Home > My Defender > An Anorak's Utility Station Wagon
Page 11 of 57 <123 ... 101112 ... 555657>
Tiger
Loving the work Thumbs Up
Post #723075 12th Aug 2018 4:48pm
Auxillary Electrics Pt 5 - Wiring
So, after what seems like an age and many, many hours in a hot garage, I've finally finished my box of electronic tricks for switching on a few lights Rolling Eyes And it works, mostly. More of that later though - here's how it came together:
Much fiddly wiring, head scratching and scribbling notes on wiring diagrams went into completing the panel itself, which also got upholstered in the process.
The eagle-eyed will have spotted a second connector that wasn't in earlier pictures. This was necessary as I realised that attaching the switch box and taking it apart again if I ever needed to, would be a nightmare without it. The other end looks like this:
There are still a couple of wires that are simply connected via a small scotch block, which is because the switch they're connected to is supposed to be mounted in the dash and will eventually be moved.
On the vehicle itself, I fitted an adapter to the stop/tail light to tee off a feed from each that will drive relays as part of the automatic function for the rear work lights.
Along with that, the main power feeds from the bus were installed and the various earths connected, completing the wiring behind the rear speaker:
With all of that in place, all of the wires from the various lights and other feeds were brought together to create an umbilical finished with the matching connector, that would enable the panel to be easily removed:
And with the trim back in place, this is all that’s visible:
The final bit of wiring was the main connection to the second battery, which made the bus bar permanently live:
And so with everything live, the panel was plugged in and fixed in place with black nylon set screws:
And here’s a close-up of the finished control box:
Top left is a push-to-make switch for the voltmeter, i.e. the meter is only active when the button is pressed. It didn’t seem worth having it powered all of the time.
Top right is the momentary switch for the USB socket, which is the larger of the two on the front face of the control box.
Middle left is the momentary switch for the rear work lights and middle right is the automatic function isolator, which as mentioned above, will eventually be re-located to the dash.
The automatic function is one that I originally dreamt up for my old 90 and uses two relays and feeds from the side and reverse lights. It means that the work lights only turn on automatically when I select reverse and the side lights are on, i.e. when it’s dark. Unfortunately however, that arrangement isn’t road legal despite being really useful, so this incarnation includes an isolator that allows me to disable it.
The isolator switch started out as a regular ON/OFF switch as used for the heated rear screen and spotlights but has been modified to provide an ON/ON function. The reason for this is that I wanted a switch that would effectively turn off a relay whilst turning on a warning light to remind me that it was isolated. With an ON/ON switch, I could connect the common to earth, one input to the earth of the aforementioned relay and the other input to an ignition live feed serving the warning light. I'll explain the switch modification elsewhere.
The momentary switch for the work lights is really what started the whole process for this design. By using that type of switch to drive a latching relay, I can have more than one switch performing the same function in different locations. Basically, I can fit a duplicate switch on the dash that will enable me to switch the lights on from the rear and then turn them off from the front, or visa versa, without having to worry about the switches being either ‘on’ or ‘off’. The circuit includes a relay driven by the brake lights that cuts the power to the latching relay when the brake pedal is pressed. This re-sets that relay and turns the lights off, meaning it’s all but impossible to drive any distance with the work lights left on.
The lights themselves work really well, although I’ve aimed them down slightly since I took this picture:
Back to the control box, bottom left is the momentary switch for the LED load space light shown earlier in the thread.
Bottom right is another momentary switch for the Hella socket, also on the front face of the control box.
So, essentially, it all does exactly what I intended. There are, however, a couple of problems. As mentioned above, the use of momentary switches and latching relays was driven by the specific control requirement for the work lights. That, coupled with picking up some momentary fog light switches for 7p each is the reason why I’ve used the same arrangement for the other functions. What I didn’t predict though, is that the LR switches don’t actually work very well as momentary switches. They’re really ‘passing contact’ and the sensitivity of the latching relays that they’re connected to means they sometimes ‘double-click’ and don’t turn off. Some are better than others – the USB switch works all of the time whilst the work light switch works about 1 in 3 times, for example.
As the work light function is the only one that really needs to be momentary, the solution is to swap that one for a reliable body and change the others to regular ON/OFF switches, dispensing with the latching relays. I’ll have to live with it for a little while though, as I’m off on holiday in it next week.
