Home > My Defender > An Anorak's Utility Station Wagon
Page 32 of 57 <123 ... 313233 ... 555657>
In principle, yes. Whilst there are pre-drilled holes in the cill rail, it would be simple enough to drill new ones for a different position. For the chassis brace, you drill the hole to suit anyway. The only obstacle is the bracket for the trailing arm, which would limit the position to either side of it. Darren
Post #827719 26th Apr 2020 9:16am
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Thumbs Up
Post #827720 26th Apr 2020 9:27am
L110CDL
Great update and very detailed as ever LRA Thumbs Up
Liking the steps on the 110 Very Happy Clayton.
Keeper.
Post #828078 27th Apr 2020 9:36pm
Headight Surrounds Revisited
This has been covered in it's own separate thread but is included here for completeness.
Sooo, in a fit of lockdown boredom, I thought I'd experiment with the look of the front end. I bought a cheap set of aftermarket headlight surrounds (Allmakes), which come with a sort of stippled finish. However, as self-coloured surrounds have a tendancy to fade to grey, I thought I'd paint them satin black to match the grill. I sanded one back to smooth with a succession of finer emery papers to create a surface that could be painted. It was then primed with plastic primer and then two coats of regular grey primer and three of black satin, flatted back with fine emery paper between each coat. Finally, it was given a couple of coats of clear lacquer, which has produced what I hope will be a tough satin finish.
I fitted one panel to see what it would look like and to gauge reaction:
With only a couple of dissenting voices Laughing I prepped and painted the other side:
I'm very pleased with the result...until I get bored again Whistle Darren
Post #829005 3rd May 2020 9:53am
Rear Crossmember
Partly inspired by all of the lockdown projects on here and Instagram and partly as prep for something else in the near future, yesterday I cleaned and repainted my rear crossmember.
The starting point wasn't too bad, to be honest. There were a couple of very small surface rust patches on some of the edges but nothing significant. The paint had chipped off the galvanised grab handles though, so better prep needed for them next time!
With everything masked off, I rubbed down those areas that warranted it. I was shocked but not surprised to discover just how thin the original paint was, with bare metal revealed by the lightest touch of sand paper Shocked
The bare patches were treated to a coat of etch primer:
Followed by a couple of coats of grey primer, with each flatted off with 800 and 1200 grit wet and dry:
Three coats of satin black followed with the same treatment between coats, and then two coats of clear lacquer to finish it off:
A very satisfying outcome Cool
 Darren
Post #829009 3rd May 2020 10:11am
Stainless Steel Bolts - Body to Rear Corssmember
Whilst prepping for painting the rear crossmember, I removed the six body to crossmember bolts beneath the rear door to make masking up easier. After the painting was finished, I decided to swap all ten of those bolts for stainless equivalents.
The original bolts are M8 x 25mm torx head with a largish washer. To replace them, I've used the same size stainless button head bolts together with a stainless washer and a matching nylon washer to go underneath. This is to isolate the stainless steel from the alloy body and prevent bimetallic corrosion:
Each bolt was also given a coating of Duralac to aid with that isolation, although as they clearly screw into steel captive nuts, that's probably overkill:
The finished result has a neat appearance and won't go rusty, which is nice Smile
 Darren
Post #829011 3rd May 2020 10:21am
L110CDL
Re: Headight Surrounds Revisited
Loving that look Darren, much better ( imo ) Bow down
Also liking the good work done on the rear cross member Thumbs Up Clayton.
Keeper.
Post #829116 3rd May 2020 9:46pm
Thanks, Clayton Very Happy Still lots to do but the better weather is helping. Darren
Post #829151 4th May 2020 9:03am
Side Steps Corrosion Protection
Having gone to a lot of trouble to replace all of the fixtures on my new side steps with stainless equivalents, I also wanted to do what I could to protect the steps themselves from corrosion. To that end, I've sprayed them with Dinitrol 4010 Corroheat.
This product is really intended for use on things like engine blocks as it's designed to be high temperature resistant, but its' useful property for my side steps is that it's clear. This makes it ideal for coating finished surfaces such as the powder coating on the steps. It dries with a sort of waxy finish, which will be fine for this application.
 Darren
Post #829910 8th May 2020 4:24pm
Dog Guard
A relatively easy mod today, to fit a new dog guard, although there was a bit of a saga to get this point.
When I bought my 110 it was fitted with a perfectly serviceable, genuine Land Rover, full height dog guard, which I promptly took out and sold. You see, I thought I had a better idea: some years ago on my previous TD5 station wagon, I built a bulkhead behind the rear seats and fitted a standard hardtop dog guard to it. I was really pleased with it as it was a very practical arrangement and I thought I’d replicate it on this Land Rover. That though, it turned out, was a mistake.
