![]() | Home > My Defender > My 110 MILLIE. |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10383 ![]() ![]() |
Rustic, but effective
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10874 ![]() ![]() |
![]() ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
legin Member Since: 22 Jul 2017 Location: Chelmsford Essex Posts: 1004 ![]() ![]() ![]() |
I like the shield
Millie is looking good there Clayton
![]() 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
Thanks Legin and Mash
I regret not having mine done, a friend did nearly every part when he rebuilt his 90. Looks well Clayt
You can still get it done GREENI , many thanks
Just an update on the fuel cap really, had no problems with it from the last update and i am well pleased with it .........
![]() Click image to enlarge ![]() Click image to enlarge ![]() ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Well Millie had a subtle up grade the other day kindly from a member on here, so, as it always takes longer than it should
![]() ![]() Before ................ ![]() Click image to enlarge After .................. ![]() Click image to enlarge I was not to sure at first if i would like them on, but i think they go well with the wheel nut covers, so i'm a happy bunny .... ![]() Click image to enlarge Many thanks to Procta ![]() ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20616 ![]() ![]() |
Is that socket head cap bolts on the flanges with plastic caps? Chillin In The Backwoodsπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
Just put the plastic caps on Steve
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5236 ![]() ![]() |
Looks miles better ![]() ![]() Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
Thanks Procta
shayes Member Since: 29 May 2016 Location: Devon Posts: 153 ![]() ![]() ![]() |
Morning Clayton, loving what you have recently done to Millie, proper working Rover. Indy (JT?) has done some good work. I was in there the other month and was impressed, with the set up and work they were doing. Hopefully see Millie passing soon,
Cheers, Simon ![]() ![]() |
