Home > Puma (Tdci) > Output shaft failure, Forum Survey
Page 11 of 35 <123 ... 101112 ... 333435>
mark_d
2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Post #792075 11th Sep 2019 11:32am
Devon-Rover
United Kingdom 2014 Defender 110 Puma 2.2 USW Aintree Green
Devon-Rover wrote:
1) 2013 (2014MY designation)
2) 2.2
3) Y
4)33630
Due to Gbox oil leak I was able to asses the shaft. It was 'greased' at circa 20K at the local main dealer when they did the engine oil leak under warranty. and TBH It was mainly dry with some powder rust marks and only a small amount of something that looks like silver slip on it. The picture shows it after cleaning up. I have thoroughly re-greased it and reassembled, as the splines look fine.
Update
2) 2.2
3) Y
4)52225
As of yesterday this WAS in the motor and it is looking just as good as it went in previous when I greased it. Probably a just perceptible amount of play but it was still functioning fine.
Now been replaced with a LOF one piece shaft. No more worries here I hope.
Thumbs Up Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #859719 4th Oct 2020 11:41am
Naks
1, 2010
2, 2.4
3, Y
4, 82850km
Seeing that the transfer case needed to come out for some TLC due to a slow leak, I decided to do the Ashcroft upgrade and some other bits:
Original parts:
Ashcroft kit:
Major improvement in the gearchanges, and little to no drivetrain clunking. Thumbs Up --
Post #860026 6th Oct 2020 8:22am
nitram17
spudfan wrote:
2008 Puma. 170,000+ kms. Still on original shaft.
the simple fact you have done that mileage on the same shaft must prove its the fit thats the problem and not the design!
Post #883767 7th Feb 2021 2:21pm
My original factory-fitted shaft has now done 250k miles. This is also with two different LT230s, suggesting that (as I have suggested before) any alignment issues are likely to be with the extension housing and not either gearbox.
It'll probably fail now I've said that though! Big Cry
Post #883777 7th Feb 2021 2:58pm
spudfan
Ireland
Our 2008 Puma still on it's origional shaft. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #883778 7th Feb 2021 3:00pm
Julie
... that simple fact would have been proven, if the Ashcroft shafts failed since their only improvement is lubrification.
Misalignement rules them out.
Only time will tell
Post #883788 7th Feb 2021 3:57pm
Co1
2013, 78,000 miles.
Post #883882 8th Feb 2021 7:06am
david110
Scotland 2015 Defender 130 Puma 2.2 HCPU Santorini Black
Evening, in the middle of the process, I'm fitting the Ashcroft shaft kit. It's the first time it failed and I've owned the 130 from new
Land Rover defender 130
2015
55600 miles
2.2 tdci
Removed the transfer box this evening and expecting Ashcroft kit tomorrow, looking forward it the rebuild tomorrow evening and then a road test😀
Post #885792 16th Feb 2021 12:37am
dgardel
Italy
Same here with 142000km and 180HP Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #885805 16th Feb 2021 7:54am
Eduardo
Mine still OK after 350.000 km
2.4 MY 2007 Eduardo
Post #888041 26th Feb 2021 11:06pm
Shorty53
United Kingdom 2012 Defender 90 Puma 2.2 XS CSW Santorini Black
2012, 2.2, 90, 22,152
Post #888204 27th Feb 2021 10:24pm
nitram17
Do you think if you use the lof shaft to replace a broken shaft and it is as you say a alignment issue ..will it move the problem up or down the drive train?
Post #888222 28th Feb 2021 12:18am
Yes, quite possibly. Rolling with laughter
Sorry, not the answer you were looking for. Who knows, I think it depends on many factors including the fit of the LOF shaft on the gearbox tailshaft splines and the flexibility of the LOF adaptor shaft, as well as how much engineering analysis went into the product. It may even eliminate the problem, only time will tell.
Post #888226 28th Feb 2021 12:59am
nitram17
I dont know if we will ever know for certain!
Post #888228 28th Feb 2021 1:08am
