![]() | Home > Puma (Tdci) > Output shaft failure, Forum Survey |
mark_d Member Since: 07 Sep 2013 Location: Northern Ireland Posts: 266 ![]() ![]() |
2010
2.4 N 30K miles http://defender90xs.blogspot.co.uk/ |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2669 ![]() ![]() ![]() |
1, 2010
2, 2.4 3, Y 4, 82850km Seeing that the transfer case needed to come out for some TLC due to a slow leak, I decided to do the Ashcroft upgrade and some other bits: ![]() Click image to enlarge Original parts: ![]() Click image to enlarge Ashcroft kit: ![]() Click image to enlarge ![]() Click image to enlarge Major improvement in the gearchanges, and little to no drivetrain clunking. ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
the simple fact you have done that mileage on the same shaft must prove its the fit thats the problem and not the design! |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17704 ![]() ![]() ![]() |
My original factory-fitted shaft has now done 250k miles. This is also with two different LT230s, suggesting that (as I have suggested before) any alignment issues are likely to be with the extension housing and not either gearbox.
It'll probably fail now I've said that though! ![]() |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4761 ![]() ![]() |
Our 2008 Puma still on it's origional shaft. 1982 88" 2.25 diesel
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 571 ![]() ![]() ![]() |
... that simple fact would have been proven, if the Ashcroft shafts failed since their only improvement is lubrification. Misalignement rules them out. Only time will tell |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3706 ![]() ![]() ![]() |
2013, 78,000 miles.
david110 Member Since: 11 Dec 2009 Location: Stirlingshire Posts: 81 ![]() ![]() ![]() |
Evening, in the middle of the process, I'm fitting the Ashcroft shaft kit. It's the first time it failed and I've owned the 130 from new
Land Rover defender 130 2015 55600 miles 2.2 tdci Removed the transfer box this evening and expecting Ashcroft kit tomorrow, looking forward it the rebuild tomorrow evening and then a road test😀 |
Same here with 142000km and 180HP Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 ![]() ![]() ![]() |
Mine still OK after 350.000 km
2.4 MY 2007 Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Shorty53 Member Since: 17 May 2013 Location: Lancashire Posts: 135 ![]() ![]() ![]() |
2012, 2.2, 90, 22,152
Do you think if you use the lof shaft to replace a broken shaft and it is as you say a alignment issue ..will it move the problem up or down the drive train? |
Yes, quite possibly.
![]() Sorry, not the answer you were looking for. Who knows, I think it depends on many factors including the fit of the LOF shaft on the gearbox tailshaft splines and the flexibility of the LOF adaptor shaft, as well as how much engineering analysis went into the product. It may even eliminate the problem, only time will tell. |
I dont know if we will ever know for certain!
