![]() | Home > Puma (Tdci) > Output shaft failure, Forum Survey |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 584 ![]() ![]() ![]() |
I find it quite remarquable, that there was - in fact - some sort of knocking sound when I was in the Alpes mountains mounting serpentine roads with changing rpm and many many load changes, too. The knocking occured in non loaded situations in 180° curves.
I've never been able to reproduce that sound. But, the very same day, the spline failed 2...3 hours later. And it did not fail under load but driving down a 180° curve. When I wanted to réengage the clutch after the curve, the spline didn't have any more contact. I had the truck towed by another 4x4 That strange knocking sound came from the drivetrain and it began a few days before, but occasionally. I concluded that - once @home - I had to check the drivetrain what I've never done and even forgotten after the installation of the new spline. |
