Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 6 of 109 <123 ... 567 ... 107108109>
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
Another one that may or may not work is walk away locking
MultiCAN-505
WalkAwayLocking
Change it to Current: Enabled
You then have to go into your centre screen and enable it
Patrick said that this doesn't work on all cars and mine happens to be one that it doesn't work on Sad Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #972529 26th Nov 2022 11:33pm
Cheshire110
Has anyone managed to find the setting for disabling the auto shutdown?
I hate when you open the door and the car turns itself off, erasing any terrain response modes etc.
(NB. I’m NOT talking about start/stop) Cheers, David
Post #972531 27th Nov 2022 12:26am
umbertob
United States
forzahog wrote:
For those trying to get ACC that don't currently have it, here's what I have tried so far without real success. These are changes I made comparing my CCF file to Ian's.
Setting: Value [Original Value]
EUCD-075 Integrated Vehicle Dynamic Control: IVDC (Incl. Enhanced ESP And CDC) [Not Supported]
EUCD-097 Forward Collision Warning: Not Supported [Without Forward Collision Warning]
MultiCAN-503 IntelCruiseCtrl: Not supported [ICC not Fitted]
MultiCAN-580 PTCruiseFitment: ACC with Queue Assist fitted [Normal Cruise Fitted]
I did verify that even my Base model has the radar module behind the Land Rover logo. You can even test it with the IID tool in Live Values. So, the hardware is in place, just not the settings/software.
For those that have ACC, do you also have regular cruise control as well? The videos and documentation I've seen so far hint at switching between Speed Limiter/ACC and not regular cruise control. I'm wondering if disabling regular cuise may help...IDK.
Another line to check (my 2020 110 NAS HSE was factory fitted with ACC) is this - my setting included. Kind of counterintuitive - like many other entries in the CCF, honestly - but that's how it is in mine:
EUCD-023 Cruise Control
Without cruise control
Unrelated, but here is how to modify the front signature LEDs behavior - if yours is equipped with them of course - to keep them on while the turn signals or hazard lights are operating (that one always bothered my... symmetry OCD on the Defender and most other Land Rovers - I am sure there is a law that states the front DRL/signature halos need to dim when turn signals are on, but I doubt I'll get ticketed for that):
MultiCAN-463 DRLBehWhilstDIsAct
Current: Turn Off
New: No Action
MultiCAN-465 DRLBehWhHazardsAct
Current: Turn Off
New: No Action 2020 NAS Defender 110 HSE 5-seater / Silver / Khaki / Black Pack / Black Roof / Satin Film / Cold Pack / Off-Road Pack / Advanced OR Pack / Comfort + Convenience Pack / Sirius + HD radio / HUD / Meridian Surround
Post #972535 27th Nov 2022 5:22am
umbertob
United States
MultiCAN-505
WalkAwayLocking
Mine doesn't work either. As a matter of fact, the setting in the center screen that appears under the Safety and Security tab, as you show in the above screenshot, turns off by itself about 5 seconds after I toggle it on. So, I suspect Walk Away Locking may be market or model year dependent. Same reason why I cannot seem to get Global Windows Close to operate on my 2020. In North America / US market, that features is disabled, and even if you turn toggle both Global Windows Open and Close on in the center screen settings, only Open works with the remote Changing the setting in the CCF has not made a difference for me. Perhaps there is another setting I am missing. 2020 NAS Defender 110 HSE 5-seater / Silver / Khaki / Black Pack / Black Roof / Satin Film / Cold Pack / Off-Road Pack / Advanced OR Pack / Comfort + Convenience Pack / Sirius + HD radio / HUD / Meridian Surround
Post #972536 27th Nov 2022 5:34am
matt4x4
Germany
forzahog wrote:
matt4x4 wrote:
@pllr
After messing up ACC features I always got an error shown with the emergency braking system,
was not able to use even the normal cruise control. After restore all fine again.
Could you share what changes you tried for ACC?
I have been looking at the CCF for anything related to this list.
https://www.lrdefender.org/speed_control_d...n-630.html
Quote:
The adaptive cruise control system utilizes the following main components:
CCM
IPMA
Parking Aid sensors (quantity Cool
Park Assist sensors (quantity 4)
Side Obstacle Detection Control Module - Left (SODL)
Side Obstacle Detection Control Module - Right (SODR)
Right steering wheel switch
PCM
Electric throttle
ABS
Adaptive cruise control warning indicator - Displayed in the IPC.
The link to the doc is very interesting. HairyDan send me his CCF.
Both of us have these parameters set:
MultiCAN-792 DADC Module
DADC LL
MultiCAN-793 CCM Variant
MRRevo14F Fitted
I think this refers to the radar in the LR sign and the camera behind the center mirror.
So I believe the hardware must be there and the same.
I tried with these settings, but will try again with variations.
As said, I got "Emergency brake failure" and nothing worked with CC.
-> a lot values - tried: Adaptive Cruise Control, Stop & Go, Brake Limit 2, With ACC To CC Toggling
-> but Hairy Dans CCF also shows "without", but he has it.
-> so I dont know, what this setting really is for.
