Home > General & Technical (L663) > Gap Diagnostic Tool Activations for IID 4 tool + other items
Page 1 of 3 123>
DefenderMidlands
We could do with creating a sticky for Gap Diagnostic Tool working Activations for IID 4 tool only and then we can add ATPC, ACC and TR2 that are confirmed working but only with IID 4 version MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar
Post #1036634 6th Jun 2024 8:26am
sasa
Czech Republic
Thumbs Up
Post #1036769 7th Jun 2024 1:22pm
Martin
Site Admin
Whistle  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1036770 7th Jun 2024 1:40pm
DefenderMidlands
***Starred item Requires GAP IID Tool G4 to activate Will throw up an error with GAP IID G3 version of the tool***
ALSO MAKE SURE THE G4 TOOL IS UPDATED TO THE LATEST FIRMWARE VERSION VIA USB CABLE ON YOUR PC/MAC
***ACC ADAPTIVE CRUISE CONTROL (ACC)
MultiCAN-580 PTCruiseFitment: ACC with Queue Assist fitted
MultiCAN-712 ACC Lead Car Distance Display: Fitted
MultiCAN-809 ACC Stop Gap Setting: Fitted
***ALL TERRAIN PROGRESS CONTROL (ATPC)
MultiCAN-476 ATPC
Original: HDC Change to : HDC and LSPC
No warnings, no loss of other functionality. 15 min wait required, no Pivi reset.
***CONFIGURABLE TERRAIN RESPONSE (TR2)
MultiCAN-736 Config TR Fitment - Not Configured > change to Off Road Configuration
MultiCAN-755 Config TR Mode - Not available for selection > change to Available for selection with timeout
MultiCAN-797 Ter CT Select In FCPB Change to "Rotary used for selection within touch
CHAUFFEUR MODE ENABLE MY24 ONWARDS ONLY
MultiCAN-665 ChaffeurMode
Fitted
MultiCAN-853 TS Sec Seat Movement
Touch Screen Control of Secondary Seat Movement - Fitted
STARTUP ON AUTO TERRAIN RESPONSE
MultiCAN-476 ATPC
Was HDC only
Is HDC and LSPC
MultiCAN-696 ATCM Auto TR Mode Switch
Was Auto Terrain Response Mode selection switch not fitted
Is Auto Terrain Response Mode selection switch fitted
Was Not Configured
Is Off Road Configuration
MultiCAN-754 Auto TR Prog Mode
Was Not fitted
Is Fitted
Was Not available for selection
Is Available for selection with timeout
MultiCAN-778 ATPC Select In FCPB
Was Control interface not available in FCPB
Is Available as shared purpose button
MultiCAN-778 Ter Auto Select In FCPB
Is Rotary used for selection within touch screen
MultiCAN-789 Drive Mode Order
Was All Terain Vehicle Standard Order
Is AlI Terrain Vehicle Including Auto Order
MultiCAN-798 Ter CP Select In FCPB
MultiCAN-853 ATPC Button Type
Was Not fitted
Is Hard Button Fitted
REMEMBER AUTO STOP/ START LAST SETTING
MultiCAN-566 MHLastUserMode
Last user memory mode disabled
Last user memory mode enabled
ACCURATE SPEEDOMETER
MultiCAN-838 Speedo Market
Market 0 (+3.5% +2km/h)
Market 1 (+2%)
You also have to have all these 3 setting to match
MultiCAN - 838 Speedo Market
MultiCAN - 577 SpdoCalPercentScale
MultiCAN -575 SpdoCalkmhOffset
FOGLIGHTS SHUT OFF WHEN TRAILER IS CONNECTED, ONLY TRAILER FOGLIGHTS ARE RUNNING
EUCD-019 Rear Foglight Tow Function
Not supported
EUCD-020 Trailer Module
Not supported
Trailer Module 13-pos socket
ENABLE BOTH FRONT MICROPHONES
EUCD-126 Microphone
Microphone (Driver Only)
Front microphones
RESET SERVICE OIL WARNING
Service/Test -> IPC-Instrument Pack -> Service Interval Reset
STOP DRIVER ASSISTANCE RESETTING TO HIGH
MultiCAN-889 GSR2 EU Market Ft
Change it to Non GSR2 Country
ACTIVATE WIFI/WLAN HOTSPOT
MultiCAN-814 IVIWiFiHotspot
Standard: Not fitted
Changed to: Internal WiFi Hotspot fitted
CHANGE SPLASH SCREEN TO "Defender 007
EUCD-205 Racing Sub Brand
Standard: Mainstream Vehicle