The other minor issue concerns the backlighting for the switches. I’d taken a feed from the interior lights automatic function with the idea that the switches would light up for a few minutes when the door was open. However, I completely forgot that that feed is a switched earth rather than power and so it doesn’t work. I’ll have to come up with a different cunning plan for that another time Rolling Eyes Darren
Post #723236 13th Aug 2018 3:10pm
L110CDL
Thank you for the detailed up date, the wiring you do is always so neat, would put mine to shame Embarassed
Good that you got it nearly all working, but that will come in time after you have have had a Idea
Once again, thanks, great read Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #723320 13th Aug 2018 9:20pm
Gwyn Lewis Mud Shields
Last week I had my 110’s chassis Dinitrolled by Zagato of this parish, which I’m really pleased with.
To make the most of the protection, over the last couple of days I’ve fitted a complete set of Gwyn Lewis mud shields to protect the front outriggers, the rear crossmember and the front of rear wheels centre crossmember. These kits are great – well engineered and with nice, clear instructions unlike a lot of aftermarket accessories.
I’d previously ordered and fitted these shields to my old 90 but as an added bonus this time, I arranged to collect them from the man himself:
The kit to protect the front outriggers is quite straightforward and obviously universal with regards to wheelbase:
In standard trim, this outrigger and the bulkhead footwell are exposed to everything thrown up by the front wheel, with the mud flap being fitted to the bottom face:
The new shields use three existing holes that are occupied by two screws and a plastic rivet, all of which are replaced with stainless speed screws. They are positioned behind the lower edge of the wheel arch liner, like so:
Fitting these ones is quite easy and is best done with the front wheels on full lock pointing away from the side being worked on.
Compared to a 90, the rear shields for a 110 are quite a lot more involved. The kit to protect the centre crossmember comprises four panels and more speed screws but there are no existing holes to use this time, with everything needing new ones drilled.
In addition, if fitting to a Puma or TD5, one of the panels has to be cut down to clear the fuel filter housing. To make this easy, the shield has a cut line milled into the rear face:
After offering the shields up, all of the holes can be drilled and I gave them all a squirt of Dinitrol before final fitting:
And with both pieces fitted:
The kit to protect the rear crossmember is more complicated again and includes various pieces of steel hardware. All of those parts are galvanised and all of the fixings are stainless:
The kit includes replacement, much more substantial, diagonal body stays along with replacement mud flap brackets, which are designed to be removeable. The original brackets are removed and discarded as part of the installation. The kit also includes a reinforcement piece for the bottom edge of the outer bodywork.
I bought this particular kit from a member on here, who'd already painted the mud flap brackets black so they didn't stand out so much. I just gave them a clean up and another couple of coats before fitting.
The two large brackets at the top of that picture get bolted to the underside of the tub and so I made some rubber gaskets to separate them from the aluminium:
I also made some gaskets for where the diagonal body stay fixes to the edge of the tub but forgot to take photos.
As the supplied instructions are so clear, I won’t go into a lot of detail about the fitting process. Suffice to say that it’s necessary to drill two holes in the tub to fix the bracket mentioned above. The kit includes some M6 hex head stainless bolts for this purpose but I replaced them with button head versions as they were less intrusive on the surface of the tub. I cut small circles out of the sound insulation and incorporated some nylon washers to separate the fixing from the aluminium body. Eventually, I expect them to be hidden under carpet:
This is the fixed guard in place, which on the off side also protects the fuel filler:
And the mudflap on its’ new bracket below:
The original mud flaps are re-used but cut down to suit the new brackets:
I fixed some sticky back closed cell foam to the bracket where it is mounted on the uprated diagonal body stay, partly to make the anti luce pins a better fit and partly to stop it rattling:
Which fits like so:
On the near side, the process is exactly the same except that the fixed guard is shaped to fit around the exhaust. I also had to trim the inner edge of this guard slightly, to accommodate a pair of large electrical conduits that pass through this area:
It’s also necessary to trim the mud flap to clear the exhaust:
On their new brackets, the mud flaps are about 4-5 inches further forward than their original position and also slightly further out. I was initially a bit concerned about the latter but, in fact, they end up pretty much in line with the wheel arches and are better placed to cover the tyres:
I’m now confident that the chassis and various other components are about as protected as it’s practical to do. Darren
Post #727189 4th Sep 2018 8:52pm
One Piece Rear Half Shafts
Whilst I had the wheels off to fit the mud shields, I also took the opportunity to fit my recently acquired one piece rear half shafts:
I gave the end caps several coats of paint to protect them from the elements and they were fitted with galvanised, 12.9 cap head bolts and matching spring washers, all torqued to 65Nm.
