Home > General & Technical (L663) > Gap Diagnostic Tool Activations for IID 4 tool + other items
DefenderMidlands
We could do with creating a sticky for Gap Diagnostic Tool working Activations for IID 4 tool only and then we can add ATPC, ACC and TR2 that are confirmed working but only with IID 4 version MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar
Post #1036634 6th Jun 2024 7:26am
sasa
Czech Republic
Thumbs Up
Post #1036769 7th Jun 2024 12:22pm
Martin
Site Admin
Whistle  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1036770 7th Jun 2024 12:40pm
DefenderMidlands
***Starred item Requires GAP IID Tool G4 to activate Will throw up an error with GAP IID G3 version of the tool***
ALSO MAKE SURE THE G4 TOOL IS UPDATED TO THE LATEST FIRMWARE VERSION VIA USB CABLE ON YOUR PC/MAC
***ACC Adaptive Cruise Control (ACC)
MultiCAN-580 PTCruiseFitment: ACC with Queue Assist fitted
MultiCAN-712 ACC Lead Car Distance Display: Fitted
MultiCAN-809 ACC Stop Gap Setting: Fitted
***All terrain progress control (ATPC)
MultiCAN-476 ATPC
Original: HDC Change to : HDC and LSPC
No warnings, no loss of other functionality. 15 min wait required, no Pivi reset.
***Configurable Terrain Response (TR2)
MultiCAN-736 Config TR Fitment - Not Configured > change to Off Road Configuration
MultiCAN-755 Config TR Mode - Not available for selection > change to Available for selection with timeout
MultiCAN-797 Ter CT Select In FCPB Change to "Rotary used for selection within touch
Chauffeur Mode Enable MY24 onwards only
MultiCAN-665 ChaffeurMode
Fitted
MultiCAN-853 TS Sec Seat Movement
Touch Screen Control of Secondary Seat Movement - Fitted
STARTUP ON AUTO TERRAIN RESPONSE
MultiCAN-476 ATPC
Was HDC only
Is HDC and LSPC
MultiCAN-696 ATCM Auto TR Mode Switch
Was Auto Terrain Response Mode selection switch not fitted
Is Auto Terrain Response Mode selection switch fitted
Was Not Configured
Is Off Road Configuration
MultiCAN-754 Auto TR Prog Mode
Was Not fitted
Is Fitted
Was Not available for selection
Is Available for selection with timeout
MultiCAN-778 ATPC Select In FCPB
Was Control interface not available in FCPB
Is Available as shared purpose button
MultiCAN-778 Ter Auto Select In FCPB
Is Rotary used for selection within touch screen
MultiCAN-789 Drive Mode Order
Was All Terain Vehicle Standard Order
Is AlI Terrain Vehicle Including Auto Order
MultiCAN-798 Ter CP Select In FCPB
MultiCAN-853 ATPC Button Type
Was Not fitted
Is Hard Button Fitted
REMEMBER AUTO STOP/ START LAST SERTING
MultiCAN-566 MHLastUserMode
Last user memory mode disabled
Last user memory mode enabled
ACCURATE SPEEDOMETER
MultiCAN-838 Speedo Market
Market 0 (+3.5% +2km/h)
Market 1 (+2%)
You also have to have all these 3 setting to match
MultiCAN - 838 Speedo Market
MultiCAN - 577 SpdoCalPercentScale
MultiCAN -575 SpdoCalkmhOffset
Foglights shut off when trailer is connected, only trailers foglights are running
EUCD-019 Rear Foglight Tow Function
Not supported
EUCD-020 Trailer Module
Not supported
Trailer Module 13-pos socket
EUCD-126 Microphone
Microphone (Driver Only)
Front microphones
EUCD-129 Terrain Response Fitment
With Terrain Response
Auto Terrain Response Dynamic & Configurable Dynamic Mode
EUCD-245 Dynamic-I
Dynamic-i Not Fitted
Dynamic-i Content with Configurable Dynamic Mode Screen
MultiCAN-476 ATPC
HDC only
HDC + LSPC
MultiCAN-562 DynamicProgMode
Available for selection without timeout
MultiCAN-579 TowAssist
Not Enabled
Tow Assist 2
MultiCAN-584 NextGenPwrTrnSQ
PTSQ NLI
Not Fitted
MultiCAN-585 ActSndDesignPwrlvl
NGPTSQ
Not Fitted
MultiCAN-605 ConfigDynamicMode
Not Fitted
Fitted
MultiCAN-712 ACC Lead Car Dist Disp
Fitted
MultiCAN-770 Remote Release Tailgate
Disabled
Enabled
MultiCAN-777 Ter Dyn Select In FCPB
MultiCAN-793 TA2 Input Control
Not fitted
HVAC rotary
MultiCAN-795 TA2 Select In FCPB
Not fitted
HVAC rotary
Fitted
RESET SERVICE OIL WARNING
Service/Test -> IPC-Instrument Pack -> Service Interval Reset MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar
Post #1036784 7th Jun 2024 2:47pm
Gbone99
United States
Hi, New member here. Thru the awesome work on this forum I got a GAP V4 tool for my 23' Defender 130. All the ACC programs I tried have worked except the parking feature and global open/close window with the remote. The parking shows up on Pivi but wont work. I think I need to disconnect the battery (read on another thread) to get these to work.
I found that the battery is under the pass seat, is there any specific process or pit falls to be aware of here?
Thanks in advance.
