
https://www.defender2.net/forum/topic78820.html
Post #1059552 4th Feb 2025 10:32pm
Brockmoor Howard
Belgium
Thank you for this valuable info.
Post #1059569 5th Feb 2025 11:04am
lightning
Dannymm wrote:
exactly!
Have you tried this and did it work for you? When l tried it, l got various errors such as collision avoidance disabled and 2wd only available.
l reset the settings and the faults disappeared.
Post #1060417 12th Feb 2025 9:27pm
Mark1107
United States
Fellas the locking rear differential can be oem factory retrofitted. I did it on my 2020.
https://www.instagram.com/p/CPcL8nNlhLw/?u...gn=loading
 2022 Defender Trek Competition 110 collectors edition!
2020 Defender 110 P400 Full Explorer Pack 7 Seater HSE Fuji White(sold)
2020 SVO Range Rover L405 Full Size Spectral Blue Chromaflair
2014 Range Rover L405 Autobiography Full Size Aintree Green
2014 Dodge Viper GTS Stryker Green
Post #1060607 15th Feb 2025 9:07am
Cheshire110
Has anyone found a way to set the Driver Assistance level (the steering wheel button on new models) to remember the user setting (like e.g. we have managed with start/stop)? Cheers, David
Post #1064329 31st Mar 2025 6:46pm
Page 2 of 3 <123>