Changed to: LTD 007
DYNAMIC MODE
Most cars will then have red dials and red interior lights when dynamic mode is selected
EUCD-129 Terrain Response Fitment, Set to "Auto Terrain Response Dynamic & Configurable Dynamic Mode"
EUCD-245 Dynamic-I
Standard: Dynamic-i Not Fitted
Changed to: Dynamic-i Content with Configurable Dynamic Mode Screen
MultiCAN-562 DynamicProgMode
Standard: Not available for selection
Changed to: Available for selection without timeout
Other possible value: Available for selection with timeout
MultiCAN-605 ConfigDynamicMode
Standard: Not Fitted
Changed to: Fitted
MultiCAN-777 Ter Dyn Select In FCPB
Standard: Control interface not available in FCPB
Changed to: Rotary used for selection within touch screen
WALK AWAY LOCKING
MultiCAN-505
Change it to Current: Enabled
Possibly only works on cars without locking fuel cap or MY25 onwards
APPROACH UNLOCKING
MultiCAN-807 Approach Unlocking
Disabled
Change to Enabled
MODIFY SIGNATURE LEDS BEHAVIOUR
MultiCAN-463 DRLBehWhilstDIsAct
Current: Turn Off
New: No Action
MultiCAN-465 DRLBehWhHazardsAct
Current: Turn Off
New: No Action
This setting is to keep them on while the turn signals or hazard lights are operating
ENABLE SUBWOOFER
The subwoofer was installed in the base model, but wasn't enabled
EUCD-121 Subwoofer
Standard: Without Subwoofer
Changed to: Subwoofer
ENABLE ALL MICROPHONES
EUCD-126 Microphone = Four Microphones (Two Front & Two Rear)
Standard: Microphone (Driver Only)
DISABLE SEATBELT REMINDER
MultiCAN-717 Front Belt Minder
Beltminder Fully OFF
MultiCAN-737 Rear Belt Minder
Rear Beltminder OFF
REAR DOOR POPS OPEN FROM BUTTON ON KEY FOB
MultiCAN-770 Remote Release Tailgate
Enabled
GLOBAL OPEN AND CLOSE
MultiCAN-723 Gloabal open/close
MultiCAN 723 SMRF Global Close - changed to Enabled
MulitCAN 719 CDL Global Close - changed to Enabled
MultiCAN 719 CDL Global Open - changed to Enabled
EUCD 184 Global Open/Close - changed to Global Open/Close Doors + Sunroof
DISABLE DRIVE AWAY LOCKING
MultiCAN-740 Drive Away Door Lock to Disabled - To disable drive away locking
FOGLIGHTS WITH HIGHBEAM
EUCD-018 Foglight Function
Foglight without restrictions
MultiCAN-734 Front Fog Lights Oft High Beam
Set to Disable.
MORE ACCURATE SPEED READINGS
MultiCAN-838 from: Speedo market 0- 3.5% + 2kph
To Speedo market 1- 2.0% + 0kph
TOW ASSIST2
MultiCAN-579 Tow Assist
Set to Tow Assist 2
MultiCAN-635 Towing
Set to Not Support if not already set to this setting.
MultiCAN-696 ATCM TA2 Switch
Set to Tow Assist 2 feature selection switch not fitted, again if not already set to this.
MultiCAN-793 TA2 Input Control
Set to HVAC rotary.
MultiCAN-795 TA2 Select in FCPB
Set to Rotary used for selection within touch screen.
AFTER RETROFITTING 11.4" DISPLAY
MultiCAN-641 FrntUpperDispVariant
Alpine 11.6 inch Single View
Clarke4x4's thread on fitting larger screen
https://www.defender2.net/forum/topic89297.html
AFTER RETROFITTING CLEARSIGHT INTERIOR REAR VIEW MIRROR
MultiCAN-711 Interior Mirror Variant
IRVM
changed to SVRM
Marco's thread on fitting Clearsight Mirror
https://www.defender2.net/forum/topic88338.html
To turn off DRL / signature LEDs, aka "halos" in premium / matrix type headlamps:
MultiCAN-468 FntDRLType
Current: Incorporated DRL and Pos
New: No DRL
TURN OFF AUTOHOLD PERMANENTLY
MultiCAN-711 Auto Hold
Current: HVH Enabled
New: HVH Disabled
STOP DRIVER ASSISTANCE RESETS TO HIGH
DISABLE THE VEHICLE WAKING UP AND THE LIGHTS COMING ON OR OFF WITH SOLELY THE TAILGATE/BOOT DOOR OPENING AND CLOSING
Multican 703 “BCM interior light trunk” Fitted.