Post #1040975 25th Jul 2024 4:30pm
BadgerWaz
Disconnecting the battery on many cars will disable the auto window function, so these need relearning when the battery is reconnected.
Usually you put the window down with the switch and hold it down for a short while, then the same for putting it back up.
Maybe try this but using the keyfob as that's how I lower all my windows at once to let the heat escape the car before letting the dogs jump in. On our Disco the sunroof opens too.
Post #1040987 25th Jul 2024 7:13pm
RoysRover
United States
Eco Mode Default
Has anyone been able to set the default TR mode to anything other than Comfort? I have all the “features” other than the dreaded Park Assist. I had it almost working but the start button was greyed out. A huge thank you to this thread and the big contributors; Gap Diagnostics, Ian, Marco, and many others. Thanks to you all, my vehicle is way cooler!
Post #1041889 4th Aug 2024 10:43pm
copysat
United Arab Emirates
Post #1045286 9th Sep 2024 9:00am
Kaylorsan
United States
Dynamic Soft Button
I got my GAP IID tool last week and have been playing around with it a bit.
I have a Carpathian Edition (VCool in the North American Market. I have Pivi 4.1.5 installed. It came standard with many of the options out there, however I can still add a # of features with the tool.
Yesterday, I was playing around with 882 and 895 in the CCF files. I can’t recall who/where it was posted (see text below), however it enabled a ‘shortcuts’ screen that allows for TR (Terrain Response) settings via soft buttons.
It also made some changes to the ‘real estate’ on the left and right side of the screen. The right side now has a slider for Volume and the left side has TR Modes.
When Pivi first booted up, it showed some ‘demo’ screens of the new layout. It included some Climate options on the left side. Unfortunately, they have not shown up yet on the screen.
The only downside is that the left side used to be customizable with the apps that I could choose. It is now ‘fixed’.
My guess is that there are more changes in the future and things will change over time, however I found this exciting to play with. Has anyone else seen this yet? Thanks for all who have contributed to this thread. I find it very fun to explore/add/customize features.
FWIW, I am still not able to get Park Assist to work. Like others have posted, everything seems to sequence correctly, however the START button remains greyed out.
The post I saw
…882 to enable the side bars on the ends of the screen. This way you can quickly adjust the AC temp, fan, drive mode, seat temps, volume. You also need to enable a few setting that if I recall were grouped in the 895 and you can choose what short cuts you want displayed such as window defrost etc. Those are called soft buttons..
Post #1045369 10th Sep 2024 12:33am
Kaylorsan
United States
Re: Eco Mode Default
@RoysRover - This worked for me. Can't recall where found it tho. It took a couple reboots and restarts to appear. Note that I also performed some activations that gave me 'side menu bars' and the 'shortcuts' screen. I'm not sure if the success of this activation depends on those.
I hope that it works out for you.
MultiCAN-476 ATPC
Was HDC only
Is HDC and LSPC
Was Not Configured
Was Not fitted
Is Fitted
Was Not fitted
Post #1045371 10th Sep 2024 1:00am
Joolroper
United Kingdom 2012 Defender 90 Puma 2.2 X-Tech LE Orkney Grey
Many thanks this worked for me to enable AUTO terrain response.
This needs adding to the main thread please for all, as this is not on there at present.
Cheers guys!
Post #1045817 14th Sep 2024 6:09pm
graemesmith1960
I think it is already all on the main thread somewhere as I managed to enable the Auto mode a while ago. The problem is that it always defaults to Comfort on startup. You need to do a long press of the button or select it on screen to get the Auto Terrain.
According to the iGuide it will either default to Comfort or Auto depending on the market. Unfortunately it doesn't say what markets are supposed to do what!
Mine is a UK spec car. Defender D350 X-Dynamic HSE 110 MY25 Carpathian Grey
Post #1048461 12th Oct 2024 1:30pm
Lonfred
Spain
I used this as written above and the car start up on Auto terrain response but when I manually change to another program it is not possible to manually change back to AUTO even if it is visible on the screen. Anyone who know what to change to get it available? Long push does not work either. P400e with small screen MY23
MultiCAN-476 ATPC
Was HDC only
Is HDC and LSPC
Was Not Configured
Was Not fitted
Is Fitted
Was Not fitted
Post #1050663 3rd Nov 2024 8:57pm
TomekW
Poland 2003 Defender 110 Td5 SW Bonatti Grey
Hi Folks,
below is the complete list of mods I did in my 2021 Defender 90 D250, with analog instrument cluster.
All mods are working, sometimes you need the car to relearn the CCF config, then perform car reset; both available in G4 version
new values in blue
Not supported
Not supported
EUCD-126 Microphone
Front microphones
EUCD-245 Dynamic-I
MultiCAN-476 ATPC
HDC only
HDC + LSPC
Not Enabled
Tow Assist 2
PTSQ NLI
Not Fitted
NGPTSQ
Not Fitted
Not Fitted
Fitted
Fitted
Disabled
Enabled
Not fitted
HVAC rotary
Fitted
Market 1 (+2%) 2021 Defender 90 D250
1998 TUL
1997 TUM FFR
2003 Defender 110SW Td5
1985 ExMOD 110 ST 3.9 V8
1971 Series IIa Lightweight
Post #1056226 3rd Jan 2025 5:43pm
lightning
Did you find that after changing the speedometer to the more accurate setting, the cruise control remains on the previous less accurate speed?
For example you set the cruise at 70mph but the speedometer says you are doing 67mph
Post #1056312 4th Jan 2025 6:06pm
