Home > My Defender > An Anorak's Utility Station Wagon
Page 10 of 57 <123 ... 91011 ... 555657>
L110CDL
I must read more slower Laughing good that you have a better item to go on, in place of the plastic bit Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #718126 16th Jul 2018 9:20pm
Staftly
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
Truly great thread, very informative indeed. I have a 2012 110 UTE XS and plan to fit amongst other things a split charge system and sound proofing. Your attention to detail is second to none. This thread will certainly make things much easier for me. Thumbs Up
Staftly
Post #718649 19th Jul 2018 10:38pm
Thanks Smile
I'm part way through wiring up my new control panel at the moment, but it's slow going as 'life' keeps getting in the way Laughing Darren
Post #718675 20th Jul 2018 7:12am
Auxillary Electrics Pt 4 - Circuit Components
I spent a good few hours today wiring up my control panel, which was very satisfying:
Next steps are to cover the panel with vinyl cloth, wire up the switches and make up the vehicle side connector, and I'm nearly there! Darren
Post #719150 22nd Jul 2018 8:02pm
legin
United Kingdom 2012 Defender 90 Puma 2.2 HT Santorini Black
This is well above my pay grade so love watching some one who know what they are doing,also the neatness perfect ,please keep the posts going.
Post #719159 22nd Jul 2018 8:33pm
L110CDL
That does look very satisfying, great bit of work Very Happy 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #719544 24th Jul 2018 9:26pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
LandRoverAnorak wrote:
I didn't realise that Mantec sell them. Mine is an ex-mil one but I didn't pay anywhere near a three figure sum for it Shocked It came with a large 'U' shaped clamp with centres to match the two holes in the mounting plate, which I assume clamps around some part of the Wolf spare wheel mount. This is the third one I've had on different vehicles, which have all needed to be adapted in different ways to suit the circumstances. This one was the easiest.
I actually met the guy that invented them, at Billing show back in 1990-something. He had a stand and was trying to sell them for £50 each but nobody was buying. He then later secured a contract to supply them for the side mounted spares on Wolf Defenders.
I'm not sure how one would fair on your wheel carrier. They do have quite long adjustable straps but they're more for taking up the difference between the sling mounting point and the wheel when positioned on the carrier. Looking at my picture with the wheel on the floor, you'd probably be ok if your final position is no more than about 6 inches higher than standard. Beyond that, you'd end up with the wheel hanging in mid air, which would defeat the object.
Apologies for the old thread resurrection, but I've acquired one of the Mantec Tufflift slings with the adjustable straps and no metal bar. Any clue as how to fix it to the wheel carrier..? I have a TD5 90 with the standard carrier, but will be swapping to a Mantec carrier soon.
Simon
Post #721161 2nd Aug 2018 11:01pm
I think they're designed to fit to holes in the Mantec wheel carrier, so you'd have to drill a couple of suitable holes in the sides of a standard door mount.
Have you got a picture? Darren
Post #721168 3rd Aug 2018 6:32am
couplands
Here's the photo...
Simon
Post #721313 3rd Aug 2018 8:21pm
Procta
couplands I think that might be for defenders that don't have a swing way or some other system, As that one is different to mine. ( check out my thread for the installation) Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it!
Post #721329 3rd Aug 2018 9:11pm
couplands
Could you point me to your thread..?
I currently have the standard wheel carrier (my 2001), but have ordered a Mantec one.
I'm sure I can fabricate something, but interested in how it is meant to work.. Very Happy
Simon
Post #721335 3rd Aug 2018 9:23pm
Yeah, that's the one for use with their wheel carrier, which has holes for the two larger yellow plastic tags. Darren
Post #721336 3rd Aug 2018 9:23pm
couplands
^^^ perfect, just waiting for the Mantec carrier to arrive... Thumbs Up
Having said that, on the photos and fitting instructions of the Matec carrier, I can't see any holes that would allow the toggles to be attached.... Confused
Simon
Post #721340 3rd Aug 2018 9:59pm
It wouldn't surprise me if their instructions are out of date. The slings are relatively new products for them and yours is advertised as being suitable for use with their carrier. Darren
Post #721344 3rd Aug 2018 10:11pm
Procta
Simon
http://www.defender2.net/forum/topic50945-615.html Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #721347 3rd Aug 2018 10:52pm
