Home > Expedition & Overland > Henri the 110 goes pop top!
Page 5 of 17 <123 456 ... 151617>
kzycnn
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
Tim, that looks very good - I'm impressed. I like the look of your water containers. I haven't seen these before so have googled them Smile . Are you using a submersible pump? If so, is it also connected to the shower attachment you have by the back door? I would be interested to know what the flow rate is you're getting at each of the taps?
Thanks.
Tony
Post #829511 6th May 2020 1:52pm
L110CDL
Thanks for the answer Tim, i just knew there must of been a purpose for your design there Thumbs Up Clayton.
Keeper.
Post #829767 7th May 2020 8:24pm
Timcat
United Kingdom 2012 Defender 110 Puma 2.2 SW Indus Silver
Thanks.
Tony
Hi Tony,
The pump is indeed a submersible ( Reich twin pump) it’s 18L per min & yes it serves three water points. One being the tap which is filtered potable water & then two shower points one rear panel & one off side back door for the quick pitch shower.
The Bull finch shower points are mixers in their own rights so if you blank the hot water feed to them they become a basic flow switch from 18L per min to guessing 5L. Very impressed with how they work.
Post #830021 9th May 2020 8:08am
familymad
Just glad you sorted the x member .... that was triggering me with such a lovely build Rolling with laughter 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #830032 9th May 2020 9:00am
Timcat
makes a difference a bit of paint.....
Post #830063 9th May 2020 10:54am
Timcat
Slowly getting there with the rear fit out, drawings are nearly there for the laser cutting.
Post #830064 9th May 2020 10:56am
Outlaw1
England 2010 Defender 110 Puma 2.4 USW Santorini Black
Nice work Timcat . Gone are the days of beer mats to draw on
Post #830072 9th May 2020 12:22pm
kzycnn
Tim
Quote:
Hi Tony,
It would be interesting to see how it works and if you can get a suitable pressure at the Bull finch shower point. I use a 7 litre shurflo 20 PSI in-line pump with an accumulator and a couple of filters (sediment bowl attached to the pump and a separate 3M in line). These just feed a single tap and the flow rate at the tap is really poor. I had intended using a bull finch shower point as well but the flow at the tap is so poor I abandoned that idea! Water containers are a couple of NATO jerry cans which I've had for years. I put an inline pump in because the neck is a bit tight to get a submersible pump in (and create a seal Very Happy )
Tony
Post #830444 11th May 2020 10:07am
Timcat
Hi Tony, tried attaching a video but it won’t let me! Connected it up and it’s more pressure than my domestic shower at home, but it’s an 18L per min pump so more than double what you have at the moment.
Jim.
Post #830483 11th May 2020 3:32pm
kzycnn
Hi Tim
No worries, but thanks for the offer. I might have to get another pump Sad . I should have done a bit more research when I got this one! I discussed it with Errol when I had the roof fitted but couldn't show him as I had stripped the inside out to make his life a bit easier! He had used a much juicier pump in his Defender (sold on already, when he did my roof) but I'd had a quick demo. at an earlier overland show - just didn't know (then) what size pump he had Rolling with laughter
Post #830492 11th May 2020 4:05pm
Timcat
So, rear o/s gull wing out & panel fabricated up a roughly fitted drilled ect to accept Peli 1720 case. It’s a good fit & suits our needs holding a service kit & recovery kit. That’s off to be powder coated now.
It’s 155mm out from the side of the truck ( so probably 20-30mm further out than the rocksliders shower awning ect)
Post #831167 15th May 2020 7:10am
I like that, very neat, could have been designed for the job!
I think I would be inclined to fit a couple fo stays to the peli to hold the lid horizontal when opened (to act as a sort of tray, and also probably a bungee running the length of it so that if I had to open it with the vehicle on the tilt it stops everything falling out.
it's the testosterone-rich version of the hairdryer box on the new Discovery Defender!
Post #831181 15th May 2020 8:24am
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
that looks really good and practical - love the idea and may ‘adapt’ it for Poppy!
Thinking of possibly using 2 boxes on that side mounted on air rails rather than one long box. - but still just thinking !
Thumbs Up Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #831206 15th May 2020 11:01am
Whirly90
England 1993 Defender 90 300 Tdi HT Keswick Green
I had the same idea myself but wanted to see what it looked like first, now i've seen one in place i'm happy that it's a great idea Thumbs Up
Post #831215 15th May 2020 12:05pm
Timcat
Good points Blackwolf, ordered a couple of stainless stays & have a couple of stainless steel bimmi hooks that will accept a 25 mm cam strap to run from left to right.
Post #832890 23rd May 2020 2:08pm
