Home > Expedition & Overland > Henri the 110 goes pop top!
Page 17 of 17 <123 ... 151617
Timcat
United Kingdom 2012 Defender 110 Puma 2.2 SW Indus Silver
All done Gary, new genuine Landrover ( re-con) turbo / egr blanked the garage also found the diesel leak which turned out to be a split inlet manifold blowing up onto the LP drain off pipe.
Dropped the oil today / greased props / dropped the diff oil & will do the box & transfer box when I can get some oil.
Apart from that not a lot been going on!!
Post #984830 8th Mar 2023 1:17pm
wyvern
Thumbs Up
Fabulous - you can do the same on mine if you like .... !!! Rolling with laughter
Fingers crossed for a long run now with minimal hiccups Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #984833 8th Mar 2023 1:49pm
I'm glad you've finally found the cause of the fuel leak.
Post #984855 8th Mar 2023 5:12pm
Timcat
I’m getting the mechanic a bottle of scotch! I think the crack has opened up as it is spraying under the LP drain off hose more now.
Temporary fix with putty ( the guys have managed to find a used one for £100.00) a new one is £350.00 ish here.
Post #984933 9th Mar 2023 1:32pm
Have you figured out how it is that there is fuel in the inlet manifold in the first place, since if it is being blown out of the manifold it must be in there to start with. Since the engine is direct injection there should never be fuel in the inlet manifold.
There may well be oil mist from the crankcase breather, and all manner of nasty stuff from the EGR, but there should not be fuel.
Post #984945 9th Mar 2023 3:07pm
Timcat
Your smack on, as it was a mist on the underside of the bonnet & appeared to be coming from the LP return I took it as diesel.
As you say I think it’s residue from the crank case breather. Booked in for Monday second hand manifold going on (£100 + labour)
Todays job gearbox & transfer box oil change. The 5L is empty for what comes out.
Post #984993 10th Mar 2023 7:32am
Timcat
Back in Botswana! Everything done, new boxes fitted ( snazzy double hinge design on the back one) and finally got the compressor fitted & hard wired in the side box!
Post #986155 20th Mar 2023 10:54am
wyvern
looking fabulous!!
What a great place for smelly trainers !! (the box would be worth it for that job alone with our running and cycling shoes!)
Ive just purchased the same pump for fitting some time in the summer - probably going into the loo box as there is a bit of dead space there and its close to the batteries etc ... air hose outlet access will be from the passenger side - not as professional as yours though !
Thumbs Up Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #986159 20th Mar 2023 11:20am
Timcat
Professional!! Camp site install Rolling with laughter Rolling with laughter Just be careful the compressor gets silly hot depending on how much you use it!
Another little tip, pull the feed off the switch that illuminates it constantly & leave the one that illuminates it when on. Saves killing the battery.
Post #986170 20th Mar 2023 12:30pm
Timcat
After the Optima yellow top only lasting 12 months we now have a lithium leisure battery & a NLDC-25 dc-dc charger & solar controller made by National Lunar including their LCD Display.
A lot of guys here in Namibia run these as they are super compact & don’t suffer from heat problems like the Victron dc-dc unit.
Had it professionally fitted which took a long time due to having to cut the D44 tray as the lithium battery was 2mm too big!
Also had a custom brace made to secure them down which accounts for the difference in height ( photo shows the old strap)
Labour all in was £250.00 inc fab work & took 8 hrs.
Post #990867 30th Apr 2023 9:41am
Timcat
As you can see the battery box is 46 deg C & it wasn’t a particularly hot day!!
Post #990868 30th Apr 2023 9:42am
wyvern
Yikes! Shocked
The optima didn't last long!
Ive gone with a cheap 110am hr battery which has been excellent over the last few years - my thoughts were that I could buy 4 for the price of one optima ..
Not gone down the lithium route yet but am going to be watching how you get on with interest !
Post #990923 30th Apr 2023 8:04pm
Timcat
The 100ah lithium gives 3+ times the power of the AGM yellow top & half the weight! The yellow top in SA was £350.00 & the lithium in Namibia was £450.00 no brainier really for us.
1st impressions are why didn’t we do this in the 1st place?
Post #990952 1st May 2023 5:26am
