Home > Puma (Tdci) > who does and who doesn't use 1st gear? |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6308 |
its not so bad if the car behind nudges you.......
i end up nudging them as I'm rolling backwards be the time I'm into second and it therefore just seems to back a nonsense of using 1st most of the time |
19th Mar 2012 8:23am |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 |
I always use first gear, mindfull of the fragility of the clutch, but like someone else said, once moving I regularly skip gears such as fifth when going up the box.
Pete |
19th Mar 2012 12:34pm |
rasmussen Member Since: 13 Mar 2012 Location: Nice Posts: 46 |
In my old 110 defender hardtop (1986, no turbo) I did a lot of clutch sliding! Holding for red light on an uphill lane I did not hold the car on the break but the clutch. (just to avoid rolling back into the car behind) I know that now a day when people take driving license they are told to use the hand break holding for red light.
But reading this thread I understand that the clutch in the Puma is more fragile than the old defenders? It sounds strange as going off-road I would like to have a strong clutch in order to pass obstacles more gently. Look forward to you comments |
19th Mar 2012 2:48pm |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 |
1st most of the time.
2nd if on a downhill incline (where I will probably use neutral till it gets rolling fast enough to "hold" 2nd anyway...so no clutch slippage)... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
19th Mar 2012 5:09pm |
Fat Cog Member Since: 19 Mar 2012 Location: Oxfordshire & Devon Posts: 502 |
Always use 2nd, except when towing or uphill...anti stall helps!
19th Mar 2012 10:34pm |
geezer Member Since: 27 Feb 2011 Location: Brissy Posts: 20 |
Use first all the time even if only brief without BAS ecu upgrade, otherwise clutch and or engine labours to much for my liking.
Varies between first and second with BAS ecu upgrade dependant on road gradient. |
21st Mar 2012 10:39am |
and no clutch problems in 3 years? Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
21st Mar 2012 4:45pm |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 |
21st Mar 2012 6:06pm |
