Home > Puma (Tdci) > who does and who doesn't use 1st gear?
Page 4 of 4 <1234
chiefstoker
England 2005 Defender 90 Td5 HT Zambezi Silver
Honker wrote:
Tried this today. Can see the point if you need a (relatively) nippy get away across a junction, but doing it regularly must put some extra strain on things. Think I'll stick to the current 1st , accelerate , pause , wait for it , 2nd , off we go again.
Stu
Thats about right, select 1st, get up speed, clutch, count - 1000 2000 3000 4000 5000, select 2nd, wait for the nudge from the car behind - and we're off! 2005 TD5 90 Hard Top
Beer 'n Sex 'n Chips 'n Gravy
Post #132457 19th Mar 2012 7:17am
Caterham
its not so bad if the car behind nudges you.......
i end up nudging them as I'm rolling backwards be the time I'm into second and it therefore just seems to back a nonsense of using 1st most of the time Embarassed
Post #132469 19th Mar 2012 9:23am
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I always use first gear, mindfull of the fragility of the clutch, but like someone else said, once moving I regularly skip gears such as fifth when going up the box.
Pete
Post #132518 19th Mar 2012 1:34pm
rasmussen
France
In my old 110 defender hardtop (1986, no turbo) I did a lot of clutch sliding! Holding for red light on an uphill lane I did not hold the car on the break but the clutch. (just to avoid rolling back into the car behind) I know that now a day when people take driving license they are told to use the hand break holding for red light.
But reading this thread I understand that the clutch in the Puma is more fragile than the old defenders? It sounds strange as going off-road I would like to have a strong clutch in order to pass obstacles more gently.
Look forward to you comments
Post #132558 19th Mar 2012 3:48pm
MartinK
1st most of the time.
2nd if on a downhill incline (where I will probably use neutral till it gets rolling fast enough to "hold" 2nd anyway...so no clutch slippage)... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #132590 19th Mar 2012 6:09pm
Fat Cog
Always use 2nd, except when towing or uphill...anti stall helps!
Post #132711 19th Mar 2012 11:34pm
geezer
Australia 2011 Defender 90 Puma 2.4 SW Zermatt Silver
Use first all the time even if only brief without BAS ecu upgrade, otherwise clutch and or engine labours to much for my liking.
Varies between first and second with BAS ecu upgrade dependant on road gradient.
Post #133075 21st Mar 2012 11:39am
ZeDefender
and no clutch problems in 3 years? Tell someone you love them today because life is short.
Post #133134 21st Mar 2012 5:45pm
Zagato
rasmussen wrote:
In my old 110 defender hardtop (1986, no turbo) I did a lot of clutch sliding! Holding for red light on an uphill lane I did not hold the car on the break but the clutch. (just to avoid rolling back into the car behind) I know that now a day when people take driving license they are told to use the hand break holding for red light. Look forward to you comments
Shocked Rolling Eyes
Post #133158 21st Mar 2012 7:06pm
Page 4 of 4 <1234