Multican 703 BCMinterior light delay” Fitted. Immediately turns out all vehicle lights without a 30 second delay.
So the 1st one stops ALL vehicle lights when trunk/boot door is opened or shut.
The 2nd one immediately stops the lights when any of the 4 passenger doors are opened because our vehicles are set for a 30 second delay which drains the battery.
WIPER DRIP FEATURE
MultiCAN-726 Wiper Drip Wipe Feature
Change to:Disabled
TURN PUDDLE LIGHTS OFF (if you're not a fan of the "graphics")
EUCD-087 Puddle Light
Stock setting: Outer Mirrors With Puddle Light (0x2)
Change to: Without puddle light
DISABLE THE FAKE ENGINE NOISES PLAYED THROUGH THE STEREO (or choose different versions)
with these two settings: (I highly recommend disabling this on long roadtrips... it's more present than you think.)
Next Generation Power Train Sound Quality (NGPTSQ)
MultiCAN-584 NextGenPwrTrnSQ
Select: Not Fitted
MultiCAN-585 ActSndDesignPwrlvl
Not Supported
Select: Not Fitted
* Both set to ' Not fitted ' for off[/u][/i]
DEFENDER PIVI PRO MY25 INTERFACE - SOFT BUTTONS ON SIDES OF SCREEN
POSSIBLY ONLY WORKS FOR MY25 CARS
MultiCAN-882 Sidebar Controls
from "Legacy" to "Sidebar Controls with DSC + VC Drawer AND VC Bar on 4x4i
MultiCAN-892 SideBar Climate
Climate Icon on Side Bar Available - FICP Replacement
MultiCAN-896 ReCircle Soft Button
Soft Button Fitted with timed and latched logic
MultiCAN-897 Max AC Soft Button
Soft Button Fitted
MultiCAN-897 Max Defrost Soft Button
Soft Button Fitted
MultiCAN-897 AC OnOff Soft Button
Soft Button Fitted
MultiCAN-897 Auto Climate Soft Button
Front AUTO Climate Soft Button Fitted
MultiCAN-898 Front Htd Screen Soft Button
Soft Button Fitted
MultiCAN-898 Read Htd Screen Soft Button
Soft Button Fitted
RESET SERVICE (GAP TOOL NOT REQUIRED)
Open driver door. Leave open
Pull bonnet hatch
Press start stop
Press and hold down brake pedal
Wait 2 seconds. Fully press and hold accelerator pedal.
Wait upto 30 seconds until service reset message appears MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar
Post #1036784 7th Jun 2024 3:47pm
Gbone99
United States
Hi, New member here. Thru the awesome work on this forum I got a GAP V4 tool for my 23' Defender 130. All the ACC programs I tried have worked except the parking feature and global open/close window with the remote. The parking shows up on Pivi but wont work. I think I need to disconnect the battery (read on another thread) to get these to work.
I found that the battery is under the pass seat, is there any specific process or pit falls to be aware of here?
Thanks in advance.
Post #1040975 25th Jul 2024 5:30pm
BadgerWaz
Disconnecting the battery on many cars will disable the auto window function, so these need relearning when the battery is reconnected.
Usually you put the window down with the switch and hold it down for a short while, then the same for putting it back up.
Maybe try this but using the keyfob as that's how I lower all my windows at once to let the heat escape the car before letting the dogs jump in. On our Disco the sunroof opens too.
Post #1040987 25th Jul 2024 8:13pm
RoysRover
United States
Eco Mode Default
Has anyone been able to set the default TR mode to anything other than Comfort? I have all the “features” other than the dreaded Park Assist. I had it almost working but the start button was greyed out. A huge thank you to this thread and the big contributors; Gap Diagnostics, Ian, Marco, and many others. Thanks to you all, my vehicle is way cooler!
Post #1041889 4th Aug 2024 11:43pm
copysat
United Arab Emirates
Post #1045286 9th Sep 2024 10:00am
Kaylorsan
United States
Dynamic Soft Button
I got my GAP IID tool last week and have been playing around with it a bit.
I have a Carpathian Edition (VCool in the North American Market. I have Pivi 4.1.5 installed. It came standard with many of the options out there, however I can still add a # of features with the tool.
