Home > My Defender > Puma to LT1/8L90 Restomod
Page 12 of 41 <123 ... 111213 ... 394041>
mrfirepro
United Kingdom 1996 Defender 90 300 Tdi HT Bonatti Grey
Hi Andy,
That’s from Nick at RW Engineering. I've asked for technical details a couple of times but nothing has been forthcoming. It seems Nick is overrun with work so I've spoken with Martin (futuranet) and he thinks he can put something similar together.
Martin has made no promises apart from he’s going to look at it.
I'm going to wait for Martin as I'm using the rest of his kit and it keeps it all together, plus it will probably be at least 6 months before I get anywhere near to thinking about the cluster.
Martins System controller will do everything else I need.
This is also the way I'm planning on integrating the TMPS into the display, via a can bus TPMS unit from tyrepal.
I wasn't very clear on integration between the GM ECU and LR systems. I'm removing the LR ECU and replacing it with the system controller from Futuranet, that will not only integrate the GM ECU via canbus but will also do all the other function that I need (ABS/AC, cluster etc etc..) If the remote display gets off the ground that will be able to show all the GM info as well as gears.
If anyone else is interested please give Martin a call as the more people that show interest the more chances it has of happening.
Post #889996 8th Mar 2021 8:19pm
Philip
Does the gearbox come with a standard tune for the supplied engine?
Post #890004 8th Mar 2021 8:40pm
mrfirepro
Turnkey provide a complete package and tune engine and GB to work specifically with the defender(thats there sales pitch anyway). They upgrade the CAM and tune for around 525BHP (think 450 is standard). They provide the complete package so that it's just plug and play my end, well that’s how the story has started let wait and see.
They run every package they sell to check it all works together, thus eliminating any gremlins that may be in any of the components or the loom.
Post #890008 8th Mar 2021 8:49pm
mrfirepro
Axles shot blasted and prepared and painted with EM121
Calipers and Rotors arrived, unfortunately the rotors are wrong they should have been fully floating so they have to go back....
Sorry not the best photos I was in a rush.
I've now blasted every single bracket, boxed up all the nuts and bolts ready to go off to the platers tomorrow.
Whilst I've not had that much to do I could get on with the fuel system, this is my outline design, I'd be happy to get any advice.....
Post #890047 8th Mar 2021 11:46pm
ay4alex
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Java Black
Whilst not helpful with the fuel query, that 996 GT2 is divine Twisted Evil Laughing
Build is looking stunning!
A 110 Tdci Double Cab
Post #890092 9th Mar 2021 8:50am
FD7
2006 Defender 90 V8 Petrol ST Auto Chawton White
Those brake discs do look good! Look great quality, hopefully you get on well with them!
Post #890123 9th Mar 2021 10:18am
Philip
Interested to see how it all works out - I was looking at the “budget” method of buying a pull-out driveline with an already-matched box.
Post #890163 9th Mar 2021 12:23pm
mrfirepro
a few changes to the fuel layout. AN-06 with 8mm hose was probably on the small side so now changed to the AN-08 with 11mm hose, which should be good for upto 650 BHP.
Post #890169 9th Mar 2021 12:39pm
mcma1
Pretty much all there is to it. The pressure gauge is a good idea. My recent regulator issue may encourage me to fit one. Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #890232 9th Mar 2021 4:31pm
Linds Hanson
Can you run the GM Corvette fuel filter then just have to run return to that?
Post #890275 9th Mar 2021 6:47pm
mrfirepro
Andy, where did you mount your regulator? engine/firewall?? any pics?
Post #890341 9th Mar 2021 11:31pm
mcma1
Mine is fitted in behind the cover plate in the rear driver side arch Andy
2014 Corris 110 SW
LS3 V8 build...
Post #890345 10th Mar 2021 2:59am
mrfirepro
Fitting up the rear axles with new stub axles.
The kit I've bought has got two gaskets one larger one with an ABS sensor cut out and a rather flimsy paper one with no abs cut out.
I'm using the ABS one (as I'm adding ABS) but it is bigger than the flimsy paper one and sticks out the sides of the flange.
It seems strange to have two gaskets of differing materials and sizes with different cut outs? Or gaskets for different models perhaps but why is the one with the ABS cut out soo much bigger?
Am I missing something???
Post #891583 15th Mar 2021 2:54pm
mrfirepro
Picked up the tub rails and bulkhead from the galvanisers
after Tank Kleen and t wash
After the britpart bulkhead removal bar debarcle tried the PPCages one and it fitted with no problems. So all the tub repairs are nearly done just left to fit the side rails and then EM121 to the base.
Post #891737 16th Mar 2021 8:11am
JOW240725
Wow! I love a bit of galv. Whilst I agree the bulkhead needs painting will the cappings be painted of left galv? Whistle James
Instagram @suffolk_rovers
Post #891758 16th Mar 2021 9:10am
