![]() | Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3706 ![]() ![]() ![]() |
And, has the driving mode bit been resolved so that if you turn the car off on Grass Gravel Snow, when you come to turn it on it will remain in GGS?
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 174 ![]() ![]() |
thanks Ian for the terrain configurable upgrade, I edited the ccf as you said and got the screen after two resets of the pivi. I also tried to enable the Auto mode, but when I turn it on again, an error appears that I have already seen other times in configurations, traction only at 2WD. later I deleted AUTO, everything worked. Anyway very nice ....... thank you very much ![]() ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1442 ![]() ![]() ![]() |
This will turn off the seatbelt bong MultiCAN-717 Front Belt Minder Beltminder ON (ECE type) Change to off to disable your seatbelt warning buzzer ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Nicofender Member Since: 16 Jan 2023 Location: Southern Posts: 51 ![]() ![]() |
Does someone know whether it’s possible to turn the Adblue system off so the engine will still start without that brew?
It’ll give you some peace of mind when doing longer off-road trips. |
Nice one. Thanks. |
DefenderMidlands Member Since: 08 Mar 2023 Location: West Midlands Posts: 255 ![]() ![]() |
Is this still in beta? Where is the place to order these from in the UK and if still in beta can you still join the beta program?
stevemfr Member Since: 18 Sep 2022 Location: Strasbpurg Posts: 156 ![]() ![]() |
What is meant by a locking fuel cap. Don’t they all Lock?
Would be interested to see if I could enable approach unlocking on my 2023 defender with the gap tool |
ODPA Member Since: 06 Jul 2023 Location: Northwest Posts: 86 ![]() ![]() |
My GAP IID Tool arrived a couple days ago. Read the manual and registered. So far have set the 007 welcome, walk up unlock, walk away lock, auto stop disable, and seat belt warning disable. Work great and is very easy to use. The list earlier in the thread is very helpful as well. Thank you all who have contributed.
As for the locking gas cap no the do not all have this. Mine as an example has a push open and push close door with a non locking filler cap can just be removed. I would guess based on your reply that yours does lock? If so it sounds like the unlock and lock option may not work for you. But again I am very new to this as well so may be mistaken. Just going off what others have posted previously. |
If you lock your car then go to the fuel flap door and see if it's locked or can be opened. If it hasn't locked you can probably change the following settings and you 'may' get it to work MultiCAN-505 Change it to Current: Enabled MultiCAN-807 Approach Unlocking from: Disabled to: Enabled ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
kenl Member Since: 11 Jul 2022 Location: bunvegas Posts: 30 ![]() ![]() |
I have actually changed mine back to disabled. I have my key in my pocket most of the time and whenever i'm anywhere near my car it unlocks and then again locks... That can't be good for the actuators and it bugs me, so now it's just walk away locking. Because sometimes I forget! MY23.5 SE Defender
I have been through this entire thread twice and made lots of notes but seem to be missing the CCF’s specific to advanced tow. Does anyone have the specifics on turning this one? I have ATPC already so based on what I have read it should work if I turn it on. Sorry if I missed it but again am just hoping someone has the specifics on this. Thanks.
In my notes I have
MultiCAN579 TowAssist 0x02 Change to Tow Assist 2 But I haven't been able to test it personally as I haven't got a trailer here, let us know if it works ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
o-ren-ishii Member Since: 25 Jul 2023 Location: The Hague Posts: 41 ![]() ![]() |
Hi all,
Thanks for all the info in this thread. Got the IID tool a few days ago and I'm trying to change some stuff on my 75th ![]() Looking for info regarding this: • Auto brake hold. After standing on the brake at the traffic light for about a minute or so sometimes autohold engages. Even if it's turned off in the settings menu. • Shut off with running engine when opening the drivers door. I find this very annoying and would like to car to keep "running" (as you can speak of "running" with an P400e.. ) • There's supposed to be a "camping" settings in which the rear door doesn't trigger/wakes the car, thus saving you battery from draining when repeatedly opening and closing without running the engine on let's say a campsite... No clue what CCF settings to look for. Also found this option in the CCF file: • EUCD-247 Off Road Navigation Should I enable this and see what happens or is that a bad idea? Do you guys have more info about these settings? Cheers, Jasper |
