Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 50 of 108 <123 ... 495051 ... 106107108>
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
mani_jeenu wrote:
can you add these as well? These are all from this thread as well except the last two which are from different threads in this forum
Done Thumbs Up Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1006881 8th Sep 2023 7:43am
Hairy Dan
lightning wrote:
l've noticed that my speedometer over reads by about 3mph at 70 mph, according to my GPS.
This would be useful then.
Why would they set the speedometer to over read?
I would say that just about every car that I've had the speedo over-read they do this to ensure that they comply with the law and make sure that their speedometers are never showing less than true speed under any foreseeable circumstances, car manufacturers will normally deliberately calibrate their speedos to read 'high' by a certain amount.
I always set my ACC to the speed limit plus 2mph so in a 40 limit I would set the ACC to 42 Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #1006882 8th Sep 2023 7:46am
Nuclear Nick
Spot on HD. Construction and Use regs require manufacturers to set speedos within the range plus 10% to minus 0%. This means speedos will always over read. Manufacturers I suspect have used this to their cost advantage to fit cheaper inaccurate speedos. It also fools customers into thinking how smooth and quiet cars are when in fact they are not going as fast as they think they are! As one example in the bike world, I’ve ridden brand new Yamaha FJR1300 Blood Bikes, with digital speedos, that are 10% fast throughout the range. Pretty poor in this day and age.
Post #1006884 8th Sep 2023 8:08am
Badeagle
Got my IID tool up and running
Have already added the 007 splash screen, walk up / away locking, Wi-Fi hot spot, open tailgate with fob and dynamic mode so far (love the red dials).
Would like the ACC when it’s sorted.
Has anyone been able to get the car to remember last drive mode. MY23 XS 110 D250
2003 Jeep Cherokee Limited
Post #1006961 8th Sep 2023 9:53pm
Hairy Dan
No not yet unfortunately Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #1006963 8th Sep 2023 10:47pm
aajr
United States
It worked on a 2023.5.
Post #1006970 9th Sep 2023 6:54am
pjeski
United States
What is “last drive mode” and what worked?
Post #1006973 9th Sep 2023 7:34am
Hairy Dan
I took it to mean if you had the car in say dynamic it would remember it after switching the car off. Cheers Ian
Kielder 4x4 Safari
Post #1006974 9th Sep 2023 8:03am
Badeagle
Great can you share the settings MY23 XS 110 D250
Post #1006985 9th Sep 2023 10:10am
Hairy Dan
Yes it would be good to know the settings if you could share them please Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #1006996 9th Sep 2023 12:33pm
pjeski
United States
I find it odd what the car remembers and what it doesn’t. This once certainly should be remembered. My car retains the setting for mute for the navigation voice prompts, but forgets that I set the voice feedback accent to English (UK), it always reverts back to US.
Post #1006998 9th Sep 2023 12:41pm
aajr
United States
It remembers your setting for the auto shutoff when stopping at a light, etc So, if the auto shutoff was on, it will remember that next time you use the car.
Post #1007021 9th Sep 2023 4:28pm
Hairy Dan
Oh I see you mean stop/start setting MultiCAN-566 MHLastUserMode, we thought you'd found a way for the car to remember the drive mode you were in eg Eco/Comfort/Dynamic etc Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #1007027 9th Sep 2023 6:02pm
aajr
United States
Sorry for the confusion. Alas, I have not seen anything that allows keeping the drive mode from the prior setting.
Post #1007041 9th Sep 2023 8:28pm
TBinOz
Australia
Successfully enabled Configurable TR on my 2021 D300 SE. It was reluctant to show up on screen, even after running the learn config procedure and letting the car sit double-locked overnight I still had to force-reboot Pivi Pro. Showed up in the end though.
Thanks to all who helped discover and share these options!
Post #1007151 10th Sep 2023 9:08pm