Possible Values:
Adaptive Cruise Control Stop & Go
Adaptive Cruise Control Brake Limit 2
Adaptive Cruise Control Stop & Go, Brake Limit 2
Adaptive Cruise Control, With ACC To CC Toggling
Adaptive Cruise Control, Stop&Go, With ACC To CC Toggling
Adaptive Cruise Control, Brake Limit 2, With ACC To CC Toggling
->Adaptive Cruise Control, Stop & Go, Brake Limit 2, With ACC To CC Toggling
Not supported
->ICC fitted
MultiCAN-580
PTCruiseFitment
Normal cruise fitted
Values:
No cruise fitted
ACC fitted
->ACC with Queue Assist fitted
Others I found are the MultiCAN-497 settings. I tried changing them,
but without any success. These are my defaults.
IntelSpdLimitISL
ISL fitted
DrvDrowsyMonDDM
DDM not fitted
IntelEmergBrkingCUIEB
IEB not fitted
FwdCollWarnAEB
FCW not fitted
But I have some kind of "Forward Collision warning" working,
if not messing it up with changing paramaters - hmmmmm....
As seen on the screens in "pllr"s post I have as standard
the "Adaptive Speed limiter" for traffic signs
and "Emergeny brake" with the 4 possible value in pivi (far to near)
under "Collision avoidance"
But not the "Adaptrive cruise control: Stop Gab" menu - yet Wink
So I think all needed hardware must be there.
We'll see what the sunday brings ....
Post #972543 27th Nov 2022 8:08am
whiterdesign
Walk away locking only works on 2023 MY with the new BCM., according to Vulkan. So if your fuel cap doesn’t lock, walk away locking should. 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
Post #972655 27th Nov 2022 9:56pm
Hairy Dan
Thanks for that, now I know why it doesn't work on mine Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #972657 27th Nov 2022 10:09pm
matt4x4
Germany
Mine is a 23.5
WalkAwayLocking works for me.
And my car has no locking fuel cap.
But I like to retrofit it sometime, if I get the actuator.
Or will that not work with the new BCM?
Can the new BCM also be the reason why enabling ACC does not work / gives the error with emergency braking assist ?
Post #972681 28th Nov 2022 9:25am
whiterdesign
I’ve got the new BCM on my 23 MY and I’ve had ACC added by Venture Automotive in Bolton.
Vulkan have developed an add on unit for fuel locking but it is both expensive and difficult to fit. Simon at Powerful is also looking at it. 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
Post #972701 28th Nov 2022 11:39am
Nuclear Nick
My March build 23MY V8 doesn’t have the locking filler flap. As far as I can see the flap has the actuator fitted and wiring connected so it seems like it’s more about saving chips in the BCM.
And yes, Simon is on the case and also with some other retrofits. I’ve just installed his sunglasses holder. Bit fiddly but looks and works fine.
Post #972720 28th Nov 2022 3:12pm
Hairy Dan
forzahog wrote:
Side note, I was also playing with saving Start/Stop so it doesn't keep resetting to on when you get back in the car.
MultiCAN-566 MHLastUserMode = Enabled
Enabled this on my car last night and it seems to work Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #972723 28th Nov 2022 4:20pm
Hairy Dan
Just to keep the list up to date and together, here are the changes that appear to work at the moment.
- Activate WIFI/WLAN Hotspot
MultiCAN-814 IVIWiFiHotspot
Standard: Not fitted
Changed to: Internal WiFi Hotspot fitted
- Change Splash Screen to "Defender 007"
EUCD-205 Racing Sub Brand
Standard: Mainstream Vehicle
Changed to: LTD 007
- Dynamic Mode
EUCD-245 Dynamic-I
Standard: Dynamic-i Not Fitted
Changed to: Dynamic-i Content with Configurable Dynamic Mode Screen
MultiCAN-562 DynamicProgMode
Standard: Not available for selection
Changed to: Available for selection without timeout
Other possible value: Available for selection with timeout
MultiCAN-605 ConfigDynamicMode
Standard: Not Fitted
Changed to: Fitted
-Remember Stop/start setting
MultiCAN-566
-WalkAwayLocking
MultiCAN-505
Only available on MY2023 onward, if you don’t have a locking fuel cap you can enable walk away locking. You will also have to go into your centre screen setting and switch it on
-Modify signature LEDs behavior
Current: Turn Off
New: No Action
Current: Turn Off
New: No Action
This setting is to keep them on while the turn signals or hazard lights are operating. Cheers Ian
Kielder 4x4 Safari
Post #972724 28th Nov 2022 4:26pm
forzahog
United States 2016 Defender 110 Other Works V8 Auto Fuji White
I can add one more to the list for those that don't already have it. The subwoofer was installed in my base model, but wasn't enabled.
EUCD-121 Subwoofer
Standard: Without Subwoofer
Changed to: Subwoofer 20MY Defender 110 Fuji White
Post #972726 28th Nov 2022 4:46pm
forzahog
And another one...
-Enable All Microphones
EUCD-126 Microphone = Four Microphones (Two Front & Two Rear)
Standard: Microphone (Driver Only)
This one switched from using the microphone in the dash to the four mounted overhead. This made a huge impact on sound quality when I was on the phone. 20MY Defender 110 Fuji White
Post #972820 29th Nov 2022 1:24pm
PatGAPInnov
Site Sponsor
Canada
Darn, I should have spent more time on this thread... Glad to see progress so far!
We still haven't figured out Adaptive Cruise Control but to our defense have been overwhelmed with work lately. We will get to the bottom of it in time...
Cheers! http://www.gap-diagnostic.com/
Post #972858 29th Nov 2022 7:20pm
