![]() | Home > My Defender > Puma to LT1/8L90 Restomod |
Philip Member Since: 09 Mar 2018 Location: England Posts: 510 ![]() ![]() |
Does the gearbox come with a standard tune for the supplied engine?
mrfirepro Member Since: 06 Nov 2020 Location: kent Posts: 233 ![]() ![]() ![]() |
Turnkey provide a complete package and tune engine and GB to work specifically with the defender(thats there sales pitch anyway). They upgrade the CAM and tune for around 525BHP (think 450 is standard). They provide the complete package so that it's just plug and play my end, well that’s how the story has started let wait and see.
They run every package they sell to check it all works together, thus eliminating any gremlins that may be in any of the components or the loom. |
Axles shot blasted and prepared and painted with EM121
![]() Click image to enlarge Calipers and Rotors arrived, unfortunately the rotors are wrong they should have been fully floating so they have to go back.... ![]() Click image to enlarge ![]() Click image to enlarge Sorry not the best photos I was in a rush. I've now blasted every single bracket, boxed up all the nuts and bolts ready to go off to the platers tomorrow. Whilst I've not had that much to do I could get on with the fuel system, this is my outline design, I'd be happy to get any advice..... ![]() Click image to enlarge |
ay4alex Member Since: 18 Feb 2009 Location: Midlands Posts: 328 ![]() ![]() ![]() |
Whilst not helpful with the fuel query, that 996 GT2 is divine
![]() ![]() Build is looking stunning! A 110 Tdci Double Cab |
FD7 Member Since: 16 Feb 2021 Location: Midland Posts: 179 ![]() ![]() |
Those brake discs do look good! Look great quality, hopefully you get on well with them!
Interested to see how it all works out - I was looking at the “budget” method of buying a pull-out driveline with an already-matched box. |
a few changes to the fuel layout. AN-06 with 8mm hose was probably on the small side so now changed to the AN-08 with 11mm hose, which should be good for upto 650 BHP.
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2938 ![]() ![]() |
Pretty much all there is to it. The pressure gauge is a good idea. My recent regulator issue may encourage me to fit one. Andy
2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 498 ![]() ![]() |
Can you run the GM Corvette fuel filter then just have to run return to that?
Andy, where did you mount your regulator? engine/firewall?? any pics?
Mine is fitted in behind the cover plate in the rear driver side arch Andy
Fitting up the rear axles with new stub axles.
The kit I've bought has got two gaskets one larger one with an ABS sensor cut out and a rather flimsy paper one with no abs cut out. I'm using the ABS one (as I'm adding ABS) but it is bigger than the flimsy paper one and sticks out the sides of the flange. It seems strange to have two gaskets of differing materials and sizes with different cut outs? Or gaskets for different models perhaps but why is the one with the ABS cut out soo much bigger? Am I missing something??? |
Picked up the tub rails and bulkhead from the galvanisers
![]() Click image to enlarge after Tank Kleen and t wash ![]() Click image to enlarge After the britpart bulkhead removal bar debarcle tried the PPCages one and it fitted with no problems. So all the tub repairs are nearly done just left to fit the side rails and then EM121 to the base. ![]() Click image to enlarge |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 ![]() ![]() ![]() |
Wow! I love a bit of galv. Whilst I agree the bulkhead needs painting will the cappings be painted of left galv?
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
