Home > Puma (Tdci) > who does and who doesn't use 1st gear?
Page 2 of 4 <1234>
spudfan
Ireland
Always use first gear.I keep pressure on the gear stick to keep it to the left and get a smooth change in to second gear. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #6324 15th Jan 2009 9:16pm
Caterham
spudfan (and all)
thanks, I'll try keeping pressure to the left for a smooth change. Up til now its either been a very slow change (almost like double clutching) or a slightly less than smooth change.
Post #6374 17th Jan 2009 10:09pm
If some of you have been using 2nd it's no wonder some of you get through so many chutches Laughing I always use first after all if you need to pull out that quick is it a good idea anyway? Thumbs Up
Post #132036 17th Mar 2012 1:03pm
Naks
1st gear. --
Post #132042 17th Mar 2012 2:07pm
Zagato
I used to use 2nd in my TD5 but always use 1st in the TDCi. Think TDCi has lower first gear than TD5 so that makes no sense Confused Whistle
If you pull away on a very steep hill and take the usual time to change from 1st to 2nd look in your mirror and watch the car behind have to slow down before they run in the back of you Rolling Eyes
Post #132046 17th Mar 2012 2:25pm
Maybe they won't be so close next time Laughing
Post #132055 17th Mar 2012 2:56pm
ericvv
Rolling Eyes 1st of course... Just to get going, and smoothly (meaning slowly) change to 2nd once reaching 10 kph (6mph)... The gearbox is not made to pull away in 2nd. Doing so you invariably will be slipping the clutch more than is needed. You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #132056 17th Mar 2012 3:02pm
T1G UP
this is part of the issue of running a utility vehicle that's capable of towing 3500kg as a daily / unladen drive.
2 nd's a tad to high but if you pull away with slip on the flat or slightly down hill its great, trying to get a flyer in a defenders wrong! 1st with higher tyres would be spot on i'm guessing.
with a caravan / car trailer / plant trailer etc the lowish first makes perfect sense, great for maneuvering and just list the clutch with no throttle and away you go.
You need to try drivin all day in low box like we did in Wales recently 3rd Low was low! 4-5-6 geting you up to 20 mph Thumbs Up
Post #132057 17th Mar 2012 3:03pm
Clutch slipping = clutch wear and reduced life. Done on a regular basis won't last long I doubt Whistle
Post #132058 17th Mar 2012 3:04pm
22900013A
I always use first gear in my 110, unless I'm on a downhill but even then I find 2nd a touch too high. Thats with 235 tyres. I wonder if those who pull away in 2nd are in 90s with 205s on?
Post #132067 17th Mar 2012 3:48pm
T1G UP
do they still do 205's on a puma?
Post #132068 17th Mar 2012 3:56pm
defender4
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Java Black
i will only use second if I'm on a down incline. I'm uncomfortable about not using first. I was taught to always use all the gears going up or down through the box.
Post #132113 17th Mar 2012 7:42pm
I was taught to jump gears but I don't in the Defender it's risky and to be honest there often isn't point. I prefer to go through the gears.
Post #132115 17th Mar 2012 7:47pm
22900013A
Sure, you still see farmers 90s on 205s.
Post #132124 17th Mar 2012 8:12pm
NinetyTD4
Wales 2012 Defender 90 Other SW Keswick Green
Never used 2nd to start away, always do 1st to get in motion. Never forget: cars have owner, Landrover have field service personnel.
Post #132128 17th Mar 2012 8:17pm
Page 2 of 4 <1234>
