Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
haymeister Member Since: 24 May 2021 Location: Saitama Posts: 268 |
What does 'Dynamic mode' give you apart from red dials?
Heavier steering, a more sensitive throttle response, holds the gears longer? 22MY Defender 110 D300 S in Pangea Green and Contrast White Roof IG defender_japan "Hulk san" |
26th Jul 2023 12:12am |
ODPA Member Since: 06 Jul 2023 Location: Northwest Posts: 86 |
I think you hit most of it. It also will hold gears no matter the RPM when in sport mode and adds three new windows to the pivipro. Stopwatch, lap timer, and g force. My 110 also has the heads up display which changes to MPH and a tachometer indicator.
26th Jul 2023 4:04am |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1423 |
Yes somebody pointed that out last week and when I went to my settings I had it set correctly but had been told you had to touch the screen to do it so never checked Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
26th Jul 2023 1:12pm |
As ODPA says you have pretty much hit the nail on the head with your description although not everybody gets the red dials I now have the flappy paddles enabled on mine and that in conjunction with dynamic mode changes the way I drive the car Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
26th Jul 2023 1:16pm |
DefenderMidlands Member Since: 08 Mar 2023 Location: West Midlands Posts: 233 |
Has anyone managed to enable the cooling seats on cars with the heated seats and got it working with this tool?
26th Jul 2023 9:23pm |
There was somebody on here looking to retrofit the cooled seats but I don't think he went ahead because of the hardware that was needed. I'm pretty sure I've seen the setting for the climate seats in the CCF file so you should be able to turn them on once the hardware is fitted. Cheers Ian
26th Jul 2023 10:55pm |
Nuclear Nick Member Since: 21 Aug 2021 Location: Southwest Posts: 288 |
Also stiffens the suspension and deeper slightly louder exhaust note. But it’s standard on the V8 so it also has the necessary hardware. |
27th Jul 2023 7:55am |
Where in the gap tool are the settings to see if I could add an activity key? I read that I need to check if the kvm is locked for life? I’m not sure where to find this though?
28th Jul 2023 3:58pm |
whiterdesign Member Since: 10 Jun 2021 Location: Preston Posts: 269 |
I think you will find if you have 2 keys that it is locked, they only left it open when the vehicles were being delivered with one key, enabling them to add the second key later, it would then have been locked 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
28th Jul 2023 4:19pm |
I am aware of that and do have two keys. As I have the gap tool I just thought I would have a look but couldn’t see in the tool settings where to check
28th Jul 2023 4:36pm |
MickD Member Since: 28 Jul 2023 Location: New England Posts: 28 |
Hello, new guy here.
I was just activating Dynamic mode on my 110 using the instructions posted earlier in this thread. EUCD - 245 Dynamic 1 set to “Dynamic 1 Content with Configurable Dynamic Mode Screen” MultiCAN - 562 DynamicProgMode. Set to “Available for Selection Without Timeout” MultiCAN - 605 ConfigDynamicMode. Set to “Fitted” MultiCAN - 682 DynamicLiteMode. Set to “Available for Selection Without Timeout” MultiCAN - 777 Ter Dyn Select In FCPB. Set to “rotary used for selection within touch screen” It was all working except that the dynamic mode icon was not appearing on the drivers display when adjusting the rotary knob to select a mode. I found that adding this did the trick: EUCD-129 Terrain Response Fitment, Set to "Auto Terrain Response Dynamic & Configurable Dynamic Mode" Here's an image to demonstrate. Adding EUCD-129 resolved the issue. Click image to enlarge |
28th Jul 2023 10:55pm |
MickD nice info on EUCD129 I didn’t include that on my post as it was already active on my 110. I had it listed as a possible change but no change was needed once I was in the CCF files and saw my current settings.
29th Jul 2023 3:33am |
Well no joy on the Advanced Tow Assist. I tried setting to Tow Assist 2 which looked like it was working. Gave me the icon for the trailer with the steering wheel after selecting my trailer profile. Then when in reverse I could get the start window but the system would not allow me to select start. Then when I would exit out it would say auto steering cancelled but when backing the dial did nothing other than change the temperature setting. I have advance tow assist on the 130 so am familiar with how it works. Going to let it sit a while and see if it magically changes. If not I will put it back to default setting. Will have to dig more into it later.
30th Jul 2023 12:09am |
You got further than I did. I also set Tow Assist 2 but got nothing. Maybe I needed a Pivi reset.
30th Jul 2023 3:44am |
