Home > Expedition & Overland > Henri the 110 goes pop top! |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10833 |
Thanks for the answer Tim, i just knew there must of been a purpose for your design there Clayton.
1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
7th May 2020 8:24pm |
Timcat Member Since: 20 Jul 2016 Location: Rugby at the moment Posts: 1025 |
Hi Tony, The pump is indeed a submersible ( Reich twin pump) it’s 18L per min & yes it serves three water points. One being the tap which is filtered potable water & then two shower points one rear panel & one off side back door for the quick pitch shower. The Bull finch shower points are mixers in their own rights so if you blank the hot water feed to them they become a basic flow switch from 18L per min to guessing 5L. Very impressed with how they work. |
9th May 2020 8:08am |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3481 |
Just glad you sorted the x member .... that was triggering me with such a lovely build 1951 80" S1 2.0
1995 110 300TDI 1995 90 300TDI |
9th May 2020 9:00am |
makes a difference a bit of paint.....
9th May 2020 10:54am |
Slowly getting there with the rear fit out, drawings are nearly there for the laser cutting.
Click image to enlarge Click image to enlarge |
9th May 2020 10:56am |
Outlaw1 Member Since: 11 Aug 2016 Location: east sussex Posts: 273 |
Nice work Timcat . Gone are the days of beer mats to draw on
9th May 2020 12:22pm |
kzycnn Member Since: 24 Apr 2009 Location: Northumberland Posts: 277 |
Tim
It would be interesting to see how it works and if you can get a suitable pressure at the Bull finch shower point. I use a 7 litre shurflo 20 PSI in-line pump with an accumulator and a couple of filters (sediment bowl attached to the pump and a separate 3M in line). These just feed a single tap and the flow rate at the tap is really poor. I had intended using a bull finch shower point as well but the flow at the tap is so poor I abandoned that idea! Water containers are a couple of NATO jerry cans which I've had for years. I put an inline pump in because the neck is a bit tight to get a submersible pump in (and create a seal ) Tony |
11th May 2020 10:07am |
Hi Tony, tried attaching a video but it won’t let me! Connected it up and it’s more pressure than my domestic shower at home, but it’s an 18L per min pump so more than double what you have at the moment.
Jim. |
11th May 2020 3:32pm |
Hi Tim
No worries, but thanks for the offer. I might have to get another pump . I should have done a bit more research when I got this one! I discussed it with Errol when I had the roof fitted but couldn't show him as I had stripped the inside out to make his life a bit easier! He had used a much juicier pump in his Defender (sold on already, when he did my roof) but I'd had a quick demo. at an earlier overland show - just didn't know (then) what size pump he had |
11th May 2020 4:05pm |
So, rear o/s gull wing out & panel fabricated up a roughly fitted drilled ect to accept Peli 1720 case. It’s a good fit & suits our needs holding a service kit & recovery kit. That’s off to be powder coated now.
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge It’s 155mm out from the side of the truck ( so probably 20-30mm further out than the rocksliders shower awning ect) |
15th May 2020 7:10am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17519 |
I like that, very neat, could have been designed for the job!
I think I would be inclined to fit a couple fo stays to the peli to hold the lid horizontal when opened (to act as a sort of tray, and also probably a bungee running the length of it so that if I had to open it with the vehicle on the tilt it stops everything falling out. it's the testosterone-rich version of the hairdryer box on the new Discovery Defender! |
15th May 2020 8:24am |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2117 |
that looks really good and practical - love the idea and may ‘adapt’ it for Poppy!
Thinking of possibly using 2 boxes on that side mounted on air rails rather than one long box. - but still just thinking ! Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
15th May 2020 11:01am |
Whirly90 Member Since: 01 Sep 2016 Location: Ampshire Posts: 407 |
I had the same idea myself but wanted to see what it looked like first, now i've seen one in place i'm happy that it's a great idea
15th May 2020 12:05pm |
Good points Blackwolf, ordered a couple of stainless stays & have a couple of stainless steel bimmi hooks that will accept a 25 mm cam strap to run from left to right. |
23rd May 2020 2:08pm |