I bought a suitable dog guard at Newbury some time ago and also bought a set of pre-Puma rear side trims. The latter were an experiment to see if I could free up some space as the standard Puma trims are very bulky, designed as they are to accommodate forward facing seats in the regular station wagon. However, the trims wouldn’t fit as the second row seat belt mounts are positioned differently, and the dog guard wouldn’t fit between the bulky Puma side trims so I was back to square one!
I’m not that keen on the LR dog guard as it’s also quite bulky. Thick tubes, closely spaced mesh and a black finish make an already dark interior even worse. Casting around for an alternative, I came across the offering from Travall. This one is a lighter construction, both in materials and colour as it uses wider spaced mesh and is finished in grey. It’s also much cheaper directly from their website, which was a pleasant surprise 😊
Apart from the two mesh panels, the kit comprises six brackets, ten thumb turn bolts and a couple of Torx bits to undo existing fixings. Unfortunately, one of those was the wrong size but it was a good effort.
Installation is quite straightforward. Firstly, two small brackets are installed under two existing fixings that secure the plastic trim around the rear seat floor locking mechanism. These fixings are the ones for which the wrong Torx bit was supplied.
Two more brackets are bolted to the strengthening webs at the front of the rear tub. Again, these use existing fixings, where the second Torx bit is required:
The final two brackets are installed beneath the ends of the high level grab handles, above and behind the seat backs. These also use existing fixings, which in this case are largish self-tappers. Whilst this works ok, next time I take the trims off (which is on the cards for another little project) I plan to install some rivnuts and use some pan head machine screws in this location. I’ve had these trims off several times already and the self-tappers aren’t as secure as they once were.
With all of the brackets in place, installing the dog guard panels is quite easy, using the thumb turn bolts. I left the bracket fixings slightly loose until the panels were secure and then tightened them all up afterwards, which made lining everything up slightly easier.
The finished article feels nice and strong and doesn’t seem to creak or rattle, which is a bonus.
My only real criticism is that it’s positioned a bit further away from the rear seats than I would have liked. There’s probably in the region of 100mm clearance behind the head rests and quite a bit more behind the seat bases. Although not quite enough for my trolley jack in its’ case Rolling Eyes
In due course, I’ll make some brackets to secure various stuff to the guard. In particular, I’m thinking of typical roadside kit such as triangle, wheel brace, chocks, etc. I’ll mount these on the front side, behind the seats, so that they’re easily accessible by tipping a seat forward rather than being buried in a box in the back. Darren
Post #830796 12th May 2020 10:21pm
Argee
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
Nice truck.
I've got this dog guard in my 110 CSW - intrudes into the leg room for the rear forward facing seats so much in standard trim that it makes them unusable. It also requires the removal of the whole dog guard if you want to fold the middle row seats forward for more load space.
My solution was to have a local engineering firm make me up a stainless steel up and over bulkhead bar to replace the upper part of the lower grill, using all the same fixing points (bar the underseat ones) but slotted at the two bottom body fixings. This allows enough adjustment to move the guard forward to meet the back of the middle row seats, leaving enough room for rear seat passengers.
This set up also allows longer items to be carried with the middle row seats folded forward, without removing the dog guard.
Seems to stiffen the body a bit too, less creaking on cornering.
An added bonus is that with a few bits of bracketry I can use the now redundant bottom part of the guard as a load space shelf for bedding and clothes when we go camping Thumbs Up
I'll get some pics later if anyone's interested.
Rich
Post #830871 13th May 2020 1:33pm
Hi Rich,
Yeah, always interested in pics of different ideas.
I obviously don't have to worry about rear seats in mine but having thought about it a bit, I may well adapt some of the brackets to alter its' position relative to the middle row seats slightly, just to make better use of the space behind them. Darren
Post #830886 13th May 2020 2:30pm
Argee
Photos as promised, on the drag because flat out at work, sorry.
I lied about the slots at the bottom, that was the early plan A, the fabricator wasn't happy with that idea as he wanted to engineer it spot on. Nice to find someone who takes pride in their work.
Post #831202 15th May 2020 11:31am
Interesting, thank you. It's a sort of virtual bulkhead - the opposite of a bulkhead removal bar Laughing Darren
Post #831213 15th May 2020 12:57pm
Argee
Exactly! Thumbs Up
Post #831258 15th May 2020 5:29pm