Yesterday, I was playing around with 882 and 895 in the CCF files. I can’t recall who/where it was posted (see text below), however it enabled a ‘shortcuts’ screen that allows for TR (Terrain Response) settings via soft buttons.
It also made some changes to the ‘real estate’ on the left and right side of the screen. The right side now has a slider for Volume and the left side has TR Modes.
When Pivi first booted up, it showed some ‘demo’ screens of the new layout. It included some Climate options on the left side. Unfortunately, they have not shown up yet on the screen.
The only downside is that the left side used to be customizable with the apps that I could choose. It is now ‘fixed’.
My guess is that there are more changes in the future and things will change over time, however I found this exciting to play with. Has anyone else seen this yet? Thanks for all who have contributed to this thread. I find it very fun to explore/add/customize features.
FWIW, I am still not able to get Park Assist to work. Like others have posted, everything seems to sequence correctly, however the START button remains greyed out.
The post I saw
…882 to enable the side bars on the ends of the screen. This way you can quickly adjust the AC temp, fan, drive mode, seat temps, volume. You also need to enable a few setting that if I recall were grouped in the 895 and you can choose what short cuts you want displayed such as window defrost etc. Those are called soft buttons..
Post #1045369 10th Sep 2024 1:33am
Kaylorsan
United States
Re: Eco Mode Default
@RoysRover - This worked for me. Can't recall where found it tho. It took a couple reboots and restarts to appear. Note that I also performed some activations that gave me 'side menu bars' and the 'shortcuts' screen. I'm not sure if the success of this activation depends on those.
I hope that it works out for you.
MultiCAN-476 ATPC
Was HDC only
Is HDC and LSPC
Was Not Configured
Was Not fitted
Is Fitted
Was Not fitted
Post #1045371 10th Sep 2024 2:00am
Joolroper
United Kingdom 2012 Defender 90 Puma 2.2 X-Tech LE Orkney Grey
Many thanks this worked for me to enable AUTO terrain response.
This needs adding to the main thread please for all, as this is not on there at present.
Cheers guys!
Post #1045817 14th Sep 2024 7:09pm
graemesmith1960
I think it is already all on the main thread somewhere as I managed to enable the Auto mode a while ago. The problem is that it always defaults to Comfort on startup. You need to do a long press of the button or select it on screen to get the Auto Terrain.
According to the iGuide it will either default to Comfort or Auto depending on the market. Unfortunately it doesn't say what markets are supposed to do what!
Mine is a UK spec car. Defender D350 X-Dynamic HSE 110 MY25 Carpathian Grey
Post #1048461 12th Oct 2024 2:30pm
Lonfred
Spain
I used this as written above and the car start up on Auto terrain response but when I manually change to another program it is not possible to manually change back to AUTO even if it is visible on the screen. Anyone who know what to change to get it available? Long push does not work either. P400e with small screen MY23
MultiCAN-476 ATPC
Was HDC only
Is HDC and LSPC
Was Not Configured
Was Not fitted
Is Fitted
Was Not fitted
Post #1050663 3rd Nov 2024 9:57pm
TomekW
Poland 2003 Defender 110 Td5 SW Bonatti Grey
Hi Folks,
below is the complete list of mods I did in my 2021 Defender 90 D250, with analog instrument cluster.
All mods are working, sometimes you need the car to relearn the CCF config, then perform car reset; both available in G4 version
new values in blue
Not supported
Foglights shut off when trailer is connected, only trailers foglights are running
Not supported
EUCD-126 Microphone
Front microphones
With Terrain Response
EUCD-245 Dynamic-I
MultiCAN-476 ATPC
HDC only
HDC + LSPC
MultiCAN-579 TowAssist
Not Enabled
Tow Assist 2
PTSQ NLI
Not Fitted
NGPTSQ
Not Fitted
Not Fitted
Fitted
MultiCAN-712 ACC Lead Car Dist Disp
Fitted
Disabled
Enabled
Not fitted
HVAC rotary
MultiCAN-795 TA2 Select In FCPB
Fitted
Market 1 (+2%) 2021 Defender 90 D250
1998 TUL
1997 TUM FFR
2003 Defender 110SW Td5
1985 ExMOD 110 ST 3.9 V8
1971 Series IIa Lightweight
Post #1056226 3rd Jan 2025 6:43pm
lightning
Did you find that after changing the speedometer to the more accurate setting, the cruise control remains on the previous less accurate speed?
For example you set the cruise at 70mph but the speedometer says you are doing 67mph
Post #1056312 4th Jan 2025 7:06pm
Page 1 of 3 123>
