Home > Off Topic > My RRC project |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 |
Door handles weren't Maestro - they were Marina/Allegro... at least they were on my J reg ex works 3 door 200Tdi.
8th Dec 2017 9:24pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4794 |
Both of my range rovers are full of montego switchgear 2002 90 Td5 Station Wagon
9th Dec 2017 9:17pm |
newer jag use ford chassis |
10th Dec 2017 1:38pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5223 |
dorsetsmith, I think the jag uses or used the mondao floor pan. My pal said they used the ford locks too. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
11th Dec 2017 12:37am |
The Jaguar x-type was basically a Mondeo. Running gear, engine and a lot of the electronics. The V6 Jag is basically a AWD ST220 2002 90 Td5 Station Wagon
11th Dec 2017 6:46pm |
Double post 2002 90 Td5 Station Wagon
1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton Last edited by grafty99 on 29th Jan 2020 10:51pm. Edited 1 time in total |
12th Dec 2017 5:56pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10854 |
I bet you will be spending a lot of time in your workshop with all this weather were having, happy dismantling Clayton.
1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
13th Dec 2017 8:38pm |
Looking under the shell, my previous assumptions were correct. The rear shell is pretty good and the front is poor. Thinking of welding the obvious bits and then getting the shell blasted. Any thoughts? 2002 90 Td5 Station Wagon
13th Dec 2017 9:52pm |
Oops, forgot to add under shots
Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
13th Dec 2017 9:54pm |
mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772 |
I really want a lift at home keep the pics coming please Ray
13th Dec 2017 11:21pm |
Frivillesid Member Since: 20 Nov 2017 Location: Albuquerque, USA Posts: 2 |
agreed with the previous poster, keep the pics coming. btw, my last range was looking quite the same but had health issues and been searching for meds reviews and so i had to sell it. unfortunately.
14th Dec 2017 5:30pm |
Made a little bit of progress today. Kept getting distracted
Needs a really good clean up but a good base to start with. Click image to enlarge I then split the engine and box so I can work on the engine easier. Could really do with an engine stand but haven't got the room to store one. Hence working on the crane (not ideal). Click image to enlarge And finally stripped off the engine mounts and sump so they could have a spruce up Click image to enlarge RCP applied. Will get the top coat on tomorrow and then get the engine in hopefully 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton Last edited by grafty99 on 29th Jan 2020 10:52pm. Edited 1 time in total |
14th Dec 2017 7:04pm |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 |
Gearbox sump is another excuse for a bit of RCP relief
Did mine the other weekend along with kickdown cable replacement along with filter kit |
14th Dec 2017 7:25pm |
Yeah the gearbox is next on my list. Need to split it from the transfer box first and get it off the ground 2002 90 Td5 Station Wagon
14th Dec 2017 7:27pm |
