![]() | Home > Puma (Tdci) > who does and who doesn't use 1st gear? |
kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987 ![]() ![]() ![]() |
6th is best, with lots of slip
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20688 ![]() ![]() |
What 0 - 60mph in 30 minutes? ![]() |
Def-00 Member Since: 11 May 2011 Location: Sharjah Posts: 236 ![]() ![]() ![]() |
I hardly use first always second to pull away I just lift off the clutch and hold it till it reaches a steady speed then lift off then accelerate. I even pulled away at a traffic light in third once in the same way 2012 Fuji White 110
Always 1st to get rolling, but frequently go from 4th to 6th. LANDYWATCH
![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
Unladen, on the flat and downhill, especially in heavy moving traffic (and if I'm too lazy) I often pull gently away in 2nd - doesn't seem to be much more clutch slip than in 1st
![]() But shout it at them in German because life is also terrifying and confusing... |
NinetyTD4 Member Since: 22 Apr 2011 Location: North Posts: 397 ![]() ![]() ![]() |
They don't, it is a standard 82 gearbox from Ford Transit. Never forget: cars have owner, Landrover have field service personnel. |
Peter Td4 Member Since: 23 Oct 2010 Location: Antwerp, Belgium Posts: 228 ![]() ![]() ![]() |
Same here, unladen and flat or downhill (very rare around here
![]() No need to ride the clutch, 2nd on the Puma is not that much different from 1st gear on my Td5. Peter, Defender 110 StaWa - Td5 Defender 110 HCPU - Puma Defender 90 Soft Top - Td5 |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6324 ![]() ![]() ![]() |
me wonders what got this thread going again after 2 years?
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5014 ![]() ![]() |
Kona being VERY enthusiastic
It was indeed me ![]() |
I can't even remember what happened yesterday - keeps everything fresh and exciting
That's probably because yesterday was much the same as today ![]() |
cinstone Member Since: 29 Nov 2010 Location: Stourbridge Posts: 375 ![]() ![]() ![]() |
1st all the time pulling away from a stand still. 2nd isn't low enough.
Chris. http://shropshirelandrovers.freeforums.org 2015 Defender 90 XS SW & Helen, 1964 IIa. Previously 2012 Defender 90 XS SW & 2008 90 XS SW. Previous LR's: Michael, my 2008 Defender 90 XS SW. Machinas oportet intrare non capsicum annuum faveo |
Honker Member Since: 26 Jun 2011 Location: St Albans Posts: 353 ![]() ![]() ![]() |
Tried this today. Can see the point if you need a (relatively) nippy get away across a junction, but doing it regularly must put some extra strain on things. Think I'll stick to the current 1st , accelerate , pause , wait for it , 2nd , off we go again.
Stu |