Initial impressions after a short test drive is that they've definitely reduced driveline play, despite only recently fitting new drive members to the original shafts. Darren
Post #727193 4th Sep 2018 9:03pm
seriesonenut
Hi
I have just fitted a set of the rear crossmember guards but mine are set almost up against the rear crossmember
mud guard by Richard Holmes, on Flickr
I like the guards you have fitted which sit much closer to the rear wheels. Looking at the Gwyn Lewis web site I cant see the type you fitted listed. Is that where they originally came from?
Thumbs Up 1984 One-Ten CSW
2010 XS USW (sold)
1957 Series One 88 diesel
1958 Series One 88 4x2
Post #727198 4th Sep 2018 9:16pm
I'm guessing you've fitted the GL1012 kit? The one I've fitted is GL1003, described as 'Defender 110 Rear Mud Flap Mounting Kit and Shields, Stepped Tub'.
https://gwynlewis4x4.co.uk/product/defende...ub-gl1003/ Darren
Post #727201 4th Sep 2018 9:34pm
seriesonenut
Thanks. I thought this was just the mud flap kit but now I see it includes the shields. Looks like I'll end up with double protection! Rolling with laughter 1984 One-Ten CSW
2010 XS USW (sold)
Post #727203 4th Sep 2018 9:42pm
The shields that you've got work really well on a 90 so I expect you'd be able to sell them on. Darren
Post #727204 4th Sep 2018 9:44pm
Just a quick update on the half shafts: I've now done a few more miles and can honestly say they have transformed the way it drives. The first clue was the absence of a small metallic 'clonk' - like somebody gently tapping the axle casing with a small hammer - when changing from first to reverse. On the road though, particularly after it had warmed up, it's lost virtually all of the driveline shunt that was previously evident when changing down a gear and applying power, so I'm very pleased indeed.
I replaced the rear axle drive members about 2000 miles ago and whilst they did improve things, the difference was no where near as great as this time. There's no obvious, visible wear to the old half shaft splines but there clearly must be enough to cause such noticeable symptoms. Darren
Post #727474 6th Sep 2018 7:27am
Rkcorry
Excellent work Darren, Im now reading this thread backways, but thats nothing new.
Can i ask you were you sourced the single piece shafts.
Do keep up the good work.
Post #727540 6th Sep 2018 12:06pm
Thanks Smile
I struck very lucky on eBay for the half shafts - I think I paid about £150 for something that's around £6-700, new. Darren
Post #727542 6th Sep 2018 12:13pm
Front Mud Flaps
The final step in my 'protect the underside from the elements' saga was replacing the front mud flap brackets with galvanised versions, which I completed today. Actually, that's not the last step as I also plan to replace the suspension hardware with galv. components, but that's a job for the future!
Anyway, I recently bought a set of galv. brackets from good old eBay, which turned up in a blue bag. The galv. coating is a bit rough but otherwise they're absolutely fine, though:
The first task to prepare them for use was a coat of T wash:
And then primer and top coat. I'd usually go with Smoothrite for something like this but I found some nice acrylic paint in my local motor factors that seems to give a decent finish:
I separated the original brackets from the mud flaps by drilling out three rivets. This revealed quite a build up of crud between the flap and the bracket:
To try and avoid this in the future, I cut some thick rubber disks from some offcuts of matting that I had lying around, to form spacers on the fixing bolts:
Hopefully, the resulting gap will allow crud to fall out easier.
The flaps and brackets were then re-assembled using stainless nuts and bolts:
They were then re-attached to the outrigger using more stainless fixings. I did re-use the metal spacers that are fitted as standard and I also took the opportunity to give the mounting points a coat of Dinitrol before they were covered up again.
With the Gwyn Lewis guards in place, the brackets are now quite well protected, so they should last a good, long time.
 Darren
Post #728084 9th Sep 2018 1:40pm
ozzie1989
Wales 2010 Defender 110 Puma 2.4 USW Bonatti Grey
Re: Auxillary Electrics Pt 5 - Wiring
How about a timer relay? You could rig it up so that it's earthed through the light and then you could have it stay on for say 10 minutes after activation.
Alternatively you could just provide a permanent feed to your backlights and earth them through the light feed? Now: 2010 2.4 TDCi 110 Utility Wagon
Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition)
Post #728353 10th Sep 2018 7:14pm
L110CDL
Good idea with the spacer's for the mud flaps Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #728376 10th Sep 2018 7:52pm
